| 2004-2007 Cadillac CTS-V Performance Mods Discuss all Cadillac CTS-V performance modifications here. Engine tunes, exhaust, intake, suspension and more. | Cadillac Forums: Photos of Creative Steel Ultra Mounts Transmission Mount Vs. UUC Transmission Mount
09-24-09, 12:10 PM
| | Cadillac Owners Connoisseur Cadillac(s): 06 CTS-V | | Join Date: Mar 2007 Location: tha peg | | | Re: Photos of Creative Steel Ultra Mounts Transmission Mount Vs. UUC Transmission Mou Quote:
Originally Posted by SkullV Well, now there are multiple reported cases of UUC mounts (both motor and transmission) breaking...choice should be easy for $100+ less for the full set. | I never read any cases of the UUC tranny mount failing, can you put up some links for that?
Any hint at it failing I'll be asking for a refund and buying Ultra's. |
09-24-09, 12:22 PM
|  | Cadillac Owners Connoisseur Cadillac(s): 2005 Redline CTS-V, 1997 Catera | | Join Date: Mar 2007 Location: Purdue University | | | Re: Photos of Creative Steel Ultra Mounts Transmission Mount Vs. UUC Transmission Mou Quote:
Originally Posted by lollygagger8 DO NOT go UUC trans mount, it's a turd. See my @#&$@(#$)% UUC Trans Mount thread.....the f'n stud just turns in it.
How much is this Creative Trans Mount? And how much did it translate vibrations? | Not sure on the price, and I'll know tomorrow night about the vibrations when I get my car back....
__________________ R.I.P. Cadillacforums..... |
09-24-09, 12:23 PM
Originally Posted by tommy compton I never read any cases of the UUC tranny mount failing, can you put up some links for that?
Any hint at it failing I'll be asking for a refund and buying Ultra's. | http://www.cadillacforums.com/forums/2013382-post2.html |
09-24-09, 12:25 PM
Originally Posted by SkullV | LOL aside from that one that just popped up. |
09-24-09, 12:27 PM
Originally Posted by tommy compton LOL aside from that one that just popped up. | The others are just studs spinning in the mount, which I would consider a failure.... |
09-24-09, 12:34 PM
| | Cadillac Owners Connoisseur Cadillac(s): 06 CTS-V | | Join Date: Mar 2007 Location: tha peg | | | Re: Photos of Creative Steel Ultra Mounts Transmission Mount Vs. UUC Transmission Mou That happened on mine, but I really don't think the studs have any place to go. Failure to me would be seperation, but yes a poor design.
If Ultra's had came out only days sooner I would have bought his. From what I'm hearing Ulta's is superior, not rocket science that UUC should have tacked down the bolts, and added something inside the brackets for the urethane to better adhere to. |
09-24-09, 02:41 PM
|  | Drive It. Break It. Build it Better Cadillac(s): Platinum 2004 CTS-V | | Join Date: Apr 2008 Location: Indiana | | | Re: Photos of Creative Steel Ultra Mounts Transmission Mount Vs. UUC Transmission Mou Well I consider the spinning bolts a minor failure. But when I get the car on the ground and go down the street with it and it makes a noise (almost as loud as when a trans mount will fail and trans bumps against the floor) I consider that an epic fail.
Luke is stepping up and sending me another UUC Mount as he thinks it's an isolated incident. If this one does the same thing, I'm done with UUC anything.
__________________ Monster Stage 3 Clutch & 18 lb flywheel, B&B headers w/ hi flow cats, B&B xpipe & catback, Lingenfelter CAI, UUC Gen II Motor Mounts/Trans Mount/Shifter/Shifter Bushings/Diff Bushing, Hotchkis Sways, BMR Trailing Arms & AWH Bushings, Hawk Pads, GM Assy Wheels, Stock Wheels, Drilled GM Rotors, Hendrix Axles, CAGS Elim, '06 Diff w/updated pinion, Clear Fogs DDM bulbs, Clear Sidemarkers, CTS center console, Tuned by Brent @ EPP on mustang dyno @ 378rwhp/366tq |
09-24-09, 02:43 PM
|  | Drive It. Break It. Build it Better Cadillac(s): Platinum 2004 CTS-V | | Join Date: Apr 2008 Location: Indiana | | | Re: Photos of Creative Steel Ultra Mounts Transmission Mount Vs. UUC Transmission Mou Quote:
Originally Posted by SkullV Not sure on the price, and I'll know tomorrow night about the vibrations when I get my car back.... | You didn't buy the mounts? Are you not personally putting the mount in or something?
Let me know if you feels any vibes Ted, thanks Boss. |
09-24-09, 03:16 PM
Originally Posted by lollygagger8 You didn't buy the mounts? Are you not personally putting the mount in or something?
Let me know if you feels any vibes Ted, thanks Boss. | Got sent a tester mount. I am installing it myself tomorrow at a friend's shop and will have test results and a writeup Saturday. |
09-24-09, 03:51 PM
|  | Drive It. Break It. Build it Better Cadillac(s): Platinum 2004 CTS-V | | Join Date: Apr 2008 Location: Indiana | | | Re: Photos of Creative Steel Ultra Mounts Transmission Mount Vs. UUC Transmission Mou Nothing like waiting til the last minute huh? lol. Good luck Boss  |
09-24-09, 04:12 PM
|  | Cadillac Owners Connoisseur Cadillac(s): 04 CTS-V with a little hp persuasion device | | Join Date: Oct 2007 Age: 24 | | | Re: Photos of Creative Steel Ultra Mounts Transmission Mount Vs. UUC Transmission Mou Quote:
Originally Posted by lollygagger8 Well I consider the spinning bolts a minor failure. But when I get the car on the ground and go down the street with it and it makes a noise (almost as loud as when a trans mount will fail and trans bumps against the floor) I consider that an epic fail.
Luke is stepping up and sending me another UUC Mount as he thinks it's an isolated incident. If this one does the same thing, I'm done with UUC anything. | It'll happen again.
__________________ 04 Raven CTS-V / Forged and maggied LS6 / 90mm TB / 8 rib pulleys / 8" overdrive balancer with 2.7" blower pulley / LG G5X1 / Crane 1.8 gold rollers / 1 7/8 Kooks / ARP hardware throughout / Melling oil pump / Cloyes double roller / Volant CAI / Fidanza LS7 flywheel / Spec Stage 3 / Ground Control / QA1's / RC51 motor mounts / UUC diff, and shifter bushings / UUC Vknob / Katech STS / Rear strut bar / Kars III |
09-24-09, 05:21 PM
| | Cadillac Owners Fanatic Cadillac(s): 05 CTS-V | | Join Date: Aug 2009 Age: 23 | | | Re: Photos of Creative Steel Ultra Mounts Transmission Mount Vs. UUC Transmission Mou anyone have pics of the stock mount ? |
09-24-09, 06:48 PM
| | Cadillac Owners Member Cadillac(s): '04 CTS-V | | Join Date: Mar 2009 Location: DFW TX Age: 30 | | | Re: Photos of Creative Steel Ultra Mounts Transmission Mount Vs. UUC Transmission Mou any chance of selling the motor mounts and tranny mount as a "kit" or something? I am getting ready to do the motor mounts but if the price worked out I would just do them all at once! |
09-24-09, 11:44 PM
| | Cadillac Owners Member Cadillac(s): none | | Join Date: May 2009 Age: 43 | | | Re: Photos of Creative Steel Ultra Mounts Transmission Mount Vs. UUC Transmission Mou Quote:
Originally Posted by AG'S-V Hmmm...this poses the question...all UUC mounts or all CS with a UUC axle bushing... | Give me some time, if you guys want another choice for axle bushings, just say so. I'll be all over it. Quote:
How much is this Creative Trans Mount? And how much did it translate vibrations? | ULTRA MOUNTS trans mount is $130 shipped. Where the heck is PlatinumCavette when you need him. Yo...Damon....we need a vibration report. Quote:
Any hint at it failing I'll be asking for a refund and buying Ultra's. | NO WAY TOMMY  , you made your bed...now sleep in it.
Just giving you shit man, the door is always open Quote:
Originally Posted by kpc01 any chance of selling the motor mounts and tranny mount as a "kit" or something? I am getting ready to do the motor mounts but if the price worked out I would just do them all at once! | Oh, now you're gonna try to "work" for a better price, man...is nothing sacred? Someone just mentioned a few posts ago that we're over $100 cheaper as it is and our bolts are welded in and don't spin. Now, are we going to have any more talk about this?
__________________ Our phone number is 503-316-1811 We're here M-F, 8-5 Pacific Time.
I'll let you know when the web site is up. |
09-25-09, 01:18 AM
| | Cadillac Owners Member Cadillac(s): '04 CTS-V | | Join Date: Mar 2009 Location: DFW TX Age: 30 | | | Re: Photos of Creative Steel Ultra Mounts Transmission Mount Vs. UUC Transmission Mou no worries, I plan on ordering the motor mounts in the next few weeks from you no matter what! I'm just the type that would buy the kit to save a few bucks. either way you will be getting some of my money! just not as much as if it was a kit  | | Cadillac Discussion Tools | | |
Censor is OFF | | | |
