Not impressed with KARS III...so far. - Page 3
Page 3 of 3 FirstFirst 123
Results 31 to 44 of 44
2004-2007 Cadillac CTS-V Performance Mods Discussion, Not impressed with KARS III...so far. in Cadillac CTS-V Series Forum - 2004 - 2007; Has anyone gotten spacer measurements yet? I am trying to figure out if my bushings are too thin or if ...
  1. #31
    SkullV's Avatar
    SkullV is offline Cadillac Owners Connoisseur
    Automobile(s): NONE
    Mar 2007
    Downtown Chicago
    3,844
    Re: Not impressed with KARS III...so far.
    Has anyone gotten spacer measurements yet? I am trying to figure out if my bushings are too thin or if there is another problem (the bushings will not sit tightly in the cradle even with the car on the ground).
    According to Randy's measurements it should be:
    .OD.......Length......Qty
    2-1/2".....9/16".........2
    2-1/2".....?????.........2
    ...3"........7/16".........2
    ...3"........1/2"...........2
    According to the directions with the "Gen 2" Kars III kit it should be:
    2-1/2".....3/8"...........2
    2-1/2".....1/2"...........2
    ...3"........3/8"...........2
    Like I said, the ones that came with my "gen 2" Kars III kit are a little loose
  2. #32
    JimmyH is offline Cadillac Owners 10000+ Posts
    Dec 2006
    42
    37,302
    These cradles are all off because they are not assembled nor welded in a jig. They are tacked together and then welded on a table. Guess what happens when you do that?
    btw, I still have yet to hear a reasonable explanation of how this "KARS cradle" does more good than the problems it causes.
  3. #33
    SkullV's Avatar
    Automobile(s): NONE
    Mar 2007
    Downtown Chicago
    3,844
    Quote Originally Posted by JimmyH View Post
    Well, even with the shitty fitment and the loose bushings it killed 90% of my hop.
  5. #34
    Dec 2006
    42
    37,302
    I have never doubted that. But I wonder what kinds of problems it is going to introduce later on. Problems that will likely not even be traceable back to the kars. If it is helping to hold the differential in place better, that is undoubtedly going to transfer mechanical stresses and strain somewhere else in the chassis.
  6. #35
    Dec 2006
    42
    37,302
    I think if people accepted the limitations of this car, they would be much happier with it.
  7. #36
    SkullV's Avatar
    Automobile(s): NONE
    Mar 2007
    Downtown Chicago
    3,844
    It keeps the differential from twisting, but does allow some up/down motion. I honestly feel that it will not cause any true problems down the road. If you are afraid of hurting the diff you can take the diff support off and just use the cradle support portion of the kit.
  8. #37
    Dec 2006
    42
    37,302
    I hope for your sake you are right. But I look at pictures of that cradle, how it works, and what it does, and just looks all wrong to me.
  9. #38
    The Tony Show's Avatar
    The Tony Show is offline See you in the funny papers
    Automobile(s): 04 CTS-V, 05 STS, 07 SRX- All sold :(
    Dec 2004
    The Internet
    26,239
    I still contend that using the pinion brace in conjunction with the KARS kit focuses all the stress of the flexing cradle and diff onto the nose of the diff, which is why we've seen several vehicles with this setup split the case right at the front.
    Rest in Peace, J.D. (aka Dirt_Cheap_Fleetwood)
  10. #39
    rand49er's Avatar
    Jan 2005
    South Lyon, MI
    68
    13,827
    Quote Originally Posted by The Tony Show View Post
    I still contend that using the pinion brace in conjunction with the KARS kit focuses all the stress of the flexing cradle and diff onto the nose of the diff ...
    Hm-m ... funny you should say that. I did another vid of the noise I've been having a problem with. Put the mic near the output shaft of the tranny then moved it to point at the nose of the diff. Hope to post it up tomorrow morning sometime. It sure as heck sounds like the noise is coming from exactly there ... the nose of the diff. Also funny, though, is that I've never done more than three or four burnouts the whole time I had the KARS kit on and those were with the DSS/Hendrix axles.
  11. #40
    CTS-Voodoo's Avatar
    CTS-Voodoo is offline Cadillac Owners Enthusiast
    Automobile(s): 05 Raven V
    Oct 2008
    AutoRepairSEO.com
    951
    Quote Originally Posted by SkullV View Post
    This is exactly how mine is run. When we first put it on I had the brace attached and the associated gear meshing sounds were enough for me to have near old-car-guy heart attacks. You could literally hear the gears meshing together with the clutch in on smooth roads and when accelerating there was a whine that duplicates a supercharger or gear drive (again with the old car references)
    I will probably be modding mine out so the bar doesnt hang down too far in the front, but right now Im looking into Holden Commodore VE differentials. Interesting that the holden VE and the CTSV have the same badges....
  12. #41
    Dec 2006
    42
    37,302
    Quote Originally Posted by CTS-Voodoo View Post
    potd
  13. #42
    CTS-Voodoo's Avatar
    Oct 2008
    AutoRepairSEO.com
    951
    potd
    Im not as willing to accept road noise in a luxury vehicle as others apparently.
  14. #43
    SkullV's Avatar
    Automobile(s): NONE
    Mar 2007
    Downtown Chicago
    3,844
    I'll run it like this until it causes problems or someone releases a cost effective replacement. It does work and that is what matters. I have a VERY understanding dealership who will replace diffs and transmissions all day long so we'll see what happens...to be perfectly honest, I'm still a kid so the noise doesn't bother me that much.
  15. #44
    ahahnu's Avatar
    ahahnu is offline Cadillac Owners Connoisseur
    Automobile(s): '05 LS6 V Stealth Grey; '14 Z71 SLT Sierra 1500 Stealth Grey
    Dec 2004
    Tailgating at Giants Stadium
    37
    2,821
    I've had my Original Kars kit, Doug put it on himself for 70,000 or so. At 50,000 right before my warranty ran out, I asked the dealer to replace the rear, which they did. So same rear, Kars kit the whole time, and were almost to 50,000 on it. Yes it whines, yes it's loud. It's actually louder when rolling versus accellerating. I wouldn't feel comfortable not using it. The times I had it off, you could feel a difference (maybe just mental) of the "grip" it would have on the road, versus feeling like a feather when it was off.
  16. Remove Advertisements
