Time for a clutch...What path would you go?
Page 1 of 3 1 2 3 LastLast
Results 1 to 15 of 33
2004-2007 Cadillac CTS-V Performance Mods Discussion, Time for a clutch...What path would you go? in Cadillac CTS-V Series Forum - 2004 - 2007; My V is about to hit 50,000 miles. For the past 3000 or so, 1st has been difficult to get ...
    Doctornick is offline Cadillac Owners Fanatic
    Automobile(s): '05 CTS-V
    Nov 2007
    Miami, Fl and Chicago, Il.
    433
    My V is about to hit 50,000 miles. For the past 3000 or so, 1st has been difficult to get into if I stop the car on a slope or if "I have a quick full stop, pull the car out of gear intending to be a long light but it wasn't and now it won't go back into first and a got a group of cars behind me honking" type situation.
    My mechanic thinks its the hydraulics and I would assume that part is going to be covered under my GMPP but he did suggest looking into buying a clutch.
    I put 15k miles on it every year and have a magnacharger kit sitting in a box in my storage. (saving for cams, headers and tune, still.) It would be nice if I don't have to swap out the clutch when the blower goes on, but I might not get to it this year. So its not that big a deal.
    So whatcha think?
    -Neal
    manciniat is offline Cadillac Owners Fanatic
    Automobile(s): 2004 cts-v
    Jun 2009
    40
    155
    Re: Time for a clutch...What path would you go?
    deedubb's Avatar
    deedubb is offline Cadillac Owners Connoisseur
    Automobile(s): E85 Powered - Maggie'd V
    Feb 2005
    Mile High
    36
    1,747
    2nd vote for monster clutches
    whisler151's Avatar
    whisler151 is offline Cadillac Owners Connoisseur
    Automobile(s): 2012 CTS-V Sedan, 2011 CTS Coupe, 2010 Ford Raptor
    Apr 2007
    Dallas, TX
    3,547
    At the risk of sounding like a broken record, I too say Monster. Sounds like you will be needing a level 3 if you do a nice cam with the headers and maggie. Have fun!
    c4ss's Avatar
    c4ss is offline Cadillac Owners Connoisseur
    Automobile(s): 2005 CTS-V, Black
    Jun 2008
    Northern New Jersey
    2,166
    Quote Originally Posted by whisler151 View Post
    Before I even clicked it, I KNEW you'd comment on this thread, whisler
    Whisler is the clutch guru. I'd probably say go with Monster as well though
    whisler151's Avatar
    Apr 2007
    Dallas, TX
    3,547
    Quote Originally Posted by c4ss View Post
    You know it. I've done my research. Of course it's pretty easy when we only have two or three options for a clutch in our V (that fits).
    Now trying to pick a cam is another story!
    darkman's Avatar
    Nov 2005
    Spring, Texas
    8,161
    Quote Originally Posted by Doctornick View Post
    So whatcha think?
    -Neal
    I think your mechanic is probably right - your problem is more than likely your hydraulics, which consists of fluid within a master cylinder, hose line, slave cylinder. The inability to get the thing in gear is more often than not, a clutch disengagement issue.
    Your mechanic is also right about it being time to consider a new clutch. But then again there is the warranty which does not cover the wearing parts (e.g. clutch disc) but may cover the hydraulics. Additionally, installing a new clutch will not necessarily cure the disengagement problem if is caused by unreplaced hydraulic components.
    Of the list of hydraulic components only the slave cylinder requires you to drop the transmission and pull the bellhousing. So, if I were you I would: (1) try to get the disengagement problem sorted out under warranty before installing a new clutch; and (2) go ahead and select your next clutch setup so if step#1 leads to the slave cylinder and the need to drop the transmission/bellhousing you would be in a position to change out the clutch at the same time. (The idea being to negotiate a deal to get the wearing parts installed for the cost of "incremental labor" since the transmission/bellhousing are off the car for warrantied problems.)
    As far as new clutches go, in addtion to the Monster Clutches proffered by others, there are also options from McLeod, Spec, Textralia, and Exedy to name a few.
    stuckey's Avatar
    stuckey is offline Cadillac Owners Enthusiast
    Automobile(s): 04 CTS-V
    Jul 2008
    Alabama
    34
    936
    another question for the clutch "guru"...whats the difference in the level 3 and level 3.5 aside from being $100 more
    Hendrix-Engineering is offline Cadillac Owners Enthusiast
    Automobile(s): escalade
    May 2009
    571
    Quote Originally Posted by darkman View Post
    I agree100%,you dont want the same issues with a new clutch.We also have a clutch that drives like stock and holds tons of power.Check out the H.E.X. clutch from Hendrix-Engineering
    whisler151's Avatar
    Apr 2007
    Dallas, TX
    3,547
    Quote Originally Posted by stuckey View Post
    The .5 levels of their clutches are made with daily driving in mind. They try to make a heavy duty clutch, easier for everyday driving. The .5 level has a hybrid organic layer on the flywheel side to assist in smother launches. You will still have a bit of chatter, but it wares off as you break in the clutch.
    maxspeed96ct is offline Cadillac Owners Connoisseur
    Automobile(s): 05 CTS-V
    Aug 2009
    31
    1,048
    to all the guys that recomended monster clutches?
    Do you have them or do you just Think they are a good product ?
    Im on the same boat, im shoipping for a clutch setup as we speak...
    looking into the spec kit, the monster kit, or the LS7 kit, and im also trying to find out more on the hendrix kit, it sounds like a good setup..
    The monster seems good but they have had some issues, and for some reason all the F-body guys has problems with the master cylinder after install the monster kit, but guys just modified the stock one and they are fine with it. ( I personly dont want to deal with that crap)
    The spec kit from what ive read just dont last, but you can get a stage 2 with steel fly for 615$
    and the Ls7 kit seems like a awsome deal, but only if your making stockish power.
    Still learning more about the hendrix kit but i like everything ive heard about his company so far.
    whisler151's Avatar
    Apr 2007
    Dallas, TX
    3,547
    Quote Originally Posted by maxspeed96ct View Post
    I have it, and think it's a good product.
    Aug 2009
    31
    1,048
    which stage and which fly ?
  16. #14
    CTS-Voodoo's Avatar
    CTS-Voodoo is offline Cadillac Owners Enthusiast
    Automobile(s): 05 Raven V
    Oct 2008
    AutoRepairSEO.com
    951
    Hendrix.
  17. #15
    ctsv154's Avatar
    ctsv154 is offline Cadillac Owners Connoisseur
    Automobile(s): 04 CTS-V with a little hp persuasion device
    Oct 2007
    32
    3,824
    Umm, no offense, but you haven't even driven the H-E clutch so how can you recommend it? I'm sure it will work just fine but honestly how can you recommend something you have never used?
    This isn't to bash anybody so dont take it that way. I just dont see the logic.
  18. Remove Advertisements
