| 2004-2007 Cadillac CTS-V Performance Mods Discuss all Cadillac CTS-V performance modifications here. Engine tunes, exhaust, intake, suspension and more. | Cadillac Forums: I finally have my Hendrix Pro axles!!! Hendrix ???
09-17-09, 10:46 AM
|  | Hemi, It's what's for dinner.... Cadillac(s): CTS-V | | Join Date: Jan 2007 Location: Dallas, TX Age: 29 | | | Re: I finally have my Hendrix Pro axles!!! Hendrix ??? Quote:
Originally Posted by lollygagger8 (34mm is the socket you'll need for the spindle nut) |
I included the 34mm socket and the 22mm gear wrench with the axles! Am i a good seller or what? lol
09-17-09, 11:15 AM
|  | Drive It. Break It. Build it Better Cadillac(s): Platinum 2004 CTS-V | | Join Date: Apr 2008 Location: Indiana | | | Re: I finally have my Hendrix Pro axles!!! Hendrix ??? Quote:
Originally Posted by Kmajecki I included the 34mm socket and the 22mm gear wrench with the axles! Am i a good seller or what? lol | Well you are half badass.....he needs a 21mm wrench
Hopefully that was a typo, and you've moved backup to full badass
__________________ Monster Stage 3 Clutch & 18 lb flywheel, B&B headers w/ hi flow cats, B&B xpipe & catback, Lingenfelter CAI, UUC Gen II Motor Mounts/Trans Mount/Shifter/Shifter Bushings/Diff Bushing, Hotchkis Sways, BMR Trailing Arms & AWH Bushings, Hawk Pads, GM Assy Wheels, Stock Wheels, Drilled GM Rotors, Hendrix Axles, CAGS Elim, '06 Diff w/updated pinion, Clear Fogs DDM bulbs, Clear Sidemarkers, CTS center console, Tuned by Brent @ EPP on mustang dyno @ 378rwhp/366tq |
09-17-09, 09:41 PM
|  | Hemi, It's what's for dinner.... Cadillac(s): CTS-V | | Join Date: Jan 2007 Location: Dallas, TX Age: 29 | | | Re: I finally have my Hendrix Pro axles!!! Hendrix ??? lol Yea i forget what size was needed, but i sent him what i used from your install thread so must have been a 21mm, good catch though
Or like i used to say as a kid, "close enough", man i used to strip bolts left and right! |
09-18-09, 11:06 AM
| | Cadillac Owners Fanatic Cadillac(s): Raven Black 2004 CTS-V. Broken Diff! | | Join Date: Jan 2009 Location: San Juan Capistrano, CA Age: 26 | | | Re: I finally have my Hendrix Pro axles!!! Hendrix ??? Adjustable Crescent Hammer works great |
09-18-09, 01:57 PM
|  | Cadillac Owners Connoisseur Cadillac(s): 2005 CTS-V | | Join Date: Nov 2005 Location: Spring, Texas | | | Re: I finally have my Hendrix Pro axles!!! Hendrix ??? Quote:
Originally Posted by mpunklil Adjustable Crescent Hammer works great | Metric or standard? |
09-21-09, 11:12 AM
| | Cadillac Owners Fanatic Cadillac(s): Raven Black 2004 CTS-V. Broken Diff! | | Join Date: Jan 2009 Location: San Juan Capistrano, CA Age: 26 | | | Re: I finally have my Hendrix Pro axles!!! Hendrix ??? Standard Metric Quote:
Originally Posted by darkman Metric or standard? | |
09-23-09, 10:50 PM
|  | Cadillac Owners Fanatic Cadillac(s): 05 CTS V | | Join Date: Feb 2009 Location: Avondale, AZ | | | Re: I finally have my Hendrix Pro axles!!! Hendrix ??? received the axle nuts today, thanks Thomas and Hendrix to the rescue. I should be installing this weekend. I decided to change the diff fluid and through research of previous threads, I have decided to go with Torco RGO 85W/140 w/ limited slip additive. Any one else using this stuff??
__________________ Platinum, Katech STS, MOMO knob, UUC shifter/diff poly bushings, clear corners & STSV fogs, Billet radio,A/C,door pulls, & armrest endcaps,aluminum dash overlay,rear spoiler,CreativeSteel Tranny/Motor UltraMounts,STAGEUP tuned,Accessory wheels,.08oz lugs, JETHOT KOOKS 1 7/8,HI FLO Cats, AeroTurbine muffs,H pipe, Specter Werkes cradle bushings,Billet Prototypes catchcan,NGK TR55, Optima RedTop, Hendrix PRO axles, Hawk HPS, cryo/cross drilled rotors(R). BEST E.T. to date 11/06/09: 13.495 @ 107.00 |
11-04-09, 01:44 AM
|  | Cadillac Owners Fanatic Cadillac(s): 05 CTS V | | Join Date: Feb 2009 Location: Avondale, AZ | | | Re: I finally have my Hendrix Pro axles!!! Hendrix ??? The Hendrix Pro axles are installed and everything is working well. Installed new cross drilled rear rotors, Hawk HPS pads and changed the diff fluid with Torco 85/140. Did a couple of clutch dumps and we are ready for Friday at the strip. I will post IMPROVED E.T.'s this weekend, I hope to not dissapoint myself. |
11-04-09, 07:20 AM
| | Cadillac Owners Fanatic Cadillac(s): 05 CTS-V | | Join Date: Aug 2009 Age: 23 | | | Re: I finally have my Hendrix Pro axles!!! Hendrix ??? Quote:
Originally Posted by verywhitedevil received the axle nuts today, thanks Thomas and Hendrix to the rescue. I should be installing this weekend. I decided to change the diff fluid and through research of previous threads, I have decided to go with Torco RGO 85W/140 w/ limited slip additive. Any one else using this stuff?? |
Im running B&G gear oil with their limited slip additive, ive been hard on the rear end but I also just changed to it a few months back |
11-05-09, 02:16 PM
| | Cadillac Owners Fanatic Cadillac(s): 2005 Cadillac CTS-V | | Join Date: Mar 2007 Location: Mesa, AZ | | | Re: I finally have my Hendrix Pro axles!!! Hendrix ??? Quote:
Originally Posted by verywhitedevil The Hendrix Pro axles are installed and everything is working well. Installed new cross drilled rear rotors, Hawk HPS pads and changed the diff fluid with Torco 85/140. Did a couple of clutch dumps and we are ready for Friday at the strip. I will post IMPROVED E.T.'s this weekend, I hope to not dissapoint myself. | Mike, Firebird sticks a lot better than Speedworld. Im sure you will do wayyyyy better! |
11-07-09, 12:47 PM
|  | Cadillac Owners Fanatic Cadillac(s): 05 CTS V | | Join Date: Feb 2009 Location: Avondale, AZ | | | Re: I finally have my Hendrix Pro axles!!! Hendrix ??? I consider the Hendrix Pro axle mod a success. With a little more seat time, ET's will come down. I experienced zero wheel hop on my 4 passes. The car launches different, so first two didn't count, LOL. Second two were getting better. 60 ft 2.203, 13.495 @ 107. Last pass was better, but the ticket machine was busted, so no record information. 109 @ 13.40's.
Convinced my friend to bring his pulleyed, full exhaust, tuned 09 V2. First time to the strip for him. WOW. I wish the first time I ever went to the drag strip someone handed me a 640 HP racecar. His car IS fast and his times do not reflect the capabilities of his car. We coached him to a mild 12.82 spinning and rev limiting 1st & 2nd. Care is a BEAST and sounds FN awesome with his handbuilt LT headers and exhaust. Once he gets the hang of it and some drag radials, his time will definitely improve. On the HWY, from a 60 stomp, there is I dare say, very, very few cars that run as strong as a V2 with those upgrades.
Back at it again December 6th. |
11-07-09, 05:44 PM
| | Cadillac Owners Fanatic Cadillac(s): escalade | | | | | Re: I finally have my Hendrix Pro axles!!! Hendrix ??? Great to hear about your sucsess .Guess we know a little something after all  |
11-07-09, 08:07 PM
|  | Cadillac Owners Connoisseur Cadillac(s): 2005 Redline CTS-V, 1997 Catera | | Join Date: Mar 2007 Location: Purdue University | | | Re: I finally have my Hendrix Pro axles!!! Hendrix ??? Quote:
Originally Posted by verywhitedevil I consider the Hendrix Pro axle mod a success. With a little more seat time, ET's will come down. I experienced zero wheel hop on my 4 passes. The car launches different, so first two didn't count, LOL. Second two were getting better. 60 ft 2.203, 13.495 @ 107. Last pass was better, but the ticket machine was busted, so no record information. 109 @ 13.40's.
Back at it again December 6th. | Nice! What tires are you running?
__________________ R.I.P. Cadillacforums..... |
11-07-09, 09:22 PM
|  | Cadillac Owners Fanatic Cadillac(s): 05 CTS V | | Join Date: Feb 2009 Location: Avondale, AZ | | | Re: I finally have my Hendrix Pro axles!!! Hendrix ??? Vredestein. They are pretty bald and next time hope to have some 275/40/18 out back. |
11-07-09, 09:30 PM
Originally Posted by verywhitedevil Vredestein. They are pretty bald and next time hope to have some 275/40/18 out back. | Hmmm...probably why you aren't getting any hop...but who cares, great time! | | Cadillac Discussion Tools | | |
Censor is OFF | | | |
