LS6 vs. LS2...Yes, I did a search. - Page 4
Page 4 of 4 FirstFirst 1 2 3 4
Results 46 to 60 of 60
2004-2007 Cadillac CTS-V Performance Mods Discussion, LS6 vs. LS2...Yes, I did a search. in Cadillac CTS-V Series Forum - 2004 - 2007; Originally Posted by Jahan I don't really need to prove anything to anyone. I've driven several of each over the ...
  1. #46
    jpoole's Avatar
    jpoole is offline Cadillac Owners Fanatic
    Automobile(s): 2010 Cadillac CTS-V
    May 2007
    McKinney, Texas
    266
    Re: LS6 vs. LS2...Yes, I did a search.
    Quote Originally Posted by Jahan View Post
    I don't really need to prove anything to anyone. I've driven several of each over the past 4 months, as well as many other LS2/3/6 cars. I can feel a difference. Is it night and day? No, but to me the LS2 is more enjoyable in the CTS-V. The difference between the engines are well documented, it shouldn't be a surprise that the performance isn't exactly the same.
    Your 30 year argument MIGHT hold water; I'm not familiar enough with collector cars. But the engines are similar enough that I don't think it will make a huge difference. I'd guess that LS2 CTS-V's are rarer, and since they have a bit more torque and are the later model with improved rear end, the LS2 might actually get the nod. Who knows though . . . I know I don't plan on owning a CTS-V 30 years down the road.
    Well it is all settled now... Thanks! All it took was a non-V owner to test drive SEVERAL of each motor variant, and FEEL that difference. LOL
    Also, you are dead on with your GUESS also.
  2. #47
    whisler151's Avatar
    whisler151 is offline Cadillac Owners Connoisseur
    Automobile(s): 2012 CTS-V Sedan, 2011 CTS Coupe, 2010 Ford Raptor
    Apr 2007
    Dallas, TX
    3,547
    I was not expecting to feel a difference between the LS2 and LS6 CTS-V's, but I could. The LS2 is noticeably torquier in the low-mid range, and I've decided that when I buy a V (sometime in the next 6 months) it will be an LS2. The torque curve just fits the V better, and I don't think the extra high end of the LS2 makes up for it in this car.
    Quote Originally Posted by jpoole View Post
  3. #48
    Jahan is offline Cadillac Owners Member
    Jun 2006
    36
    Lol. This is ridiculous. I never said that my comments would "settle" the debate, although I don't see what's so hard to understand about those dyno curves.
    My work fleet includes an 06 CTS-V and Z06. As part of my JOB, I've driven both on the street and track. I recently sold my 2008 Corvette, and I've put many miles on several other CTS-V's and Corvettes, as well as a couple different GTO's and TBSS.
    No, I don't own and CTS-V, but that just means I don't have a built-in bias intent on defending my own purchase. Unlike someone who owns one or the other, I've spent about equal time in both. That means I'm not more "used to" one or the other, which can again cloud judgment. Each car I've driven has been bone stock and well maintained.
    It's no surprise that all the LS6 owners are so quick to discredit my opinions, but I don't see anyone coming on here with any better advice or unbiased opinions for the OP.
    I will acknowledge that the LS6 has lower compression, which will tolerate boost a bit better. That might be a consideration for some people. There is a chance I'll supercharge mine at some point, but I'm still going with the LS2.
  5. #49
    VfReaK is offline Banned
    Automobile(s): CTS-V
    Aug 2009
    25
    "I will acknowledge that the LS6 has lower compression, which will tolerate boost a bit better. That might be a consideration for some people. There is a chance I'll supercharge mine at some point, but I'm still going with the LS2."
    there are many ls2's that support and perform much better than
    the ls6 is this department as well. 7psi vs 7psi in either of these stock motors,
    and the outcome will be just as one sided as this ridiculous debate,... the bigger motor with bigger lungs will generate more horse power every single time. the ls2's higher compression ratio at these boost levels will also make more power FYI.
    the ls6 is out dated, it's like arguing the the ls1's superiority over the lt1.
    when it made it's debut, now no one even give either an honorable mention. no one and i mean no one uses a ls6 for high horse power application.
    they ALL use forged :cough: ls2's
    ls2 ftw... AGAIN!
  6. #50
    She-V's Avatar
    She-V is offline Cadillac Owners Member
    Automobile(s): '07 CTS-V Black Raven
    Aug 2009
    Eastern NC
    52
    35
    Rock on!
    So we've come to the concluson that Black Raven V's sporting LS2's RULE!
    I'm in!
  7. #51
    CTS-Voodoo's Avatar
    CTS-Voodoo is offline Cadillac Owners Enthusiast
    Automobile(s): 05 Raven V
    Oct 2008
    AutoRepairSEO.com
    951
    Quote Originally Posted by VfReaK View Post
    ls2 ftw... AGAIN!
    I like the LQ9 better. Iron block LS2s hold more power.
  8. #52
    ctsv154's Avatar
    ctsv154 is offline Cadillac Owners Connoisseur
    Automobile(s): 04 CTS-V with a little hp persuasion device
    Oct 2007
    32
    3,824
    You do realize that the LS2 is basically the same engine with a bigger bore? If you want to talk about being out dated, both engine are out dated. Both run the exact same outdated cathedral port head, both engines have the same stroke, one just has a bigger bore. There is nothing new or exciting about either engine. All of the LS motors today stem from the LS1/6 as they carry the same architecture with the only differance being stroke or bore and now with the LS3 and new engines, the square port head.
    Now obviously the LS2 will a have slight lower end advantage becasue of this bigger bore, but being that GM decide not to install a hotter cam and light weight valves in the LS2, the engines perform almost the same. If GM would have done to the LS2 what they did to the the LS6, then maybe you would have an argument. But they didn't and they let an enigne with smaller displacement have the same amount of hp with only 5 less foot pounds of torque. I dont think thats to bad myself.
  9. #53
    thebigjimsho's Avatar
    Automobile(s): ZIP
    In the barrel of a gun...
    51,885
    ls2 ftw... AGAIN!
    Finished ricing out your V yet? Mike Rice...
  10. #54
    The Tony Show's Avatar
    The Tony Show is offline See you in the funny papers
    Automobile(s): 04 CTS-V, 05 STS, 07 SRX- All sold :(
    Dec 2004
    The Internet
    26,239
    This thread is dancing on the edge of being closed, people. Why can we not talk LS6 vs LS2 without everyone getting all pissy and nasty with each other? Seriously.....
    Rest in Peace, J.D. (aka Dirt_Cheap_Fleetwood)
  11. #55
    SkullV's Avatar
    SkullV is offline Cadillac Owners Connoisseur
    Automobile(s): NONE
    Mar 2007
    Downtown Chicago
    3,844
    Quote Originally Posted by The Tony Show View Post
    Because the mod's haven't banned MikeNice AGAIN yet....
  12. #56
    onebadcad's Avatar
    onebadcad is offline Cadillac Owners Connoisseur
    Automobile(s): '09 V BR 4dr 6spd,'05 C6R 1400+HP, '05 V BEST EVA!!
    Aug 2004
    Mod Hell
    2,660
    I changed my mind since yesterday:
    LS3>LS2/LS6, of course we all want the yet-to-be-announced LS5
  13. #57
    onebadcad's Avatar
    Aug 2004
    Mod Hell
    2,660
    Quote Originally Posted by SkullV View Post
    Is he on here, if so, we are now on par with LS1Tech regarding turbo experts,,,
  14. #58
    onebadcad's Avatar
    Aug 2004
    Mod Hell
    2,660
    Damn, I am on a roll, posted new thread yesterday for first time in three years and it gets closed like in an hour. Jump into this thread for first time yesterday and it, too, is heading that route. I should play the Reverse Lottery Game.
  15. #59
    AAIIIC's Avatar
    Automobile(s): '05 CTS-V
    Aug 2007
    Where the Navy takes me...
    6,224
    It's no surprise that all the LS6 owners are so quick to discredit my opinions...
    Hey now, let's not go lumping everyone together. I'm an LS6 owner, and specifically said the bigger displacement gives the LS2 the better low end and mid range torque.
    http://www.euroteknik.com/forum/gene...-ls6-dyno.html
    Here's a link discussing the dyno chart that GM provided when the C6 was introduced. According to this chart, the peak power/torque numbers don't even begin to tell the story.
    There's nothing to argue in that graph, but it does strike me as the classic case of what one of my MechE profs told us many moons ago - "Figures don't lie, but liars figure." Chevy (or whoever generated that graph) scaled the torque axis in a way to exaggerate the torque advantage of the LS2 over the LS6. Note that the HP axis scaled starting at 0, as a graph is supposed to be scaled. The torque axis starts at 250, which serves to drive home the point of their advertisement that much more effectively. If they had scaled the torque axis from 0-450, as a graph should be scale, it wouldn't look nearly as impressive. A very common tactic in advertising. But I digress ...
    I'd love to be able to do a same day dyno comparison, but the only other V I ever see around here is my twin (same year, same color) that's a few doors down from me.
    '05 Stealth Grey CTS-V, 19x8.5/10" CCW T140s with Toyo Proxes T1 Sports (summer), black Team Dynamics ProRace 1.2 wheels with 275/35-18 R-compounds (track), Hyperblack Rota Torques (winter), KW Variant3s, V2 front brakes, Hotchkis rear sway bar, EPS cam, TEA-ported 243 heads, FAST92 intake w/LS2 TB, JBA Camaro/G8 1-3/4" shorty headers w/JBA cat pipes, Corsa exhaust, UUC motor and tranny mounts, UUC shifter, MAPerformance trailing arms, Specter cradle bushings, etc...
  16. #60
    JimmyH is offline Cadillac Owners 10000+ Posts
    Dec 2006
    42
    37,302
    your questions would be better answered on ls1tech.com
  17. Remove Advertisements
