Page 2 of 4 FirstFirst 1234 LastLast
Results 16 to 30 of 60
Thread: LS6 vs. LS2...Yes, I did a search.
  1. #16
    CTS-Voodoo's Avatar
    CTS-Voodoo is offline Cadillac Owners Enthusiast
    Automobile(s): 05 Raven V
    Oct 2008
    AutoRepairSEO.com
    951
    Re: LS6 vs. LS2...Yes, I did a search.
    they wont pull any differently.
    stock LS6 output 400/405
    stock LS2 output 405/410
    5 horsepower can be overcome by the wind.
  2. #17
    deedubb's Avatar
    deedubb is offline Cadillac Owners Connoisseur
    Automobile(s): E85 Powered - Maggie'd V
    Feb 2005
    Mile High
    37
    1,747
    Quote Originally Posted by CTS-Voodoo View Post
    Or a big breakfast!
  3. #18
    ctsv154's Avatar
    ctsv154 is offline Cadillac Owners Connoisseur
    Automobile(s): 04 CTS-V with a little hp persuasion device
    Oct 2007
    32
    3,824
    Quote Originally Posted by Tom400CFI View Post
    Thanks for the good replies. I should have been more clear. I know all of the technical differences both for the car and the engine itself; I've had a C6/LS2 for the last 3-1/2 years.
    What I was wondering, is which engine, in this virtually same chassis, has produced the best ET and TRAP results, bone stock?
    Once you change blocks, heads, cams, add blowers, etc....it's not really an "LS6" or an "LS2" anymore. I'm talking stock for stock, same platform. See? In the 'Vettes, the LS6/LS2 debate was always plagued by the fact that the two motors were never in the same chassis.
    Well the problem is neither LS6 or the LS2 can be pushed at the track because the rear end. I personaly dont think you would see much differance even if you could do a 6k drag radialed launch. The fact is the rear end in this car keeps people from seeing its true potental.
  4. #19
    bpitas's Avatar
    bpitas is offline Cadillac Owners Fanatic
    Automobile(s): Cadillac CTS-V
    May 2007
    Winchester, MA
    46
    389
    If all you're interested are the dragstrip times of the two motors (since the chassis is the same) go over to dragtimes.com (http://www.dragtimes.com/Cadillac--C...ag-Racing.html) and go through each of them and check if they are stock or not.
    Like everyone else said, though, it's hard to tell how fast it really is because the rear-end hops so bad.
  5. #20
    AAIIIC's Avatar
    AAIIIC is online now Super Moderator
    Automobile(s): '05 CTS-V
    Aug 2007
    Where the Navy takes me...
    6,463
    AFAIK they were both rated the same from the factory - 400hp and 395ft-lb. Not sure where your numbers are coming from, and maybe the numbers I'm finding online now aren't correct. The one difference is that the LS6's peak torque was 4800rpm, while the LS2's was 4400rpm - there's that extra displacement letting the LS2 make the same torque earlier in the RPM band.
  6. #21
    thebigjimsho's Avatar
    Automobile(s): ZIP
    In the barrel of a gun...
    51,885
    Quote Originally Posted by deedubb View Post
    Or a big breakfast!
    Or a blocked colon!
  7. #22
    Automobile(s): ZIP
    51,885
    Neither. If there were any difference, it would be so miniscule, it wouldn't matter.
  8. #23
    Automobile(s): ZIP
    51,885
    Quote Originally Posted by JimmyH View Post
    i love the hard pull to redline that the LS6 gives you.
    but admittedly, the LS2 is probably the better engine. particularly in everyday driving. where (whether we want to admit it or not) is where the CTS-V spends most of its time.
    Do you drive some sort of one-off automatic V? Shift...
  9. #24
    darkman's Avatar
    Automobile(s): 2005 CTS-V
    Nov 2005
    Spring, Texas
    8,208
    Quote Originally Posted by thebigjimsho View Post
    Or a blocked colon!
    Thank you for sharing that thought.
  10. #25
    JimmyH is offline Cadillac Owners 10000+ Posts
    Dec 2006
    42
    37,299
    yes...my left leg and right arm
  11. #26
    VfReaK is offline Banned
    Automobile(s): CTS-V
    Aug 2009
    25
    one can not dispute bigger is ALWAYS better.
    Bigger gun, Bigger dong, Bigger house, Bigger wallet, Bigger t*ts,
    now that that's cleared up,... it's clear you need a... BIGGER MOTOR!
    go BIG, or go home.
  12. #27
    ctsv154's Avatar
    Oct 2007
    32
    3,824
    The bigger they are, the harder they fall!
  13. #28
    madmaro00 is offline Cadillac Owners Member
    Jun 2009
    15
    For me it was the exclusivity of the LS6, be that as it may, more cubes never hurt anybody. Both are awesome motors with tons of potential, where as our rear ends are another story.
  14. #29
    CTS-Voodoo's Avatar
    Oct 2008
    AutoRepairSEO.com
    951
    Quote Originally Posted by AAIIIC View Post
    Every dynoed LS engine Ive ever seen has made more at the crank than the factory ratings stock. Perhaps GM wanted to ensure no false claims were made on its engines.
  15. #30
    darkman's Avatar
    Nov 2005
    Spring, Texas
    8,208
    This suggests that our drive line loss percentage, which we've always considered to be awful. is even worse than we thought.
  • You may not post replies
