H&R Lowered Pics
Page 1 of 2 12 LastLast
Results 1 to 15 of 18
2004-2007 Cadillac CTS-V Performance Mods Discussion, H&R Lowered Pics in Cadillac CTS-V Series Forum - 2004 - 2007; Here is some pics of an H&R setup. The front is about as low as you can go without problems ...
    crankedupforit's Avatar
    crankedupforit is offline Cadillac Owners Connoisseur
    Automobile(s): 05 CTS V 07 ESCALADE
    Feb 2007
    Cheese land
    1,596
    H&R Lowered Pics
    Here is some pics of an H&R setup. The front is about as low as you can go without problems I think. The car ran fine at the track with no rubbing or interference. Notice the shot of the front wheel well.
    Mike
    maxspeed96ct is offline Cadillac Owners Connoisseur
    Automobile(s): 05 CTS-V
    Aug 2009
    31
    1,048
    Re: H&R Lowered Pics
    damm that looks perfect. I think im going to drop my v one day...
    what struts are you running and what did you use for strut spacers?
    Feb 2007
    Cheese land
    1,596
    Quote Originally Posted by maxspeed96ct View Post
    I'm running the FG2s with forum member RC531s spacers. There are other spacer options for the rear but his worked out great with the H&Rs. You could do a search and find out tons of stuff on spacers.
    jerrycecco is offline Cadillac Owners Fanatic
    Automobile(s): CTS-V
    Jun 2005
    TX
    469
    thanks for posting the pictures of the car....
    Q: What size rubber you running?
    ...I wonder if my 265 will rub on H&R....
    Q: What's your guess the spring rate is? I heard H&R doesn't not publish...
    Do you bottom out at all? scrap any speed bumps etc...
    I'm in the processing of comparing H&R (which many V owners have) to Vogtland Springs @ 600lbs (hearsay) which no V owners have (yet)
    jerrycecco@tx.rr.com
    Feb 2007
    Cheese land
    1,596
    Quote Originally Posted by jerrycecco View Post
    The H&Rs claim to be 30% stiffer than stock which would put them at maybe the mid 500s. They are firm, make no mistake, the car will ride quite differently. With FE4s it may ride a little better. Potholes are hard hits now. With a Hotchkiss bar and FG2s the car will not roll very much at all. H&Rs are a real value if you shop around. The spacers are from a guy named 2003RC51 on the forum. These springs are just about the perfect height. My car is within 3/16 of an inch consistent ride height on the fronts and backs. They haven't rubbed the tires at all and don't squeek or clunk so far. I would still be careful going down driveways anyway. This is where you can pop a swaybar endlink on a lowered car as well. The 265s may rub if you take a big hit on the suspension. My stock Run Flats just make it. Infact I don't know if anyone with big tires in back has been able to solve the rub issue unless they increase the spring rate so much that the rear end no longer travels much. That or roll the fender lip to increase clearance. GCs are a great choice as well but since I don't need to adjust the ride height, I think the quality German made H&Rs are a good choice. Good luck with your mods.
    silver02stang's Avatar
    silver02stang is offline Cadillac Owners Enthusiast
    Automobile(s): LS6 CTS-V
    Oct 2008
    Appleton, WI
    40
    548
    Quote Originally Posted by crankedupforit View Post
    Mike
    whew. she looks a bit lower than other V's with H&R's I've seen. they almost look like Eibachs
    deedubb's Avatar
    deedubb is offline Cadillac Owners Connoisseur
    Automobile(s): E85 Powered - Maggie'd V
    Feb 2005
    Mile High
    37
    1,747
    Lookin great!
    Jun 2005
    TX
    469
    thanks for the comemnts about H&R clearances
    this is what my car looks like now on stock height with 265's
    I can fit three fingers in the space in between rear tires and top of fendor and two fingers on the front tires
    LUVMY04V's Avatar
    LUVMY04V is offline Cadillac Owners Master
    Automobile(s): 04 cadillac cts v
    Feb 2006
    Dekalb IL
    36
    5,585
    Looks just like my stance Perfect! Love my H&R's too. I have only heard of one person Ever that didn't like them
    Jun 2005
    TX
    469
    Here's pictures I rec'd from Katech this AM:
    H&R Springs with QA1 shocks, dont know the tire sizes
    Stance and height looks good for me....
    LUVMY04V's Avatar
    Feb 2006
    Dekalb IL
    36
    5,585
    soooooooooo HOT!!!!!!!
    Jun 2005
    TX
    469
    just reec'd more data from Katech:
    rims:19x9 F/R tires: 245/40R19 & 275/35R19
    now I need to calculate and compare heights and widths to my 265's
    --Jerry
    Feb 2007
    Cheese land
    1,596
    Quote Originally Posted by LUVMY04V View Post
    I actually got the idea for H&R from you. Your pics seemed to be the perfect height. Mine looks just like yours.
  16. #14
    Feb 2007
    Cheese land
    1,596
    --Jerry
    Jerry let me know how this works out. I'd be interested in knowing who makes those wheels as well.
  17. #15
    whisler151's Avatar
    whisler151 is offline Cadillac Owners Connoisseur
    Automobile(s): 2012 CTS-V Sedan, 2011 CTS Coupe, 2010 Ford Raptor
    Apr 2007
    Dallas, TX
    3,547
    They are the CCW SP600.
  18. Remove Advertisements
