Hendrix Engineering = QUALITY clutch/flywheel combo - Page 3
Page 3 of 5 FirstFirst 1 2 3 4 5 LastLast
Results 31 to 45 of 72
2004-2007 Cadillac CTS-V Performance Mods Discussion, Hendrix Engineering = QUALITY clutch/flywheel combo in Cadillac CTS-V Series Forum - 2004 - 2007; Originally Posted by Hendrix-Engineering No i only can bench 505 ..I was do tricep push downs and had 450lbs of ...
  1. #31
    jpoole's Avatar
    jpoole is offline Cadillac Owners Fanatic
    Automobile(s): 2010 Cadillac CTS-V
    May 2007
    McKinney, Texas
    266
    SmileRe: Hendrix Engineering = QUALITY clutch/flywheel combo
    Quote Originally Posted by Hendrix-Engineering View Post
    No i only can bench 505..I was do tricep push downs and had 450lbs of free weight plus my 250lbs in the air ind pulled a back muscle pretty bad,first time ive ever had a injury,guess im getting old lol
    I think there should be a vender rule, you can only offer clutch setups that match what you can bench...
    Now, go bend up some more axles, I assume by hand you strong ass SOB.
  2. #32
    deedubb's Avatar
    deedubb is offline Cadillac Owners Connoisseur
    Automobile(s): E85 Powered - Maggie'd V
    Feb 2005
    Mile High
    37
    1,747
    You guys are doing it wrong. More muscle = more weight = slower track/drag times.
  3. #33
    CTS-Voodoo's Avatar
    CTS-Voodoo is offline Cadillac Owners Enthusiast
    Automobile(s): 05 Raven V
    Oct 2008
    AutoRepairSEO.com
    951
    Quote Originally Posted by deedubb View Post
    No kidding!
  5. #34
    SoJersey05V is offline Banned
    Automobile(s): 05 CTS-V
    Jul 2008
    south jersey
    889
    any word on this thing yet? have you had the chance to see if it works? just curious...
  6. #35
    CTS-Voodoo's Avatar
    Oct 2008
    AutoRepairSEO.com
    951
    Quote Originally Posted by SoJersey05V View Post
    Car goes under the knife at Excelsior for what I am starting to jokingly call the "first makeover" on wednesday. It will be getting the Texas Speed 233/239 112 cam and all associated top end valve train parts. I am retaining the stock heads for now (unless Kushan convinces me to get his massively ported LS6 heads lol) the lightened (15lb steel) flywheel and clutch go in at the same time. As are the rear 10 inch stock rims with 295s and new black slotted and drilled rotors with EBC Yellows.
    Should be a real different car when I get it back.
  7. #36
    liqidvenom is offline Cadillac Owners Connoisseur
    Automobile(s): cts-v
    Feb 2009
    Long Beach Ca
    35
    2,741
    I thought in the other post you said that you had someone who tried this setup and it didn't work...so what are you curious about?
  8. #37
    Jul 2008
    south jersey
    889
    Quote Originally Posted by liqidvenom View Post
    well from what the pics showed it was a different PP and he never got to put it in because it never lined up... maybe this one is different (even tho tom said it wasnt, but the pics clearly showed it was)... just wondering if it would actually bolt up and hold up to power, stock power at that... hence "just curious"
  9. #38
    CTS-Voodoo's Avatar
    Oct 2008
    AutoRepairSEO.com
    951
    There is no question in my mind that everything will work fine.
  10. #39
    Jul 2008
    south jersey
    889
    well good luck then
  11. #40
    nmaier2201's Avatar
    nmaier2201 is offline Cadillac Owners Connoisseur
    Automobile(s): 2006 CTS-V
    Aug 2007
    Chicago, IL
    1,415
    good luck. Let us know how it goes. How you taking pics and doing a write up if someone else is doing the install?
  12. #41
    CTS-Voodoo's Avatar
    Oct 2008
    AutoRepairSEO.com
    951
    Quote Originally Posted by nmaier2201 View Post
    Cause I am one a hell of an internet marketing specialist, and I spend time with my clients writing up content for their websites.
  13. #42
    darkman's Avatar
    Automobile(s): 2005 CTS-V
    Nov 2005
    Spring, Texas
    8,180
    Quote Originally Posted by CTS-Voodoo View Post
    Well, I think the intended and pertinent inquiry is whether you will actually witness the install about which you will be writing.
  14. #43
    CTS-Voodoo's Avatar
    Oct 2008
    AutoRepairSEO.com
    951
    Quote Originally Posted by darkman View Post
    lol I know, I was messing about. Ill try to be more serious next time when talking about mod hell. I will be witnessing most of it, but I think Kushan (shop owner) will be the one writing the article as well as taking pics, then I perform the Voodoo..
  15. #44
    darkman's Avatar
    Nov 2005
    Spring, Texas
    8,180
    Well to cut to the chase - the write-up, no matter who writes it, must reveal the type and source of all of the components used (in additon to those supplied dirctly by Hendrix-Engineering) to assemble the thing. Otherwise, the do-it-yourself readers will not be able to replicate the install and the result will be NO incremental sales for Hendrix-Engineering, which presumably is the purpose of this exercise.
  16. #45
    nmaier2201's Avatar
    Aug 2007
    Chicago, IL
    1,415
    Ditto to Darkman.
    Thanks again Voodoo for the upcoming write-up, and for the explanation
  17. Remove Advertisements
