Engine Idle Question
Results 1 to 8 of 8
2004-2007 Cadillac CTS-V Performance Mods Discussion, Engine Idle Question in Cadillac CTS-V Series Forum - 2004 - 2007; I am just trying to find out if this is "normal" behavior which could be attributed to the heavy flywheel ...
    Caditude's Avatar
    Caditude is offline Cadillac Owners Member
    Automobile(s): 2005 Platinum Cadillac CTS-V
    Mar 2007
    Jacksonville, FL
    75
    I am just trying to find out if this is "normal" behavior which could be attributed to the heavy flywheel in our cars. Here is my issue. Car idles fine (except for some shaking due to broken motor mounts). When I am slowing down and the engine is returning to idle (out of gear) it tries to go 100 or 200 rpm below where it usually idles, at 700 rpm, and then returns to the 700 rpm idle. It did this before and after I installed a W4M tuned PCM.
    Is this normal?
    Is this something I could have W4M fix with the tune?
    Thanks for any info!
    nmaier2201's Avatar
    nmaier2201 is offline Cadillac Owners Connoisseur
    Automobile(s): 2006 CTS-V
    Aug 2007
    Chicago, IL
    1,415
    Re: Engine Idle Question
    You got to push the clutch pedal in a little faster... no waiting till the 4000lb monster almost kills the engine. j/k ( i know I know you said it was out of gear... but I laughed at myself anyways)
    The only think I can add is my car does not do that.
    lollygagger8's Avatar
    lollygagger8 is offline Cadillac Owners Connoisseur
    Automobile(s): Platinum 2004 CTS-V
    Apr 2008
    Indiana
    4,913
    Not normal.....is your car throwing any codes?
    Your throttle body position sensor might be shot? <- guessing
    Caditude's Avatar
    Mar 2007
    Jacksonville, FL
    75
    No codes. I am bringing it in for motor mounts soon and will have them check this out as well.
    Apr 2008
    Indiana
    4,913
    If it did it before and after the tune, I would definitely look at the throttle body. Sounds like the sensor/motor is bad that opens/closes the blade.
    Caditude's Avatar
    Mar 2007
    Jacksonville, FL
    75
    Bringing this back up.
    I had the mounts installed (Under Extended Warranty ) Shake is gone.
    Dealer checked out the low idle situation and gave me the proverbial "Unable to duplicate customer concern".
    I cleaned the throttle body and seafoamed the engine, but the problem still persists.
    I have an Aeroforce gauge in the car and it is showing a Throttle Percent of 4 when my foot is completely off the gas pedal. Does this sound normal?
    It almost seems like a vaccum leak although I havent been able to find one.
    Any ideas?
    ichpen's Avatar
    ichpen is offline Cadillac Owners Connoisseur
    May 2008
    Toronto, Ontario, Canada
    1,383
    Have you tried the idle relearn procedure in the FAQ? Maybe the TPS lost idle.
    Caditude's Avatar
    Mar 2007
    Jacksonville, FL
    75
    Performed the Idle Relearn procedure from the FAQ yesterday. It seems to have helped some, but not totally.
    Any other ideas?
  11. Remove Advertisements
