Clutch Questions? Enter. - Page 9
Page 9 of 9 FirstFirst 1 2 3 4 5 6 7 8 9
Results 121 to 131 of 131
2004-2007 Cadillac CTS-V Performance Mods Discussion, Clutch Questions? Enter. in Cadillac CTS-V Series Forum - 2004 - 2007; I swear I just posted a response. Now the last 2 posts are gone? Is my iPhone on crack? Maybe ...
  1. #121
    whisler151's Avatar
    whisler151 is offline Cadillac Owners Connoisseur
    Automobile(s): 2012 CTS-V Sedan, 2011 CTS Coupe, 2010 Ford Raptor
    Apr 2007
    Dallas, TX
    3,547
    Re: Clutch Questions? Enter.
    I swear I just posted a response. Now the last 2 posts are gone? Is my iPhone on crack? Maybe a mod can pm me if there are problems?
  2. #122
    darkman's Avatar
    Automobile(s): 2005 CTS-V
    Nov 2005
    Spring, Texas
    8,161
    I think some posts have been deliberately deleted from this thread. Perhaps your posts got caught up in the "flush."
  3. #123
    whisler151's Avatar
    Apr 2007
    Dallas, TX
    3,547
    Quote Originally Posted by darkman View Post
    Oh well, on with the clutch questions!
  5. #124
    SoJersey05V is offline Banned
    Automobile(s): 05 CTS-V
    Jul 2008
    south jersey
    889
    Yes i agree back to the clutch questions!!!!!!
  6. #125
    maxspeed96ct is offline Cadillac Owners Connoisseur
    Aug 2009
    31
    1,048
    any cons to getting aluminum flywheel on the V?
    I know the 15lb aluminum will be alittle better for performance. But will it give me alot of chatter and be hard to drive ?
    The CTS-v weights ~4000lbs with me in it, I just want to make sure the aluminum flywheel can handle it and be manageable to drive with ..
  7. #126
    darkman's Avatar
    Nov 2005
    Spring, Texas
    8,161
    Quote Originally Posted by maxspeed96ct View Post
    There are many previous threads that cover this because the UUC lightwheel flywheel for these cars has been available for a number of years.
    Briefly summarized the lightweight flywheel works in these cars and does not present driveabilty problems. I have one and love it. The fact that these cars weigh 4,000 lbs. is not a problem because: (1) even though their torque curves differ both the LS2 and LS6 motors have ample low end torque; and (2) the transmission is a close-ratio unit such that the drop in rpm from any particular gear change is not dramatic.
    Having said this the lightweight flywheel does result in some gear noise if the the engine is "lugged". For example, if you arrive in 6th gear below 35 mph and then try to accelerate you will hear what sounds like "pinging" not from the motor but from the transmission.
    Finally, if you spend an hour a day in stop-and-go, 1st and 2nd gear trafffic you may be happier with something a little heavier. The 28 lb. level would have some appeal in that application.
    Given the subjective nature of these conclusions you really should search those earlier threads to get a variety of opinions.
  8. #127
    Aug 2009
    31
    1,048
    sooo whens the gorup buy ?
  9. #128
    nmaier2201's Avatar
    nmaier2201 is offline Cadillac Owners Connoisseur
    Automobile(s): 2006 CTS-V
    Aug 2007
    Chicago, IL
    1,415
    Quote Originally Posted by rlj5 View Post
    Steve, Don't really need a clutch right now, But something tells me that if & when I get this thing to hook the spec 3+ is not gonna get it done. So what do you have in my power level ?, understanding that if I can get the traction figured out someday I'll probably put the larger crank pulley on, up the boost to maybe 18 psi & probably be around 1,000 hp at the wheels
    I would be so pumped if I had the ability to make a statement like that. ....but I can't....and more than likely I never ever will
  10. #129
    nmaier2201's Avatar
    Aug 2007
    Chicago, IL
    1,415
    Darn right. That's exactly why I got the ~25lb LS7 flywheel... I'm in 2hrs of stop and go on a bad day..... and I'm happy from a dead start that I have those extra ~10lbs...
    and I'm also thankful I can slip the clutch... just my .02
  11. #130
    Frans96SS is offline Cadillac Owners Member
    Mar 2004
    27
    Quote Originally Posted by Twitch View Post
    You want 90hp out of a cam and headers? Not on RPMs dyno. PM Randy for his guys info
    Not a lot of questions being answered here. But I assume the level 3 would be too "grabby" for a DD.
    I still wanna know why the 2 and 2.5 are described the same, and if I can get just the flywheel as a "bolt-on" kit.
    Tony
    Are you saying my Dyno reads low or something?
  12. #131
    Jul 2008
    south jersey
    889
    /\/\ lol thats what it sounded like to me lol!!!! i gotta get in there for some damn work!
  13. Remove Advertisements
