Go Back   Cadillac Owners Group > Current Cadillac Vehicle Discussion > Cadillac V-Series Forums > Cadillac CTS-V Series Forum - 2004 - 2007 > 2004-2007 Cadillac CTS-V Performance Mods
2004-2007 Cadillac CTS-V Performance Mods Discuss all Cadillac CTS-V performance modifications here. Engine tunes, exhaust, intake, suspension and more.
Cadillac Forums: Diff temperature monitoring in stock instrument cluster
Old 08-18-09, 06:35 PM
Cadillac Owners Enthusiast
Cadillac(s): '05 CTS-V
View AAIIIC's Photo Album
Casino Cash: $10330
I vaguely recall reading that someone (one of the other track day freaks, I think) was setting up their car to monitor the rear diff temp in addition to the tranny temp. Obviously one would need to use a switch to display one or the other in the dash cluster. Just wondering if anyone has successfully implemented this, and if so, were there any tricks to doing it?
Just finished doing 3 track days in the last 5 days and the rear diff is not too happy - noticeably louder/whinier than before, and with some low speed howling type noise that I've never heard before. (With that said, I do have the lower seat cushion out, so I may be hearing noises that were always there and I just didn't know it.) Fluid is relatively new Amsoil. I'll be doing the fluid again here in a few days and I'm curious to see what condition the stuff that comes out will be in. I have a feeling a diff cooler is in my future if I'm going to continue to track this car.
'05 Stealth Grey CTS-V, GM Accessory wheels w/Falken FK452s, Hyperblack Rota Torques w/Bridgestone RE-01Rs, KW Variant3s, Magnaflow exhaust, UUC shifter (not worth the trouble), Specter cradle bushings (somewhat useful), BMR pinion brace, and more to come I'm sure...
  #2 (permalink)
Old 08-18-09, 06:55 PM
ctsv154's Avatar
Cadillac(s): 04 CTS-V with a little hp persuasion device
View ctsv154's Photo Album
Casino Cash: $15512
Re: Diff temperature monitoring in stock instrument cluster
I think naf was working on this if I'm not mistaken.
04 Raven CTS-V / Forged and maggied LS6 / 90mm TB / 8 rib pulleys / 8" overdrive balancer with 2.7" blower pulley / LG G5X1 / Crane 1.8 gold rollers / 1 7/8 Kooks / ARP hardware throughout / Melling oil pump / Cloyes double roller / Volant CAI / Fidanza LS7 flywheel / Spec Stage 3 / Ground Control / QA1's / RC51 motor mounts / UUC diff, and shifter bushings / UUC Vknob / Katech STS / Rear strut bar / Kars III
  #3 (permalink)
Old 08-18-09, 07:26 PM
darkman's Avatar
Cadillac(s): 2005 CTS-V
View darkman's Photo Album
Casino Cash: $12594
Our transmission drain plug is the sensor. I wonder if the threads are the same as either of the differential access holes.
(I thought Naf had a GMPP differential cooler setup.)
  #4 (permalink)
Old 08-18-09, 07:47 PM
The Tony Show's Avatar
How YOU doin?
Cadillac(s): 2007 SRX (Previously 04 CTS-V)
View The Tony Show's Photo Album
Casino Cash: $18595
If the threads are the same, then it's a cakewalk. Order an extra sensor, install in diff and wire them together with a switch.
It can't be that easy though. Can it?
  #5 (permalink)
Old 08-18-09, 07:50 PM
darkman's Avatar
Casino Cash: $12594
Maybe. Worst case would just involve some sort of thread adaptor.
  #6 (permalink)
Old 08-18-09, 11:07 PM
Casino Cash: $10330
That's one big question, one that I was hoping someone might have already figured out. That way I don't have to drain the tranmission just to find out myself.
The other question I have is how the sending unit works, and how the switch would need to be wired. I would assume that the sending unit is just a positive and a ground, and thus I could just switch the positive/signal, but I'm not sure.
  #7 (permalink)
Old 08-18-09, 11:17 PM
darkman's Avatar
Casino Cash: $12594
Call Luke or go to your local Cadillac parts guy and have them pull the two parts and look at them.
I'll bet Heavy can tell you how to wire it.
  #8 (permalink)
Old 08-20-09, 10:27 AM
lollygagger8's Avatar
Drive It. Break It. Build it Better
Cadillac(s): Platinum 2004 CTS-V
View lollygagger8's Photo Album
Casino Cash: $7808
Did Luke or anyone else ever check this out? I'm interested
Monster Stage 3 Clutch & 18 lb flywheel, B&B headers w/ hi flow cats, B&B xpipe & catback, Lingenfelter CAI, UUC Gen II Motor Mounts/Trans Mount/Shifter/Diff Bushing, Hotchkis Sways, BMR Trailing Arms & AWH Bushings, Hawk Pads, GM Assy Wheels, Stock Wheels, Drilled GM Rotors, Hendrix Axles, CAGS Elim, '06 Diff, Clear Fogs/Sidemarkers, Tuned by Brent @ EPP on mustang dyno @ 378rwhp/366tq
Tags: , , , , ,
cluster, diff, instrument, monitoring, stock, temperature
Censor is OFF
