How to lower rears even more
Results 1 to 11 of 11
2004-2007 Cadillac CTS-V Performance Mods Discussion, How to lower rears even more in Cadillac CTS-V Series Forum - 2004 - 2007; I just lowered my V with Eibachs and RC1s spacers. the front sits just as I want, but I think ...
    supergeess is online now Cadillac Owners Fanatic
    Automobile(s): none
    Jul 2008
    Los Angeles
    129
    I just lowered my V with Eibachs and RC1s spacers. the front sits just as I want, but I think the rear is still a bit high. The rear is lower than stock , but I think another 1/2" or 1" would ber perfect. Any suggestions? I know the answer is probably in this forum somewhere, but I searched and couldn't find the answer.
    CadiBlk's Avatar
    CadiBlk is offline Cadillac Owners Connoisseur
    Automobile(s): Silver '05 V
    Jun 2007
    Atlanta
    1,238
    Re: How to lower rears even more
    search for MightyMouse
    He is a member here and he did a mod that relocates the upper shock mount. That is your ticket.
    Automobile(s): none
    Jul 2008
    Los Angeles
    129
    Thanks
    shadybx7's Avatar
    shadybx7 is offline Cadillac Owners Connoisseur
    Automobile(s): 2005 Platinum CTS V-Headers+3in pipes
    Apr 2008
    3,014
    IMO MM mod looks pretty ghetto, to me the spacers would make pressure points that over time would weaken the mounting points
    I think you need to upgrade to at least the GC setup so you can lower the rear to you likeing. No real cheap solution and the GC setup from what i hear is mod hell depending how lucky you are. With the you have to pay to play
    Automobile(s): none
    Jul 2008
    Los Angeles
    129
    I thinkg MM mod is a pretty good idea. Good to see people thinking of new and creative things. Without R&D, it is hard to tell what will happen over time, but it is still a great idea. I had read a ton of horror stories about GC and was not sure. Plus, I would probably never raise my car once i lowered it to where i want it. Like I said, the front sits perfect, it's just the rear i would like a bit lower. Even with the rears as they are, it looks good.
    One question I have with GC: wouldn't you still have the same prblem with the rears, since the shocks want to stay at a certain height. I knoe GC come with a rear schock kit, but to m it seems that the same issue would exist. Even if you lower the springs, won't the shocks want to stay at a certain height? Maybe someone could clarify for me.
    CadiBlk's Avatar
    Jun 2007
    Atlanta
    1,238
    As you saw I just recently lowered via Eibach kit. I thought I was going to want the rear to come down more, but I am happy. Maybe after some time the springs will settle a little bit more and might save you the trouble of doing the MM mod. Just a thought, give it a week or two of some driving.
    You could always throw some dead hookers in the trunk to break in the springs.
    Automobile(s): none
    Jul 2008
    Los Angeles
    129
    That's what I was thinking. Hopefully the rears will settle a bit more. I'm just a bit anxous cause i want to get an allignment ASAP. But don't want to get it if I will somehow lower the rear more and then have to pay for another allignment.
    I think I'll just get the allingment soon and wait to see how they settle.
    How long have you had the Eibachs on? Have they settled any lower? Did you the z06 endlinks? What is the purpose for them besides them being obviously stronger and better looking? I'm sure our stocks are strong enough.
    CadiBlk's Avatar
    Jun 2007
    Atlanta
    1,238
    I have only had my springs on for a week, but I bought them used from a forum member that put 500 miles on them. I was not able to get the endlinks on due to my inability to drill through the steel sway bar (a new bit should solve that). I purchased the endlinks due to the lowering of the front suspension, the beefier endlinks will do a better job of holding the control arm to the sway bar. Someone on here will have a better technical description, but that is what I have.
    Also my alignment isn't off anything noticeable. The wheels don't have any lean and the car tracks straight while not holding the steering wheel. I need new tires badly, so I am holding off on the alignment until I get some fresh meets. I am closing on a house, so all spending is frozen, but will get some fresh rubber after the close. Also soon as I have the new garage to work in, I will be getting those endlinks on finally.
    I would hold off a few more days before getting wild and doing the MM mod. If your alignment is off bad, then I would suggest getting an alignment because at the rate our tires run, if you had to get it realigned after doing the MM mod, it would be small change compared to the 1k our tires run.
    SoJersey05V is offline Banned
    Automobile(s): 05 CTS-V
    Jul 2008
    south jersey
    889
    the lowest combo to do is Qa1's with eibachs or h&rs, no gc... you will be almost too damn low... there are pics on here some where... think the thread was " my new suspension setup" because he had that and went to gc because he could adjust it...
    **i have GC and qa1 and have not had a problem... others complain to much!!!
    MIGHTYMOUSE Guest
    haha ghetto.
    no
    any questions i'm happy to answer
    tommy compton's Avatar
    tommy compton is offline Cadillac Owners Connoisseur
    Automobile(s): 06 CTS-V
    Mar 2007
    tha peg
    2,497
    I cut my eibachs and moded my rear shocks, it's kind of a whldwhl spacer mod taken to the next step. Scroll down 1/2 a page for the how to.
    I did this on my Cts and in my V, never any problems or noise.
    http://www.cadillacforums.com/forums...h-springs.html
    Here's how my V sits
    That's with 3/4 of a coil cut off of the rear Eibachs.
  14. Remove Advertisements
