LS7 Clutch - Let's Get the Final Word
Page 1 of 3 1 2 3 LastLast
Results 1 to 15 of 33
Like Tree1Likes
2004-2007 Cadillac CTS-V Performance Mods Discussion, LS7 Clutch - Let's Get the Final Word in Cadillac CTS-V Series Forum - 2004 - 2007; OK, I have read all kinds of threads on this as has everyone. I just wanted to get some final ...
    jpoole's Avatar
    jpoole is offline Cadillac Owners Fanatic
    Automobile(s): 2010 Cadillac CTS-V
    May 2007
    McKinney, Texas
    266
    OK, I have read all kinds of threads on this as has everyone. I just wanted to get some final confirmations before I spend all that money.
    Parts List:
    LS7 Clutch Setup (Clutch and Pressure Plate)
    LS7 Flywheel
    LS7 Slave
    LAPD Bleeder
    Confirm:
    1. With this setup, is it a direct bolt in (notching trans or not and\or spacer)?
    2. What is needed to install the LAPD bleeder (ie positioning, bending, installing, remove bleeder screw etc.)
    3. Do we need throwout bearing for LS7?
    4. Best clutch fluid to use?
    5. Part number for new bolts?
    Thanks, Jeff
    PS. I know this has been covered several times over but the info is very confusing.
    nmaier2201's Avatar
    nmaier2201 is offline Cadillac Owners Connoisseur
    Automobile(s): 2006 CTS-V
    Aug 2007
    Chicago, IL
    1,415
    Re: LS7 Clutch - Let's Get the Final Word
    Parts List:
    LS7 Flywheel
    LS7 Slave
    LAPD Bleeder
    YUP
    Amsoil RBF600
    ARP LS flywheel bolt kit
    Confirm:
    Not exactly the LS7 whip is much longer and requires special routing slave changes from exiting the bellhousing from the top to the side
    you can flip the bleeder screws around and no bending is needed.. but yeah you obviously need to remove the bleeder screw and when you do that it breaks the seal of the quick connect... so 100% must bleed the snot out of it. Position it where you want
    it comes with the LS7 slave..
    Motul RBF600 or any racing dot4
    ARP makes a kit for 20-30 bucks... get it
    darkman's Avatar
    Automobile(s): 2005 CTS-V
    Nov 2005
    Spring, Texas
    8,164
    Pressure Plate Bolt Kit = ARP 134-2201 $19.95 at Summit Racing
    Flex Plate Bolt Kit = ARP 244-2901 $27.95 at Summit Racing
    Flywheel Bolt Kit = ARP 330-2802 $26.95 at Summut Racing
    jpoole's Avatar
    May 2007
    McKinney, Texas
    266
    Thanks guys this is helping. But do i need flex plate bolts?
    Any additional info on the install would be helpful. I would like some instructions on what to tell my installer.
    Thanks, Jeff
    nmaier2201's Avatar
    Aug 2007
    Chicago, IL
    1,415
    out with the old and in with the new and upgraded parts... your in there anyways.. what's 20 bucks at that point....
    liqidvenom is offline Cadillac Owners Connoisseur
    Automobile(s): cts-v
    Feb 2009
    Long Beach Ca
    35
    2,741
    This is the sort of thread which would be useful as a future sticky in the new forum layout...
    That is once a proper write-up as it concerns what might need to be notched, how things get routed, etc...
    heavymetals's Avatar
    heavymetals is offline Cadillac Owners Master
    Automobile(s): 05 maggied CTS-V, 03 maggied Z06
    Nov 2004
    8,787
    I am very close to pulling the trigger on something like this myself.
    Addicted to MOD HELL.
    darkman's Avatar
    Nov 2005
    Spring, Texas
    8,164
    Quote Originally Posted by heavymetals View Post
    Here you go Heavy-
    ctsv154's Avatar
    ctsv154 is offline Cadillac Owners Connoisseur
    Automobile(s): 04 CTS-V with a little hp persuasion device
    Oct 2007
    32
    3,824
    Quote Originally Posted by jpoole View Post
    Thanks, Jeff
    You do not need flex plate bolts. Those bolts would obviously be for an automatic transmission. All you need are pressure plate bolts and flywheel bolts. The stock flywheel bolts are not reusable at all. The pressure plate bolts I dont know but just buy the ARP's. With the LS7 slave, no spacer is needed and you can install the slave in the same position as stock, just becareful of the hard line coming out of the slave. You will have to "adjust" it so make sure you dont kink it. The LAPD bleeder will screw right in the LS7 slave and just snake it out of the old bleeder hole. Everything I just said is done to my car and I did it so I know it works. Any more questions feel free to ask.
    lollygagger8's Avatar
    lollygagger8 is offline Cadillac Owners Connoisseur
    Automobile(s): Platinum 2004 CTS-V
    Apr 2008
    Indiana
    4,913
    Why all the sudden is everybody talking about new bolts? When I did my clutch questions thread, nobody said $hit about that. Come on guys.....I'm about to tear into mine this weekend!
    Feb 2009
    Long Beach Ca
    35
    2,741
    Quote Originally Posted by darkman View Post
    Here you go Heavy-
    Drag multi-clutch setup?
    Quote Originally Posted by ctsv154 View Post
    Thanks this is going to be helpful for me soon. Why do people keep on bringing up the "notching" of the bell housing?
    darkman's Avatar
    Nov 2005
    Spring, Texas
    8,164
    Quote Originally Posted by lollygagger8 View Post
    Why all the sudden is everybody talking about new bolts? When I did my clutch questions thread, nobody said about that. Come on guys.....I'm about to tear into mine this weekend!
    The author of this thread asked for bolt part numbers so I went to my ARP catalog and provided a complete information "dump", including the much needed automatic transmission flex plate bolts.
    darkman's Avatar
    Nov 2005
    Spring, Texas
    8,164
    Quote Originally Posted by liqidvenom View Post
    Yeah, Heavy doesn't do things half way.
  16. #14
    jpoole's Avatar
    May 2007
    McKinney, Texas
    266
    Thanks everyone for the good info. I ordered the ARP flywheel and pressure plate bolt kits.
    I have always changed bolts when replacing a clutch setup. I have always heard that those bolts are designed to stretch some when they get torqued so they should only be used once.
  17. #15
    Nov 2004
    8,787
    Yes I do, just like that bear I only run halfway into the woods......
    By the by, bitchin lookin clutch pack.
  18. Remove Advertisements
