Hendrix Clutch Assembly
Page 1 of 9 123456789 LastLast
Results 1 to 15 of 123
2004-2007 Cadillac CTS-V Performance Mods Discussion, Hendrix Clutch Assembly in Cadillac CTS-V Series Forum - 2004 - 2007; Well my Hendrix Clutch finally came in the mail yesterday. Thomas doesn't mess around when it comes to packing...it was ...
    lollygagger8's Avatar
    lollygagger8 is offline Cadillac Owners Connoisseur
    Automobile(s): Platinum 2004 CTS-V
    Apr 2008
    Indiana
    4,913
    Well my Hendrix Clutch finally came in the mail yesterday. Thomas doesn't mess around when it comes to packing...it was in a wood crate! Nice!
    Couple questions: It didn't come with an alignment tool. Does anyone know if I need a special one, or what the spline count is for it? Where do I get one?
    Also, should I get this balanced? Or will it not make that much of a difference?
    I'm assuming my clutch disc is non-adjustable? I don't see anywhere to make the springs move in/out.
    Here's a couple pics.....
    Flywheel - I don't have a scale yet, but it is LIGHT!!! I'll weigh it before it goes in, but Thomas said it is only 15 lbs.
    Flywheel (other side) - Baby likes it cuz it's shiny
    Clutch (Organic Side)
    Clutch (Ceramic Side)
    Pressure Plate (Front side)
    Pressure Plate (back side)
    My plan is to take off work friday and start working on it......it all depends on the weather!
    EDIT: Sunuva......can a mod fix the Title.....I'm an idiot and didn't spell HeNdrix right. Thanks
    deedubb's Avatar
    deedubb is offline Cadillac Owners Connoisseur
    Automobile(s): E85 Powered - Maggie'd V
    Feb 2005
    Mile High
    37
    1,747
    Re: Hedrix Clutch Assembly
    Nice! Aside from the lightened flywheel, what are the specs on it? HP ratings etc.
    Was it reasonably priced compared to other brands? I can't wait to hear a writeup!
    Apr 2008
    Indiana
    4,913
    Maybe Thomas can get in here and answer those questions......I don't want to say the wrong info.
    nmaier2201's Avatar
    nmaier2201 is offline Cadillac Owners Connoisseur
    Automobile(s): 2006 CTS-V
    Aug 2007
    Chicago, IL
    1,415
    nic pics... that one is not adjustable. There are no stepped adjusting ring tension springs or spring stops..
    I'm not 100% sure on the alignment tool... let me check my service manual.. I think you need it to line everything up...
    PS. make sure your slave has a throwout bearing
    nmaier2201's Avatar
    Aug 2007
    Chicago, IL
    1,415
    Thomas never stated what his clutches were rated for... something about underpromising and overdelivering.... so I'm sure you'll have to pry it out of him if you want him to commit to some numbers.
    My organic/organic is rated at 500HP/TQ so I'm assuming yours with a ceramic side has to be able to beat that HP/TQ number hands down.
    PPS. My 26lb flywheel is really smooth.. I didn't lose any OEM feel by losing 20+lbs, hopefully it'll be the same for you. I did manage to lose some driveline clunk from the dual mass POS... and for that I am extremly grateful.... I'm 100% sure you will be as well
    liqidvenom is offline Cadillac Owners Connoisseur
    Automobile(s): cts-v
    Feb 2009
    Long Beach Ca
    35
    2,741
    The time has come it seems.... i might be buying a clutch and axles from him in one shot if the pricing is right
    darkman's Avatar
    Automobile(s): 2005 CTS-V
    Nov 2005
    Spring, Texas
    8,208
    Service Manual indicates a generic alignment tool.
    ctsv154's Avatar
    ctsv154 is offline Cadillac Owners Connoisseur
    Automobile(s): 04 CTS-V with a little hp persuasion device
    Oct 2007
    32
    3,824
    It should be 26 spline and you can go to autozone or o'rielly's and get one for a camaro, corvette, gto, with a 6 speed. Any LS1/LT1 tool will work. Yes I said LT1. Going back old school.
    Apr 2008
    Indiana
    4,913
    Quote Originally Posted by nmaier2201 View Post
    How much faster are your revs and decels?
    Did you have to relearn how to work your clutch? Or just give it more gas when letting it out?
    Do you find yourself not using 6th gear like most people have said?
    Apr 2008
    Indiana
    4,913
    Quote Originally Posted by ctsv154 View Post
    What's a LT1??
    Thanks Boss!! I really didn't want to sit there and count em out lol.
    I remember Rob saying he used a flywheel tool to hold it while tightening/loosening the bolts.....are those tools easy to find?
    Hendrix-Engineering is offline Cadillac Owners Enthusiast
    Automobile(s): escalade
    May 2009
    571
    First things first,there should have been a line up tool ,i fired myself but had to rehire myself to make the post.You can get one from autozone etc,The clutch is already balanced,if you take it somewhere to get balanced depending on how close there machine is to ours is wether they will say its balanced to them,i wouldnt touch it.As far as rating ,thats to subjective most companys besides us rates in a best case ,as in a 3000 lb corvette,not a 4000 lb ctsv.Also how you drive and how good your car hooks up plays a big roll.I have seen other companies rate this system at 775 hp,i will not rate our clutchs,i talk to the owner ask some questions and send him the clutch that will do the job. Like when you order a tq converter.Thanks for the post ,keep us informed
    May 2009
    571
    Quote Originally Posted by liqidvenom View Post
    When comparing like items were ALWAYS the least expensive
    SoJersey05V is offline Banned
    Automobile(s): 05 CTS-V
    Jul 2008
    south jersey
    889
    Re: Hendrix Clutch Assembly
    looks great! no mod needed to do to anything in the car... just swap it out? what about a remote bleeder? anyway to make one work with this? .. i was thinking ls7 w/ remote but maybe thy this...
  16. #14
    Feb 2009
    Long Beach Ca
    35
    2,741
    Quote Originally Posted by Hendrix-Engineering View Post
    When do you think this setup will be ready for sale? Your axles have been solid on here so i think I will go with a clutch you recommend.
  17. #15
    54inches's Avatar
    54inches is offline Cadillac Owners Fanatic
    Automobile(s): 2005 V
    Sep 2007
    Houston, TEXAS
    42
    474
    Nice looking setup.
  18. Remove Advertisements
