Hendrix Clutch Assembly - Page 7
Page 7 of 9 FirstFirst 1 2 3 4 5 6 7 8 9 LastLast
Results 91 to 105 of 123
2004-2007 Cadillac CTS-V Performance Mods Discussion, Hendrix Clutch Assembly in Cadillac CTS-V Series Forum - 2004 - 2007; LS7 parts Top View Slave Cylinder Width of Base 4 7/8 Height decompressed 4 5/16 Height of Diaphragm shoulder 3 ...
  1. #91
    nmaier2201's Avatar
    nmaier2201 is offline Cadillac Owners Connoisseur
    Automobile(s): 2006 CTS-V
    Aug 2007
    Chicago, IL
    1,415
    Re: Hendrix Clutch Assembly
    LS7 parts Top View
    Slave Cylinder
    Width of Base 4 7/8
    Height of Diaphragm shoulder 3 3/4
    bleeder screw base to master line 2 7/8
    Flywheel
    outer starter teeth side to side 14 1/4
    outer edge to outer edge (no teeth) 13 9/16
    thickness at thickest point (edge) 1 7/16
    flywheel clutch surface area width 2 1/2
    flywheel height to clutch surface 1"
  2. #92
    nmaier2201's Avatar
    Aug 2007
    Chicago, IL
    1,415
    clutch plate
    total width 11.5"
    clutch plate surface area width 2 5/16
    Center spindle height 1 3/4
    flat measurement of clutch plate thickness 3/4 - 1 1/4
    Assembled
    Pic of clutch on flywheel
    Pic of al parts assembled
    flywheel clearance on the side till clutch 3/16
    total height from flywheel mount to top 3 13/16
    Again, I just took a bunch of random pics so everyone could see what was what... so no harpin on what I called stuff and my worn down measuring tape
  3. #93
    lollygagger8's Avatar
    lollygagger8 is offline Cadillac Owners Connoisseur
    Automobile(s): Platinum 2004 CTS-V
    Apr 2008
    Indiana
    4,913
    So, Thomas......is the flywheel you sent me a LS6 flywheel then?
    I need to figure this stuff out so I know how much of a spacer I'm going to need. (hopefully before I tear it all apart)
  5. #94
    SoJersey05V is offline Banned
    Automobile(s): 05 CTS-V
    Jul 2008
    south jersey
    889
    ok i am also patiently waiting to learn all of this... i am in need of something in my clutch (prolly a bad bearing or something), but if im taking it out i am replacing the whole thing.
  6. #95
    54inches's Avatar
    54inches is offline Cadillac Owners Fanatic
    Automobile(s): 2005 V
    Sep 2007
    Houston, TEXAS
    42
    474
    Quote Originally Posted by nmaier2201 View Post
    Oh yeah... love it... but it's hard to get.. I found a place that carries it... great stuff.
    Nice pics.....
    Shiner has a great Winter Lager, Kosmos Reserve and about 2-3 other great beers!
    The brewery is nice as well!
  7. #96
    Apr 2008
    Indiana
    4,913
    I'll be pissed if I bought the LS7 slave for no reason.....I guess I'm goign to have to tear this f'n thing apart THEN figure out what I need. This is bullshit
  8. #97
    Jul 2008
    south jersey
    889
    Quote Originally Posted by lollygagger8 View Post
    you will have to find a way to use the ls7 slave no? the remote bleeder is for ls7 only correct? how would that work? i thought H.E. had this all figured out...
  9. #98
    liqidvenom is offline Cadillac Owners Connoisseur
    Automobile(s): cts-v
    Feb 2009
    Long Beach Ca
    35
    2,741
    something so simple as a clutch is such a big cluster fuk on the v.
  10. #99
    Hendrix-Engineering is offline Cadillac Owners Enthusiast
    Automobile(s): escalade
    May 2009
    571
    There is no such thing as a ls6 ,ls1,ls2 flywheel.There is an ls7 that has a raised section for the pp ,then Theres all the other flywheels that bolt to a ls crank,the ls7 is the odd ball,everything else is the same,im sure i told you months ago that i do not see were the ls7 slave comes in,we use the regular f body slave for the gto wethier there putting in a ls7,spec,act,mine,etc,etc.There has never been one mention of an ls7 slave in the gto crowd,f body etc.I dont see where that trany would be any different than the f body,gto setup.
  11. #100
    Apr 2008
    Indiana
    4,913
    Quote Originally Posted by Hendrix-Engineering View Post
    Must've been a communication problem then. I thought for sure you told me it was a LS7 style pkg. Sorry if I misunderstood
    Ok then, which slave will I need to make up the difference between the dual mass and the new flywheel Boss? Or is this where I get an LS6 slave and use my monster .970 spacer behind the slave?
    I really want to be able to install this right after I take it out and not have my V sit around on stands while I search for the right parts.
  12. #101
    darkman's Avatar
    Automobile(s): 2005 CTS-V
    Nov 2005
    Spring, Texas
    8,161
    There may be another risk here too. When folks first started installing aftermarket clutch components in these cars there was a lot of confusion about the spacing issues. Some landed on component combinations that would bolt together and even seemed to work only to self-destruct (dramtically and at great expense) in a few miles.
  13. #102
    Apr 2008
    Indiana
    4,913
    Quote Originally Posted by darkman View Post
    That makes me feel warm and fuzzy now.
  14. #103
    darkman's Avatar
    Nov 2005
    Spring, Texas
    8,161
    I wish I knew more details about these clutch component differences - but I don't and I know the last thing you need right now is misinformation.
  15. #104
    Apr 2008
    Indiana
    4,913
    I'm not getting any information, let alone misinformation
  16. #105
    Feb 2009
    Long Beach Ca
    35
    2,741
    i fail to understand how we can have a similar trans, engine and clutch system yet every other gm vehicle seems to work ok going from clutch to clutch while we are the odd ones out.
    How is it that GTO people can run a f body slave yet we supposedly cant. Has anyone even tried using a setup from a f-body or gto yet to test it out?
  17. Remove Advertisements
