Hendrix Clutch Assembly - Page 5
Page 5 of 9 FirstFirst 123456789 LastLast
Results 61 to 75 of 123
2004-2007 Cadillac CTS-V Performance Mods Discussion, Hendrix Clutch Assembly in Cadillac CTS-V Series Forum - 2004 - 2007; Ok, got my Jeep fixed!! The fuel pressure regulator was bad...now it's running like a champ and I'm ready to ...
  1. #61
    lollygagger8's Avatar
    lollygagger8 is offline Cadillac Owners Connoisseur
    Automobile(s): Platinum 2004 CTS-V
    Apr 2008
    Indiana
    4,913
    Re: Hendrix Clutch Assembly
    Ok, got my Jeep fixed!! The fuel pressure regulator was bad...now it's running like a champ and I'm ready to tackle the clutch!
    Should get the ARP bolts monday, along with the alignment tool, and fw tool.
    Thinking of tacking a day off work this week for the install....if not, DEFINITELY this weekend!!
  2. #62
    Apr 2008
    Indiana
    4,913
    Ok got some questions.......
    Not sure if measuring this way is even correct, but I have the stack height of the LS7 setup, and the Hendrix setup. (thank you Nmaier for the pics)
    These pics are of the flywheel, clutch disc, and pressure plate with the tape measure on the ground, up to the clutch teeth.
    LS7 (4")......
    Hendrix Setup (3 1/2")
    Does this mean I'm going to need a 1/2" spacer behind my LS7 slave???
    Also, the dowels in the flywheel don't match up with the pressure plate, so you have to punch out the dowel pins. No biggie, just a heads up!
    I think the difference is coming from the LS7 flywheel has raised sections for the pressure plate mounting screws....where the Hendrix fw does not. Cuz the flywheels are both 1" tall (not including the raised sections)
  3. #63
    nmaier2201's Avatar
    nmaier2201 is offline Cadillac Owners Connoisseur
    Automobile(s): 2006 CTS-V
    Aug 2007
    Chicago, IL
    1,415
    Quote Originally Posted by darkman View Post
    Actually, I don't know of any evidence that an LS7 clutch is either equal to, or better than, the stock CTS-V clutch.
    Many have always assumed this because the LS7 motor has a higher horsepower rating, but for all I know the GM engineers that designed/specified the CTS-V clutch knew it was going into a 4,000 pound sedan and not a 3,000 pound Corvette and made it stronger than the LS7 unit.
    There are, of course, instances where the engineering specifications are overidden by the financial/marketing types (e.g. the 1.25 inch half shafts in 2004/05) - but I haven't encountered any evidence that such is the case with the clutch.
    I have to agree with darkman on this one... I went with the LS7 because I needed to replace my stock slave at a minimum... and the V parts were ultra expensive compared to the LS7... with the LS7 I got a lighter flywheel and it isn't dual mass like the V stocker... those were my deciding factors... but I don't have anything in writing stating it's a superior unit in terms of claming power than my stocker....
    I would be interested to find out... how can I do that? If Darkman doesn't know that doesn't give me much hope.
  5. #64
    nmaier2201's Avatar
    Aug 2007
    Chicago, IL
    1,415
    Hmm now that the clutch is in the car I can only go back to the pics and dimensions I already mailed ya...
    I could post up ALL the pics I sent you of the flywheel so people can weigh in.... would that help?
  6. #65
    54inches's Avatar
    54inches is offline Cadillac Owners Fanatic
    Automobile(s): 2005 V
    Sep 2007
    Houston, TEXAS
    43
    474
    You like Shiner? I didn't know that shipped it up North. Great thread, btw.
  7. #66
    Apr 2008
    Indiana
    4,913
    Quote Originally Posted by nmaier2201 View Post
    That might help, I don't know.
    All the other diameters and stuff are the same except for the stack height. Pretty sure those rasied up sections are the culprit for making the 1/2" difference. I want to tear into this and get it in the car asap. Does anybody know if I'll be ok with these dimensions, or if I'll need a spacer?!?!?
  8. #67
    ctsv154's Avatar
    ctsv154 is online now Cadillac Owners Connoisseur
    Automobile(s): 04 CTS-V with a little hp persuasion device
    Oct 2007
    32
    3,824
    The differance could come from the raised portion of the flywheel but if you look on the LS7 PP you'll see the friction surface actually hangs out of the pressure plate were the HE one wont. Also, make sure when you measure that you are measuring from the surface of the flywheel that actually touches the crank. Some flywheels have the the mating surface slightly recessed from the rest of the flywheel which can jack you up. The best way to do measure is to bolt it all together and measure.
  9. #68
    ctsv154's Avatar
    Oct 2007
    32
    3,824
    Also, what flywheel are you botling the HE PP too? Did he send a flywheel too and they dont line up or are you bolting the PP to the LS7 flywheel or what? If he sent you a PP for a regular LS1/LS6 flywheel and you have an LS2/LS7 flywheel, it wont work becaus the fuction surface is recessed on the LS2/7 flywheel and its not on the LS1/6
  10. #69
    Apr 2008
    Indiana
    4,913
    Quote Originally Posted by ctsv154 View Post
    I'm saying the dowel pins on the fw don't match up with the PP (actually there are no holes in the PP for the pins).
    Thomas said the whole setup is just like the LS7 setup. He sent the fw, pp, and clutch. The fw does have a recessed portion where it bolts to the block, but the friction surfaces line up just fine. Check out the pics in my first post.
    I'm trying to avoid getting it all taken apart and then not being able to use what I have.
  11. #70
    SoJersey05V is offline Banned
    Automobile(s): 05 CTS-V
    Jul 2008
    south jersey
    889
    you had the ls7 setup b4 this lolly? if so why are you switching?
  12. #71
    Apr 2008
    Indiana
    4,913
    Quote Originally Posted by SoJersey05V View Post
    No, I have the stock LS6 clutch now (which is failing miserably)
    The pics of the LS7 setup are from Nmaier (thanks again to him)
  13. #72
    ctsv154's Avatar
    Oct 2007
    32
    3,824
    so the HE pp was made to bolt to the LS7 flywheel? I'm confused. What flywheel are you using?
  14. #73
    Apr 2008
    Indiana
    4,913
    He sent a fw. 15 lb Fidanza. It's supposed to be the same as a LS7 type. How close that is to a LS6 type (non-dual mass) I don't know.
  15. #74
    darkman's Avatar
    Automobile(s): 2005 CTS-V
    Nov 2005
    Spring, Texas
    8,213
    Quote Originally Posted by lollygagger8 View Post
    Wise move. I know your current project is somewhat exploratory but when I buy my next clutch I am going to look for a complete coordinated "kit" that bolts in. These mix and match exercises are too tedious.
  16. #75
    Apr 2008
    Indiana
    4,913
    Well it should bolt in, but I am being the guinea pig for this whole project to make sure it's all smooth for the rest of yaz. Hence, the extremely good price of free for everything except the fw.
  17. Remove Advertisements
