Hendrix Clutch Assembly - Page 4
Page 4 of 9 FirstFirst 1 2 3 4 5 6 7 8 9 LastLast
Results 46 to 60 of 123
2004-2007 Cadillac CTS-V Performance Mods Discussion, Hendrix Clutch Assembly in Cadillac CTS-V Series Forum - 2004 - 2007; Originally Posted by Hendrix-Engineering Yes,but the manufactors like to rate for best case ,then when you have a problem they ...
  1. #46
    thebigjimsho's Avatar
    Automobile(s): ZIP
    In the barrel of a gun...
    51,885
    Re: Hendrix Clutch Assembly
    Quote Originally Posted by Hendrix-Engineering View Post
    Yes,but the manufactors like to rate for best case ,then when you have a problem they tell you that your cars to heavy!...If i guy calls me for a clutch and i make a recomendation i stand behind it 100% ,no excuses.
    You and Zuki...
  2. #47
    CTS-Voodoo's Avatar
    CTS-Voodoo is offline Cadillac Owners Enthusiast
    Automobile(s): 05 Raven V
    Oct 2008
    AutoRepairSEO.com
    951
    Another Hendrix clutch/flywheel combo has been sold gentlemen. Ill be taking pics of the install and doing a full writeup as well.
  3. #48
    SoJersey05V is offline Banned
    Automobile(s): 05 CTS-V
    Jul 2008
    south jersey
    889
    ok i mite have to jump on this and my damn motor mounts... something is loose in my clutch assembly... at idle you can hear shit rattling... as soon as you put tiny pressure on clutch pedal it disappears.....
  5. #49
    darkman's Avatar
    Automobile(s): 2005 CTS-V
    Nov 2005
    Spring, Texas
    8,156
    Quote Originally Posted by SoJersey05V View Post
    The checklist in the service manual for Clutch Rattle, with clutch engaged or disengaged, is as follows:
    1. Idle rattle clutch engaged – replace engine flywheel due to faulty springs.
    2. Clutch is improperly installed.
    3. Clutch disc splines and input shaft splines worn.
    The checklist in the service manual for Clutch Noisy, with clutch engaged or disengaged, is as follows:
    1. Pilot bearing is worn.
    2. Release bearing is damaged or worn.
    These assume, of course, that the issue is not something really simple like loose change in the ashtray, or some loose a heat shield underneath, etc.
  6. #50
    Jul 2008
    south jersey
    889
    Quote Originally Posted by darkman View Post
    YOU ARE THE KING!! thank you so much! i'm sure the noise and vibrations are coming from that!
    how much time/cost is it usually to have a clutch installed?
  7. #51
    darkman's Avatar
    Nov 2005
    Spring, Texas
    8,156
    Standard (flat rat manual) time is 4 hours. My dealer charged me 6 hours when I changed mine out. As you know, labor rates vary a lot. Local shops here start at around $60 per hour; my dealer gets $110 per hour.
  8. #52
    Hendrix-Engineering is offline Cadillac Owners Enthusiast
    Automobile(s): escalade
    May 2009
    571
    Quote Originally Posted by CTS-Voodoo View Post
    THANKS We look foward to it!
  9. #53
    Jul 2008
    south jersey
    889
    i want to get some reviews on this b4 i jump in.... if not i will just do ls7....
    but i do want to comment... h.e. you wont rate it, but you say it will hold more then the ls9 clutch?!?! ok.
  10. #54
    darkman's Avatar
    Nov 2005
    Spring, Texas
    8,156
    Actually, I don't know of any evidence that an LS7 clutch is either equal to, or better than, the stock CTS-V clutch.
    Many have always assumed this because the LS7 motor has a higher horsepower rating, but for all I know the GM engineers that designed/specified the CTS-V clutch knew it was going into a 4,000 pound sedan and not a 3,000 pound Corvette and made it stronger than the LS7 unit.
    There are, of course, instances where the engineering specifications are overidden by the financial/marketing types (e.g. the 1.25 inch half shafts in 2004/05) - but I haven't encountered any evidence that such is the case with the clutch.
  11. #55
    ctsv154's Avatar
    ctsv154 is offline Cadillac Owners Connoisseur
    Automobile(s): 04 CTS-V with a little hp persuasion device
    Oct 2007
    32
    3,824
    The stock clutch is really good for a stock clutch. I think most go to the LS7 just to go single mass and because it did come on a car with 505hp, it has to stick at least as good as the V's. What I would be interested in is a PP that will bolt to an LS7 flywheel without breaking the bank.
  12. #56
    Jul 2008
    south jersey
    889
    hmmm.... this is true... now kinda leaning towards the H.E. clutch.... only thing is... is the 15lb flywheel too lite for the v?
  13. #57
    May 2009
    571
    I would recomend the clutch to anyone with 600 hp or less,after that i would like to get a feel for there driving habits,we might need to step up clamp load and disc material,which we have readily avalible.FYI we also have a servicable 25 lb flywheel as well.Thanks for the consederation.
  14. #58
    May 2009
    571
    Also keep in mine i never sold the axles saying they would eliminate wheel hop either,i think they work pretty well
  15. #59
    Jul 2008
    south jersey
    889
    i drive hard! i only have acorsa for now put future plans are to heads cam intake manifold tb headers, and if you were to beef up the one you have now and also with the 25lb flywheel... how much are we talking?
  16. #60
    V-Love's Avatar
    V-Love is offline Cadillac Owners Connoisseur
    Automobile(s): 2004 CTSV(killed), 2005 CTSV(killed that too). 2004 DTS.
    Mar 2004
    North Cuba
    1,574
    Nice! Good addition to the library.
  17. Remove Advertisements
