Gforce Engineering half shafts - Page 4
Page 4 of 12 FirstFirst 123456789101112 LastLast
Results 46 to 60 of 172
2004-2007 Cadillac CTS-V Performance Mods Discussion, Gforce Engineering half shafts in Cadillac CTS-V Series Forum - 2004 - 2007; Subscribing and interested in axles at a reasonable price too!!!...
  1. #46
    vseries's Avatar
    vseries is offline Cadillac Owners Enthusiast
    Automobile(s): 2009 CTS-V , 2013 ATS Turbo
    Dec 2006
    NY -> AZ
    525
    Re: Gforce Engineering half shafts
  2. #47
    the dumontster is offline Cadillac Owners Member
    Automobile(s): Cadillac
    Oct 2007
    37
    interested in a 1 piece drive shaft!
  3. #48
    perfect's Avatar
    perfect is offline Cadillac Owners Connoisseur
    Automobile(s): 2005 Cadillac CTS-V Platinum
    May 2008
    Kansas City
    33
    1,182
    count me in for the "interested in axles at a cheap and reasonable price"
  5. #49
    GFORCE1320 is offline Cadillac Owners Enthusiast
    Automobile(s): NONE
    Jul 2009
    572
    Quote Originally Posted by nmaier2201 View Post
    In addition to the driveshaft I do also have a complete rear cradle... shocks, springs, diff, hubs, trailing arms.....everything. I think we should talk
    Give me a call, 316-650-4270 if you dont mind.
    Thanks
    Chris
  6. #50
    richdash is offline Cadillac Owners Fanatic
    Automobile(s): 2004 CTS-V
    May 2009
    Sacramento, CA
    109
    there could be lots of money in a wheel hop solution at a price point near your other vehicles solutions...
  7. #51
    Automobile(s): NONE
    Jul 2009
    572
    So if I was to design and make just the axle shafts that you could swap out yourselves (the kit would only be the axle shafts and not the inner or outer stubs and cv joints) could I base them off of 04 half shafts ? Are they all the same as far as axle spline diameter and spline count?
  8. #52
    darkman's Avatar
    Automobile(s): 2005 CTS-V
    Nov 2005
    Spring, Texas
    8,201
    Quote Originally Posted by GFORCE1320 View Post
    The 04-05 half-shaft assemblies (inclusive of inter and outer stubs and CV jonts) are interchangeable with the 06-07 half-shaft assemblies.
    The 04-05 shafts are 1.25 inches in diameter (hollow) and the 06-07 shafts are 1.5 inches in diameter (also hollow). So some sub-component must be different.
    I have a set of each (05s & 07s). (I now run the Hendrix-Engineering axles).
  9. #53
    Automobile(s): NONE
    Jul 2009
    572
    So your saying the inner and outer stubs are all the same?
    Hollow huh? Well, mine wont be hollow. They will be solid 300m, the strongest steel you can use to make axles with.
  10. #54
    rjoffe is offline Cadillac Owners Connoisseur
    Jul 2005
    1,900
    One of the solutions used in the 09 V's is to have different torsional spring rates on the different half shafts. This seems to reduce wheel hop. Do you have plans to use different materials, sizes, heat treatments,etc to achieve different spring rates on the half shafts ?
  11. #55
    darkman's Avatar
    Nov 2005
    Spring, Texas
    8,201
    I think the inner and outer stubs must be the same, but I am drawing that conclusion simply from the fact that my 05 CTS-V came with (obviously) the 05 assemblies, which were replaced with the 07 assemblies with no other changes in associated hardware or parts. This means that the inners fit into the same differential and the outers work with the same knuckles. The shafts themselves, however, were two different diameters (1.25" vs. 1.50") which means there must be a different interface between each inner stub and each outer stub, right? (I have never disassembled any of these).
  12. #56
    Automobile(s): NONE
    Jul 2009
    572
    Quote Originally Posted by rjoffe View Post
    Yes, I will more then likely offer a 30mm (1.18-1.20) drivers side axle and a 36mm (1.42-1.45) axle on the passenger side.
    That is what I am coming out with for the new Camaro and G8.
    Very similar to what GM has done on the new Camaro.
    Quote Originally Posted by darkman View Post
    I'm sure the splined are of the axles are the same where they go into the stubs. They probably just bump up the diameter between the cv's.
  13. #57
    darkman's Avatar
    Nov 2005
    Spring, Texas
    8,201
    If you say so. I have already told you more than I know on this subject.
  14. #58
    dannboss is offline Cadillac Owners Fanatic
    Automobile(s): 2006 BMW M5 | 2007 Cadillac Escalade ESV
    Oct 2008
    Dallas, TX
    315
    So....again, in theory, when will they be ready? Trying to budget for the future!
  15. #59
    May 2009
    Sacramento, CA
    109
    Doubt he can really put a time on it... He will need to do R&D, lets give the kind man some time here!!! We all want to eliminate wheel hop for under 2 grand.... My money says that these wont need a $200 grease option. I cant wait to see what happens!!!
  16. #60
    Twitch's Avatar
    Twitch is offline Cadillac Owners Connoisseur
    Automobile(s): '05 CTS-V, '00 SLS, 98 SLS, 89 Eldo, '80 Eldo
    Mar 2006
    NYC
    46
    4,001
    Quote Originally Posted by Luna. View Post
    Good God...what motor(s) are you guys planning on running? Are you talking crank or wheel HP?
    Holy smokes...I would have been happy with a diff that would handle 500 rwhp, to say nothing about 600 or more.
    Also, I'd start raising an eyebrow at the transmission at those power levels, for they far exceed the rated specs.
    All I can say is, I want a ride in your cars...
    Haha, your funny
    Actually, I think 500rwhp would be my limit (if I ever get that far). I'm much more interested in the low end grunt . But I would like that 100hp buffer.
  17. Remove Advertisements
