Gforce Engineering half shafts - Page 3
Page 3 of 12 FirstFirst 1 2 3 4 5 6 7 8 9 10 11 12 LastLast
Results 31 to 45 of 172
2004-2007 Cadillac CTS-V Performance Mods Discussion, Gforce Engineering half shafts in Cadillac CTS-V Series Forum - 2004 - 2007; A parts car.. hmm. now your talking. Here is my shopping list. Transmission slip yoke or what ever the CTS-v ...
  1. #31
    GFORCE1320 is offline Cadillac Owners Enthusiast
    Automobile(s): NONE
    Jul 2009
    572
    Re: Gforce Engineering half shafts
    Transmission slip yoke or what ever the CTS-v uses that comes off the transmission output shaft.
    If I am going to make driveshafts, they will not have any adapters what so ever. It'll be a slip yoke on the front and a billet pinion yoke on the back.
    OEM driveshaft
    Diff pinion yoke
    Diff pinion gear for billet yoke fit check
    Half shaft assembly L&R side including the inner and outer stubs
    I could either buy these parts or borrow them and return them once I get all the data I need.
    I usually end up buying a complete rear cradle assy with everything from a salvage yard.
    Thanks
    Chris
  2. #32
    Luna. is offline Cadillac Owners Connoisseur
    Automobile(s): 2005 Stealth Gray CTS-V, 2009 Black CTS-V
    Jun 2005
    CA
    3,571
    Quote Originally Posted by CTSV_510 View Post
    Gimme something that will withstand 600-700 hp at a reasonable price.
    Quote Originally Posted by Twitch View Post
    Good point
    Quote Originally Posted by AG'S-V View Post
    This
    Good God...what motor(s) are you guys planning on running? Are you talking crank or wheel HP?
    Holy smokes...I would have been happy with a diff that would handle 500 rwhp, to say nothing about 600 or more.
    Also, I'd start raising an eyebrow at the transmission at those power levels, for they far exceed the rated specs.
    All I can say is, I want a ride in your cars...
    Quote Originally Posted by dannboss View Post
    Typically the differential due to the wheel hop or torque on the rear end. I haven't heard of CVs or axles breaking though. That is why we are so interested in the half shafts to eliminate the wheel hop, thus saving other parts.
    , save for breaking CV/axles.
    Quote Originally Posted by darkman View Post
    Before everyone gets carried away with the "single-half-shaft-theory" please remember that the stock half shafts in the 2004 and 2005 models were considered marginal at best for a stock V by GM's engineers. Many of them broke and led to the larger half shafts found in the 2006 and 2007 models.
  3. #33
    ahahnu's Avatar
    ahahnu is offline Cadillac Owners Connoisseur
    Automobile(s): '05 LS6 V Stealth Grey; '14 Z71 SLT Sierra 1500 Stealth Grey
    Dec 2004
    Tailgating at Giants Stadium
    37
    2,821
    I might even buy one for testing.
    I'm sure you could, they are getting cheap enough : (
    As far as what breaks and what doesn't a lot of the early users here had lots of variations. Almost different per person (if I remember correctly) I'm sure alot of them are spelled out on previous pages from a few years ago.
    Alot of people replaced the rear for whine (guilty here). And now it whines still. Does the axels cure this problem as well?
  5. #34
    whisler151's Avatar
    whisler151 is offline Cadillac Owners Connoisseur
    Automobile(s): 2012 CTS-V Sedan, 2011 CTS Coupe, 2010 Ford Raptor
    Apr 2007
    Dallas, TX
    3,547
    Glad to see you on the forum GForce. I hope you can help bring some cost effective solutions to us.
  6. #35
    Automobile(s): NONE
    Jul 2009
    572
    The axles wont do anything for the diff whining.
  7. #36
    StewV is offline Banned
    Automobile(s): CTS-V
    Jun 2009
    47
    ATTN G-FORCE:
    I'm not sure if you're aware that in 06 they upgraded the rear diff
    and half shafts. So you may want to buy a cradle from the 06-07,
    as this is the factory replacement rear for all the faulty 04-05's.
    The 04-05 rears were stock 6cyl rears with a gear set, (3:73's)
    and the 06-07 where updated, due to many failures for those first two
    production years.
    I hope this helps in your quest to bring us closer to an economicly
    sound option for our "wheel-hop" issues.
    Thanks for thinking of us, and good luck in your future endeavourse!!!
  8. #37
    CTSV_510's Avatar
    CTSV_510 is offline Cadillac Owners Connoisseur
    Automobile(s): '06 Z06, '05 CTS-V 453rwhp/434rwtq (sold)
    Jan 2008
    West Chester, PA
    34
    4,455
    Quote Originally Posted by Luna. View Post
    We gotta leave some room to grow, right?
  9. #38
    jpoole's Avatar
    jpoole is offline Cadillac Owners Fanatic
    Automobile(s): 2010 Cadillac CTS-V
    May 2007
    McKinney, Texas
    266
    Would be very interested in low cost half-shafts to get rid of the hop!!!
  10. #39
    Automobile(s): NONE
    Jul 2009
    572
    Quote Originally Posted by StewV View Post
    ATTN G-FORCE:
    production years.
    Thank you for the good info!
  11. #40
    ctsv154's Avatar
    ctsv154 is offline Cadillac Owners Connoisseur
    Automobile(s): 04 CTS-V with a little hp persuasion device
    Oct 2007
    32
    3,824
    The parts are interchangeable so any year should work if all you want is fitment. The diff is technically the same with an updated case. All the mounts and internals remained the same. Same with the axles. They just got bigger but thats it.
  12. #41
    jpoole's Avatar
    May 2007
    McKinney, Texas
    266
    I believe there is some pent up demand for affordable solution.....
  13. #42
    UnsafeAtAnySpd's Avatar
    UnsafeAtAnySpd is offline Cadillac Owners Connoisseur
    Automobile(s): '04 CTS-V, '07 SRT8 Jeep, '86 Fiero
    Aug 2007
    Arlington, VA
    31
    1,647
    Quote Originally Posted by GFORCE1320 View Post
    Let me know and we could probably work something out.
  14. #43
    rand49er's Avatar
    Jan 2005
    South Lyon, MI
    68
    13,813
    Quote Originally Posted by jpoole View Post
    Hendrix Engineering only put a very small dent in the demand. At a different price point, the flood gates would open wide.
  15. #44
    c4ss's Avatar
    c4ss is offline Cadillac Owners Connoisseur
    Automobile(s): 2005 CTS-V, Black
    Jun 2008
    Northern New Jersey
    2,166
  16. #45
    nmaier2201's Avatar
    nmaier2201 is offline Cadillac Owners Connoisseur
    Automobile(s): 2006 CTS-V
    Aug 2007
    Chicago, IL
    1,415
    OEM driveshaft
    Diff pinion yoke
    Thanks
    Chris
    In addition to the driveshaft I do also have a complete rear cradle... shocks, springs, diff, hubs, trailing arms.....everything. I think we should talk
  17. Remove Advertisements
