Clutch Questions...Help! - Page 3
Page 3 of 7 FirstFirst 1 2 3 4 5 6 7 LastLast
Results 31 to 45 of 94
2004-2007 Cadillac CTS-V Performance Mods Discussion, Clutch Questions...Help! in Cadillac CTS-V Series Forum - 2004 - 2007; Originally Posted by CTSV_Rob Have you started the install yet? No Sir.....Hendrix said he will probably get the flywheel(s) in ...
  1. #31
    lollygagger8's Avatar
    lollygagger8 is offline Cadillac Owners Connoisseur
    Automobile(s): Platinum 2004 CTS-V
    Apr 2008
    Indiana
    4,913
    Re: Clutch Questions...Help!
    Quote Originally Posted by CTSV_Rob View Post
    No Sir.....Hendrix said he will probably get the flywheel(s) in Tuesday. I probably won't get around to installing it for a week or two.
    Randy, why are you getting a new slave? Just for the remote bleeder? How much was your slave, and where did you get it? I'm guessing you got a LS6 slave, right? Which remote bleeder did you get, and how much? (you can PM if you want) thank you Sir!
  2. #32
    Hendrix-Engineering is offline Cadillac Owners Enthusiast
    Automobile(s): escalade
    May 2009
    571
    Im doing some checking as well,i much rather use the $100 f body style than a $230 ls7,if it needs a shim i will have a lazer shop make me some and put it in with the kitts,ive just been gettin to many diffeent stories.Mann im just going to buy one of these ctsvs!..How bout a group buy on 1000 sets of axles...LOL
  3. #33
    Apr 2008
    Indiana
    4,913
    Quote Originally Posted by Hendrix-Engineering View Post
    What's the part # of the F body slaves Thomas? Do you have any laying around that you could snap a pic of and give dimensions? Man I wonder if those would work?
    Where's the cheapest anyone has found a LS6 slave? I'm ok with getting a spacer made.
  5. #34
    May 2009
    571
    Quote Originally Posted by lollygagger8 View Post
    I have one here ill sendit with your clutch and you can compare.
  6. #35
    rand49er's Avatar
    Jan 2005
    South Lyon, MI
    68
    13,824
    I think I should point something out, here. As much as Thomas wanders around in the back of his shop and handles parts and works on stuff, I'll bet his computer keyboard is one nasty sight!
  7. #36
    Apr 2008
    Indiana
    4,913
    Ok just talked to Thomas, he's shipping out the fw/clutch and all that today.
    1) So, should I drain the fluid out of the trans before removal, or can I get away with leaving it in?
    2) How do you get the fw not to turn when loosening/tightening the bolts? Does the crank just hold it in place, or is there a special tool needed?
    3) Are there any tricks to unhooking the master cylinder line? I haven't even looked at the connection yet.
    4) Is the only difference between the LS7 slave and the LS6 slave, the length? (like LS6 slave is going to be shorter due to the dual mass fw, and LS7 picks up the slack - and no spacer needed) <- correct?
    5) Anybody have the torque settings for all the bolts? ?
  8. #37
    darkman's Avatar
    Nov 2005
    Spring, Texas
    8,181
    Transmission Fluid = Weight - your call.
    See Attached:
  9. #38
    Apr 2008
    Indiana
    4,913
    Thanks for the torque values Darkman!! That's funny.....not sure why you would need to remove the shifter bracket, but ok.
    #1....as long as it doesn't spill out all over is what I'm concerned about. Weight.....ehhh
    #5 is answered then .....
    anybody else got anything?
  10. #39
    nmaier2201's Avatar
    nmaier2201 is offline Cadillac Owners Connoisseur
    Automobile(s): 2006 CTS-V
    Aug 2007
    Chicago, IL
    1,415
    yeah what did you decide on the remote bleeder? I just got my LS7 from luke so natrurally I'm itching for a write-up....
    Let me know if you need a hand... maybe I'll drive down next weekend I think I have free....
  11. #40
    Apr 2008
    Indiana
    4,913
    Quote Originally Posted by nmaier2201 View Post
    I'm calling LAPD and ordering their bleeder. Randy got his from there are said they are pretty cool guys.
    Did you get the whole setup then? (LS7 fw/p.plate/clutch/slave)
    Did you get a LS7 slave then?
    Once I get everything I need, that would be cool if you came down if you have time. We can mess mine up, so your install goes smoothly lol. I don't know if I'll have anything by next weekend though?
    I guess I need to get my LS7 slave ordered. Since Hendrix said it's a LS7 type clutch, I don't know if the LS7 slave will work perfect length or not.....I don't know how big the spacer should be, or if there should even be one. I did find this (for measurement purposes) but it's a little confusing to me still
  12. #41
    nmaier2201's Avatar
    Aug 2007
    Chicago, IL
    1,415
    That looks perfectly simple to me! Just kidding. I don't see how you could get those measurements w/o taking the trans on and off a couple times... that sounds horrid.
    Yeah I got the whole LS7 setup. flywheel, clutch, and slave. I still need to get the bleeder... jury is still out on that one... I was going to get it after the fact and just hook it up, but Luke said with the LS7 you do need to notch it slightly or bend the tube on the LS7 slave (boo to that option) or get a bleeder... so it sounds like getting the remote bleeder during install is highly suggested.
    Yeah I'd be 90% confident that your LS7 type clutch needs the LS7 slave for spacing... and that he spacing should be fine with it. I'd order it... it's not overly expensive and getting a spacer made for your used worn down slave doesn't make a ton of sense.
    I'm slightly concerned on your diagram there about shim spacing... I didn't get any shims... becuase I was pretty sure I didn't need them.
    I'm pretty sure I'm free last weekend in July, if you are going to do it later I'll check to see if I'm free. I heard it's a two man job and since I'm going to be doing it myself (or paying someone) I might as well see what I'm getting myself into... and it would be fun.
  13. #42
    Apr 2008
    Indiana
    4,913
    I'm going to replace the slave regardless.....and install the remote bleeder while it's out. After bleeding it and seeing the $hit that came out of it, I'll be bleeding it every couple months!
    You shouldn't need shims since your slave is made for that distance clutch.
    What I DO need, is the measurement of your flywheel/p.plate/clutch assy. (the height) Could you get that for me man? That would help me big time, so I have that to compare with the Hendrix stuff. If they are the same, I won't need a spacer!
    Ya if you help me on mine, I could always come help you on yours. My Grandma lives in Countryside (couple miles from the UPS hub off 297) so I could stay with her at night and we work on yours during the day.
    I guess since we are the only two interested in this, there will be no need to take pics cuz we'll be pros by the end of it all!
  14. #43
    nmaier2201's Avatar
    Aug 2007
    Chicago, IL
    1,415
    no problem. i'll let you know
  15. #44
    Apr 2008
    Indiana
    4,913
    LAPD remote bleeder ordered
    LS7 slave ordered from Luke
    .......just waiting for Hendrix Clutch/FW
  16. #45
    CTSV_Rob's Avatar
    CTSV_Rob is offline Cadillac Owners 10000+ Posts
    Automobile(s): 2007 CTS-V Thunder Gray; 2004 Cowboy Cadillac (SRT10)
    Mar 2007
    Sunny CA.
    50
    17,678
    Don't forget the pics LG8.
    Some of us want to see what you went through. I changed out my flywheel on jack stands but I don't see this happening again PITA. I may need a new clutch soon and if so I would like to hear how this install went and if the LS7 slave worked for you.
  17. Remove Advertisements
