Sometimes I seriously hate this car. Codes inside. - Page 2
Page 2 of 5 FirstFirst 12345 LastLast
Results 16 to 30 of 68
2004-2007 Cadillac CTS-V Performance Mods Discussion, Sometimes I seriously hate this car. Codes inside. in Cadillac CTS-V Series Forum - 2004 - 2007; Originally Posted by justin311 You prolly could verify the list then: Magnuson Snout Harness Tb Tune Originally Posted by CTSV_510 ...
  1. #16
    ctsv154's Avatar
    ctsv154 is offline Cadillac Owners Connoisseur
    Automobile(s): 04 CTS-V with a little hp persuasion device
    Oct 2007
    32
    3,824
    Re: Sometimes I seriously hate this car. Codes inside.
    Quote Originally Posted by justin311 View Post
    Magnuson Snout
    Harness
    Tb
    Tune
    Quote Originally Posted by CTSV_510 View Post
    gaskets
    Sounds about right. Dont forget the bolts for the new TB. The 90 is a four bolt and and the 78 is a 3. Other than the minor change in pluming for all the lines, that sounds like it.
  2. #17
    lollygagger8's Avatar
    lollygagger8 is offline Cadillac Owners Connoisseur
    Automobile(s): Platinum 2004 CTS-V
    Apr 2008
    Indiana
    4,913
    Does the 78 have a cooling line, and the 90 not have one? Or am I thinking of something else?
  3. #18
    ctsv154's Avatar
    Oct 2007
    32
    3,824
    The 78 does have a coolant line but I have already bypassed it. But for those that have not, its an easy mod.
  5. #19
    justin311 is offline Cadillac Owners Enthusiast
    Automobile(s): 2005 Cadillac CTS-V
    Jan 2008
    Nashvegas, TN
    34
    971
    Pics? How to?
  6. #20
    ctsv154's Avatar
    Oct 2007
    32
    3,824
    No pics but I think I can walk you through it. The stock TB has two lines on the bottom of it. On goes to the driver side of the engine to a crossover tube and the other goes under the radiator shroud. Just disconnect the line that goes from the engine to the TB and remove it completely. Now take the other line the goes under the radiator shroud and remove it from the TB and reconnect it to where you pulled the other line off the crossover tube.
    When you do the maggie swap, this cross over gets replaced and the inlet is now on the passengers side so just wait until you do the swap to do it or you'll just be doing double work.
    These lines do have antifreeze in them so be careful if you do this when the engine is hot. Also, if you pull a line off and no antifreeze comes out, you probably picked the wrong lines. The two lines are the lowest part of the throttle body. Also, just to make it look a little better, I used vise grips and clamped onto the nipples and twisted them out. They can be removed with breaking them off but you will destroy them getting them out. But its not like they will ever be used again anyway.
  7. #21
    ctsv154's Avatar
    Oct 2007
    32
    3,824
    Okay just for grins I plugged in the 90mm TB with the new harness and the reduced engine power went away. Obviously I still have no control over the car because it wasn't actually installed but, it looks like it is the TB. I beat on the TPS sensor and the TB motor but it never fixed itself. Its to hot right now to mess with it so I just shut the hood.
  8. #22
    ctsv154's Avatar
    Oct 2007
    32
    3,824
    Heres a few shots to show you 78mm guys what you're missing out on.
    A shot with the 90mm snout on the 78mm TB to get a good idea just how much bigger the 90 is.
  9. #23
    MauiV's Avatar
    MauiV is offline Cadillac Owners Connoisseur
    Automobile(s): Tis Gone :(
    Nov 2007
    3,414
    About 12 millimeters?
  10. #24
    ctsv154's Avatar
    Oct 2007
    32
    3,824
    Quote Originally Posted by MauiV View Post
    I'd say thats pretty close
  11. #25
    CTSV_510's Avatar
    CTSV_510 is offline Cadillac Owners Connoisseur
    Automobile(s): '06 Z06, '05 CTS-V 453rwhp/434rwtq (sold)
    Jan 2008
    West Chester, PA
    34
    4,455
    holy crap that looks a lot bigger. I want it.
  12. #26
    Max-Q is offline Cadillac Owners Fanatic
    Automobile(s): Cadillac CTS-V & Escalade
    Feb 2007
    St. Louis
    247
    A couple questions.... what is the reason to bypass the cooling lines to the 78mm throttle body? Wouldn't it be more effective if it's being cooled?
    Second, does the 90mm throttle body fit under the stock hood on an LS6 with a maggie?
    I would have gone the 90mm route with mine if it hadn't been for the dealer replacing it under warranty. It's hard to beat free
  13. #27
    ctsv154's Avatar
    Oct 2007
    32
    3,824
    The coolant lines actually act as a heater so bypassing them will keep it cooler. However, the 90mm TB doesn't have any coolant lines running through it so the bypass is necessary anyway for the swap.
    The 90 will fit under the hood. They did it on the LS2.
  14. #28
    Jan 2008
    Nashvegas, TN
    34
    971
    O BABY. That looks sexy. I'm getting excited as hell. I have to find another bolt.
  15. #29
    Jan 2008
    Nashvegas, TN
    34
    971
    Call Jason @ Katech. He has a couple of LS2 throttle bodies laying around. How much did you pay ctsv154? Prolly got it awhile ago.
  16. #30
    CTSV_510's Avatar
    Jan 2008
    West Chester, PA
    34
    4,455
    Are they new? What does Katech want for them?
  17. Remove Advertisements
