Oh No My Clutch! - Page 3
Page 3 of 4 FirstFirst 1234 LastLast
Results 31 to 45 of 51
2004-2007 Cadillac CTS-V Performance Mods Discussion, Oh No My Clutch! in Cadillac CTS-V Series Forum - 2004 - 2007; I smell a group buy brewing...
  1. #31
    deedubb's Avatar
    deedubb is offline Cadillac Owners Connoisseur
    Automobile(s): E85 Powered - Maggie'd V
    Feb 2005
    Mile High
    37
    1,747
    Re: Oh No My Clutch!
  2. #32
    MO POWA! is offline Cadillac Owners Fanatic
    Automobile(s): CTS V
    May 2009
    30
    140
    I have had very good results from my Ram street dual clutch, very good drivability, smooth engagement, pedal is not heavy at all, and has held up to TONS of power with no problems. I would also suggest you look into RPS line of clutches, they are very good and once again very streetable, and hold alot of power. This first hand experience advise.
  3. #33
    nmaier2201's Avatar
    nmaier2201 is offline Cadillac Owners Connoisseur
    Automobile(s): 2006 CTS-V
    Aug 2007
    Chicago, IL
    1,415
    MO POWA... I read a thread a while ago about someone installing a RAM clutch that didn't fit.... you don't have the part #s of your setup do you?
  5. #34
    ctsv154's Avatar
    ctsv154 is offline Cadillac Owners Connoisseur
    Automobile(s): 04 CTS-V with a little hp persuasion device
    Oct 2007
    32
    3,824
    Quote Originally Posted by Hendrix-Engineering View Post
    The ls7 flywheel is a cast piece,not a safe piece for high and constent rpm imo...We do not have anything but theres nothing special about the desighn and we have a flywheel thats about the same weight.
    I have an LS7 style Fidanza aluminum flywheel and was just wondering if you had anything that fit it. I bought this setup before I ever planned on having this much hp. I do like the aluminum flywheel, I just wish I wouln't have bought the LS7 style. I should have bought the LS6 style. Plates and disks are much cheaper for them.
  6. #35
    May 2009
    30
    140
    Quote Originally Posted by nmaier2201 View Post
    No sorry i dont have the part numbers. However RPS makes a kit designed for the ctsv which includes a billet flywheel. I would highly recomend this clutch, we have one on a trans am making 750 hp and has worked with no problems, not even clutch smell. The clutch has taken many 4k dumps at the track with slicks, spraying out of the hole with out a single problem. Once again the drivability and pedal feel is stock like, I will be replacing my Ram with the RPS unit. Sorry just my .02
  7. #36
    nmaier2201's Avatar
    Aug 2007
    Chicago, IL
    1,415
    no need to apologize. Thanks for the input and the .02. 1st hand experience is exactly what most of us are looking for.
  8. #37
    Hendrix-Engineering is offline Cadillac Owners Enthusiast
    Automobile(s): escalade
    May 2009
    571
    Quote Originally Posted by MO POWA! View Post
    The gto crowd didnt have much luck with this clutch,keep in mind the gto and ctsv is very comparable in weight ,the f body is alot lighter and can get away with a lesser clutch.Not saying that this will not work in the ctsv,but i would never put a twin in a car,any car unless its absoloutly nesacerry.I dont think there is but maybe a very very few ctsvs that need more than our single
  9. #38
    May 2009
    571
    i 100% agree.Just make sure when you look at clutch recomendations you get a comperble weight to the car your wanting one for.
  10. #39
    CTSV_510's Avatar
    CTSV_510 is offline Cadillac Owners Connoisseur
    Automobile(s): '06 Z06, '05 CTS-V 453rwhp/434rwtq (sold)
    Jan 2008
    West Chester, PA
    34
    4,455
    This thread is confusing the hell outta me. When I need a clutch I'm just going to call Thomas and be done with it!
  11. #40
    lollygagger8's Avatar
    lollygagger8 is offline Cadillac Owners Connoisseur
    Automobile(s): Platinum 2004 CTS-V
    Apr 2008
    Indiana
    4,913
    Quote Originally Posted by ctsv_510 View Post
    this thread is confusing the hell outta me. When i need a clutch i'm just going to call thomas and be done with it!
    Agreed!!!!
    We all like to have it writeen out on here so everyone else can benefit from what is needed and stuff.
    So do I need a stock slave, or an LS7 slave for your clutch/flywheel/p.plate?
    Is your flywheel Fidanza? <- which part #?
    How much HP does your clutch hold?
    Who makes it?
    If I get non adjusting clutch, is there anything special I have to do on install?
    Or do I have to call you?
    Please let me know Boss!
  12. #41
    May 2009
    571
    [QUOTE=lollygagger8;1918982]Agreed!!!!
    So do I need a stock slave, or an LS7 slave for your clutch/flywheel/p.plate?You would need the same slave you would ned if you did the ls7 clutch,im not sure if theres a dfference.
    Is your flywheel Fidanza? <- which part #? Some are ,depends on the one you want,25lbs billit,12 lb aluminum is a piece we have made from fidenza..16llb billit from another source.
    How much HP does your clutch hold? That is a relative answer,clutch manufactors rate the clutchs in the best case,ie light weight car,I tend to under sale and over deliver,it has been working well for us.We have several heavy gtos with over 750 rwhp with our clutchs so we should be able to harness most all the ctsvs out there..
    Who makes it? This is our on desighn sourced threw many manufactors
    If I get non adjusting clutch, is there anything special I have to do on install?No
    Or do I have to call you? Only if you would like to get a clutch!!lol..We are closed all next week,so if you let me know which flywheel you want we can get this out and wait for your great write up..
  13. #42
    Apr 2008
    Indiana
    4,913
    [quote=Hendrix-Engineering;1919018]
    Quote Originally Posted by lollygagger8 View Post
    Agreed!!!!
    I had a little trouble getting all that, so I'll be calling ya and getting your expert advice Thomas! Thank You Sir
  14. #43
    CTSV_510's Avatar
    Jan 2008
    West Chester, PA
    34
    4,455
    Agreed!!!!
    Who makes it?
    No
    hmm..
  15. #44
    nmaier2201's Avatar
    Aug 2007
    Chicago, IL
    1,415
    There IS a difference. moving to LS7 parts you MUST have the LS7 slave cylinder... or you'll end up needing to get a spacer fabricated for you... So if the hendrix solution is made up of LS7 compatible parts... you had better get the LS7 slave or have a fabricator on your speed dial
    (Of course I only know this from reading other clutch threads posted on this board... so if they were incorrect or if my memory is failing me... I could be wrong... but I don't think so)
    This is why I posted this thread so we can learn from the guys on here that have blazed this path already.
  16. #45
    atdeneve is offline Cadillac Owners Connoisseur
    Jan 2006
    2,114
    Wow, magic ink! It's readable!
  17. Remove Advertisements
