Results 1 to 13 of 13
Thread: Need help on More Perf. CAI Install
    Feb 2004
    85
    Unhappy Need help on More Perf. CAI Install
    I just finished installing the More Performance CAI and I'm concerned I didn't do it right. First of all, I had a h*ll of a time removing the rubber intake hose feeding air into the old airbox. The instructions describe two plastic rivets, but I had an additional two metal ones that were VERY difficult to get out. Next, the K&N filter doesn't really fit into the new airbox, it's just too big. Even at an angle, the side of the new airbox facing the engine has to bulge out to accomodate the filter, and the filter is sort of tightly wedged into place. Also, the MAF plug is very close to the pulley, and I can't really rotate the assembly any further to correct it. Is all of this normal? Did I get a bad kit? Help!! Thanks. Eric
    Edit: One more thing, it didn't seem necessary to use the hose clamp supplied with the K&N filter. I just used the clamp on the one end of the MAF sensor module that connects to the filter. Another screw up?
    BeagleBrains is offline Cadillac Owners Enthusiast
    Automobile(s): 1975 Seville; 2004 CTS V; 2011 CTS V Coupe
    Cedar Rapids, IA
    806
    Re: Need help on More Perf. CAI Install
    When I logged on to their site, the pictures appear to have the Cold Air Intake housing somewhat distorted. It looks as if the Air Filter is oversized and bulges the side of the box. Great to have this available. But, maybe they rushed production a little.
    Being conservative, I would use the supplied hose clamp per the directions. It fits snugly enough that this is unnecessary.
    trekster's Avatar
    trekster is offline Cadillac Owners Connoisseur
    Automobile(s): 04 CTS-V R.I.P.
    Apr 2004
    Downey,CA
    30
    1,234
    I thought I had the same problem...until I removed the one inch thick hose that's connected to the long tube(the long tube that connects to the air filter) . (The one with out the white looking filter) Then Success!
  5. #4
    Feb 2004
    85
    Quote Originally Posted by Black Beast
    How did that help that filter fit into the new air box? The instructions didn't say anything about removing anything other than the old airbox and the rubber intake hose? I WISH someone was at More Perf. on a Saturday to get some help.
  6. #5
    trekster's Avatar
    Apr 2004
    Downey,CA
    30
    1,234
    Quote Originally Posted by GTS21
    It allowed the one inch I needed so I can fit Cak. I removed the rubber intake hose since it's nothing.
  7. #6
    Mar 2004
    Charlotte, NC
    48
    49
    You need to use the hose clamps that are supplied. Shoot me a PM with detailed questions and I can answer them. We do not work on Saturdays.
    Amber
  8. #7
    Feb 2004
    85
    Quote Originally Posted by MorePerformanceInc
    Amber
    Amber; For some reason, the forum isn't allowing me to PM you. Any chance I could give you a call, or could you call me? I didn't use the clamp that came with the K&N filter, becuase the one on the MAF sensor looked the same. I must not be understanding the instructions.
    I have a total of three hose clamps installed, one on the end of the long intake tube, where it connects with the throttle body, the next at the other end of the long tube, where it connects with the MAF, and the third on the other side of the MAF, connecting to the rubber tube of the K&N filter sticking through the new airbox. The K&N filter came with a clamp, but where would it go?
  9. #8
    Feb 2004
    85
    bump
  10. #9
    sefa01's Avatar
    sefa01 is offline Cadillac Owners Enthusiast
    Automobile(s): 2009 CTS-V
    New Jersey
    931
    Talking Re: Need help on More Perf. CAI Install
    After seeing the problems encountered in this thread, I went to Cartek in NJ (listed under Cadillac CTS-V FAQ). 1/2 hour and $50 for a perfect installation.
  11. #10
    CadV is offline Cadillac Owners Connoisseur
    Automobile(s): V2
    Jul 2004
    TX
    40
    1,079
    If you pull hard enough on the rubber duct the rubber will stretch over the the three rivets. Just grab the rubber at the point of the rivet and do that for all three of them.
    Cliff
  12. #11
    Automobile(s): V2
    Jul 2004
    TX
    40
    1,079
    If you take your MAF and make sure the Air Flow arrow is pointing in the right direction the black rubber will slide off the part facing the air filter. To clarify this is the section after the black square piece. Once this is removed (you will see a round silver) the air filter will slide over this and you can use the clamp from the More Perf CAK.
    Cliff
  13. #12
    joshdctsv is offline Cadillac Owners Fanatic
    Automobile(s): '06 300c SRT-8
    Aug 2004
    Leander, Tx (Austin)
    429
    Iím going to pass along what I learned from the install. I am anything but mechanically inclined and this (like the Valentine1 install) scared the hell out of meÖ but it IS do-able for us non gear-heads.
    [Iím going to assume you have the provided instructions in front of you. The numbers correspond to those]
    [1,2] Ok, Iíll admit itÖ I have no idea what a throttle body or MAF sensor is. For anyone else in the same boat, the air tube comes out of the front/center of the engine. Where they meet is the throttle body. The air tube takes an immediate right turn from the engine towards the driverís side to the air filter. Just before it gets to the air filter box (plastic cover with several warning labels on it) there is an attachment to the tube with wire connections. This is the MAF sensor.
    [3] This is not easy with big hands. I used needle nose pliers to squeeze the tab in the middle that locks the connector on. Once that was clear, a flat head screwdriver was used to pry the two pieces apart.
    [6] The infamous rubber air intake duct. Cliff made a great suggestion to pull the rubber over the rivets. I used a flat head screwdriver to get between the rubber and the rivet to accomplish this. There are FOUR of these. 2 are engine side and have heads on the left (easy to get to), 2 are grill side and have heads (which you canít get to) on the right. Even on those 2, however, you can still pull the rubber off by stretching it out over the nuts (?) on the left hand side, though they are harder. I found that after getting the 2 engine side easy ones, I could push the rubber in towards the grill, and put my left hand in where the hood latch is to pull it in even further. This exposes the last 2 to work on.
    [8-14] I tried Moreís way and couldnít get the filter flange to fit over the tube. I would suggest you put the box in to see how it fits (you WILL have to bend it a bit, but itís quite resilient and bounces back) then take it back out and put everything together outside the car. This worked very well for me.
    [10] I would move this to last. I must have screwed/unscrewed this thing 3-4 times. Get everything where you like it, with all connections made and tight, then do this one. Also, my kit came with a washer. I assumed this went under the kit between it and the bodyÖthe screw you re-use has its own washer already. Word of warning, be careful not to drop it in the engine compartment. It took me 10 minutes to fish out after I did.
    [12] The K&N filter comes with a clamp. Remove it. You donít need it and it actually gets in the way if you leave it on (doesnít fit in the air box hole). Youíll use the MAF sensorís clamp to attach to the filter.
    [14] As stated above, I did this before I put everything all the way in. Big hands make it hard to get under and make this connection after itís all attached. Once installed, the wire connection is ~1 inch from the power steering pulley (!) but seems to be firmly/safely in place with the included clamp.
    More could/should post some install pics on their site, other than just 5 views of the end result. Also, when I did something similar with my 99 vette several years back, there was a ďbreak in/learningĒ procedure. Warm up, rev to 2000, wait 5 mins, rev to 3000, wait 5 mins, etcÖ I was surprised there was not anything similar described by More. Anyone have thoughts on this?
  14. #13
    Cal is offline Cadillac Owners Enthusiast
    Apr 2004
    NJ Shore
    763
    Quote Originally Posted by sefa01
    You should have ordered their head/cam while you were there!
    How did you like the shop, that place could fit inside a modest house, it's damn small!
  • You may not post replies
