| 2004-2007 Cadillac CTS-V Performance Mods Discuss all Cadillac CTS-V performance modifications here. Engine tunes, exhaust, intake, suspension and more. | Cadillac Forums: Cadillac engine mod Question
03-04-09, 09:26 AM
|  | Cadillac Owners Fanatic Cadillac(s): 05 CTS-V w/ warmed-over LS7 | | Join Date: Sep 2007 Location: N.C. Lowcountry Age: 63 | | | Re: Cadillac engine mod Question I took a long hard look at my LS6 and the V's engine bay and modded the LS6 straight to an engine dolly in my garage. I guess that I've gotten lazy but I'd rather swap engines that fool with any in-car mods.
With that said, and this is probably an age (and testosterone) factor, but it's better to under-cam than to over-cam and be miserable. Also, the cam timing events are more critical to driveability as the displacement decreases. What someone raves about for their 408 is going to be more radical in a 347.
NAF,
If you are building a 6.0 or larger and find that you have too much lope with the cam you initially started with, try an LPE GT11 cam. It's what they use in their CTS-V "package" cars. For driveability and a wide spread of power, it would be hard to beat. |
03-04-09, 03:53 PM
|  | Cadillac Owners Master Cadillac(s): '05 CTS-V | | Join Date: Jul 2004 Location: Elkridge, MD Age: 37 | | | Re: Cadillac engine mod Question As much as I'd like to think I'm the Bolt On king, the real one is JonCR96Z. He has right around 400 rwhp on his LS6 V.
A full bolt on would include:
1) CAI
2) Intake Tube (over the radiator (OTR)to be the true king)
3) 90mm Throttle body (ported)
4) 90mm Intake manifold (ported)
5) Long tube headers
6) Catless lead pipes
7) Highflow catback or cut-outs
8) Underdrive Harmonic Balancer
9) Electric waterpump
10) Proper dyno tune
I got about 380 on a conservative mustang dyno with my boltons (didn't have #6, #9 or an OTR)
Once you start messing with the valvetrain or the cam, you've (like me) has fallen off the Bolt On list. Same with N02.
JohnCR96Z is the true:
-Chris
P.S. once you REALLY start to mod, ignore the posts about the CAI, intake tube or Ported TB's not doing anything. They do, and will show gains (although not the crazy ammounts the vendors advertise).
__________________ 2005 CTS-V:No Roof|FG2|Corsa|UUC Shifter, B-Lines, Motor/Tran Mounts, Diff Bushings|LPE CAI|FFV IntakeTube|Hawk HP+ |Hotchkis Sways|Kooks 1.75 Coated LTs + cats|KARS III |Mamofied Fast90 + NW90|224/228 111+0 XFI/XE-R .609/.588|ATI 25% UD Pulley|YT 1.7" UltraLites|Melling HiFlow Oil Pump|Comp Chromeoly 7.425" PR's|Cloyes Hex Adjust Timing Set|Lucas 42# Flow Matched Injectors|Patriot Gold Xtreme Springs, Ti retainers, Super 7 locks|All ARP Fasteners|Mustang Dyno Tuned (SAE): 412rwhp / 380 rwtq |
03-05-09, 12:39 AM
| | Cadillac Owners Member Cadillac(s): 2005 Cadillac CTS-V | | | | | Re: Cadillac engine mod Question Thanks guys, this has really helped my paradigm of the ctsv engine mod thinking, by the way I just bought my v with 2 months left on the warranty and the clutch pedal was sticking at high rpm shift, I took it in and they yanked the tran to check the date code on the clutch and there was none so i get a whole new clutch kit for free, reason there was a TSB 05-07-31-001 "Clutch pedal does not return to up position during shifts at high engine rpms(replace clutch kit) april 8,2005" so anyone having this problem bring your V in and tell them about this service bulletin, cheers |
03-05-09, 12:51 AM
| | Cadillac Owners Fanatic Cadillac(s): Cadillac | | | | | Re: Cadillac engine mod Question Quote:
Originally Posted by korey I haven't really seen this question answered myself. What is the truth about bolt on and engine tune mods for the ls6. Is it simple math, intake-20hp,-exhaust-35hp,-program tune-20hp, after market intake manifold-35hp, if you added all this up would the ctsv pump out 110hp more? this doesn't seem to make sense to me. Has anyone actually done all the above and dynoed for results. What is the highest horsepower achieved with only bolt ons(not including supercharging) for the ctsv ls6 only. thanks | not to be a jerk,,,,,,but if you have to ask this leave it alone. Search "mod hell" if you still feel the need to "improve" things. If you cant do the work yourself, be very selective about who you choose to trust to do the work. Not much bang for the buck if you pay someone to do it. Also search John Hennessey/viper lawsuit |
03-05-09, 01:21 AM
| | Cadillac Owners Connoisseur Cadillac(s): 2005 Stealth Gray CTS-V, 2009 Black CTS-V | | Join Date: Jun 2005 Location: CA | | | Re: Cadillac engine mod Question From a guy who (questionably) put $25k+ into his '05 V...
Do it right and either:
1. Supercharge it
2. Heads/Cam it
3. NoS
You'll love those mods.
Save for dumping in a new motor, almost everything else is, "Ehh, that's cool, but not enough..." |
03-07-09, 02:35 PM
| | Cadillac Owners Fanatic Cadillac(s): 2004 CTS-V | | Join Date: Nov 2005 Location: Austin, TX | | | Re: Cadillac engine mod Question Guys, take my word for it.... ported L92s, while they flow a lot of air, do not make as much power as AFR heads. If I had it to do all over again I'd use the AFR 235s with the original FAST intake. I bet I'd be making a good 50 HP more than I am with ported L92s and an L76.
All that said, get some AFR 225s for your stocker, a FAST intake, some 1 3/4" headers and a good mild cam, you will see about 100HP over stock. Quote:
Originally Posted by CTS-Voodoo You ported the L92's?? Yeesh... I was looking at L92s as more than enough.. | | | Cadillac Discussion Tools | | |
Censor is OFF | | | |
