Mallett Shifter Install
Results 1 to 15 of 15
2004-2007 Cadillac CTS-V Performance Mods Discussion, Mallett Shifter Install in Cadillac CTS-V Series Forum - 2004 - 2007; Well, to me, replacing the stock shifter with a much better one is more important than 15-20 HP. I got ...
    rabid's Avatar
    rabid is offline Cadillac Owners Fanatic
    Automobile(s): CTS-V
    Apr 2004
    Columbia, Maryland
    302
    I got the shifter installed today. It took 2 hours (including taking pictures). Pretty easy and straight-forward.
    First, some pictures of the stock shifter and the Mallett shifter:
    This is the Mallett shifter:
    Here are the two shifters next to each other:
    Notice the differece in material between the two for the linkage end bushings; rubber for the stock and aluminum for the Mallett:
    The only other difference between the two is the length of the shift arm:
    So, the only difference between the Mallett shifter and the stock shifter is the aluminum bushings compared to rubber and the shorter shifter arm (exactly 1/2 inch shorter).
    In my opinion, if you have access to a lathe, you can make this shifter (arm and bushings) yourself in an afternoon. I only learned how to use a lathe this past February and I am confident I could make this shifter.
    The difference the Mallett Shifter made:
    The throw is shorter; maybe 1 inch from first to second.
    The shifter is only slightly more precise going into each gear, not what I expected at all. It is still difficult to get into reverse.
    So, is it worth $350? ($450-$100 core)
    No. It is worth maybe $150 to $200 ($200 cheaper). That is what I would have paid. That does not take into account the fact I could have made it myself.
    There is a difference in feel, but not nearly what I would expect for $350.
    I guess nothing will ever compare to the S2000 shifter I'm use to.
    I sent a detailed set of instructions to Reed (www.cadillacfaq.com). They should be up there soon.
    ctsvett's Avatar
    ctsvett is offline FAQ is your Friend
    Feb 2003
    California
    3,987
    Re: Mallett Shifter Install
    All,
    The instructions are up on "the FAQ".
    Direct link:
    Http://www.cadillacfaq.com/faq/answe...ter/index.html
    Or look under "tranny" at
    Everyone thank RABID for the awesome instructions!
    Reed
    http://www.cadillacfaq.com
    Cal
    Cal is offline Cadillac Owners Enthusiast
    Apr 2004
    NJ Shore
    763
    Every inch counts, they say!
    Sorry to hear it was not as good as you expected. Personally when I drove the S2000 back in 2000 I think it was, I couldn't stand the shifts, so to each his own.
    sefa01's Avatar
    sefa01 is offline Cadillac Owners Enthusiast
    Automobile(s): 2009 CTS-V
    New Jersey
    931
    Cal:
    Didn't you say youhave the Mallett shifter on order? If so, I'll be very curious when you put yours in. Also, how goes the FG2 shocks?
    BTW, I'm in North Jersey (near Exit 168 of the GSP). From your posts, I guess you're in Central Jersey.
    Steve Enright
    CTS-V
    Black/Black
    Cal
    Apr 2004
    NJ Shore
    763
    Quote Originally Posted by sefa01
    Cal:
    Steve Enright
    CTS-V
    Black/Black
    Yes, I do, I am probably going to have my dealer do the install. The FG2 are great. I think I toasted my rear end 2 nights ago on the GSP, so I won't be abusing them for a short while - taking the car in on Tues. For reference I am WAY south of you, exit 67 on the GSP.
    sefa01's Avatar
    New Jersey
    931
    Cal:
    Since I'm considering both the FG@ and the Mallett shifter (as well as the Corsa exhausts and the More cold air intake), I'll appreciate your input. I may even take the 100 mi run--if you don't mind--to see the FG2 and the Mallett after you have them in.
    I also know what you mean about the S2000 shifter. I have an M roadstar and it's smooth as silk.
    Finally, don't know if you saw my post about Tracquest (tracquest.com). I'm going to Watkins Glen Oct. 30-31 to put the V through its paces. Cost is $550 for the 2 days and includes instruction, insurance, etc.
    Steve Enright
    Cal
    Apr 2004
    NJ Shore
    763
    Steve,
    If you can't wait that long
    www.pdadrivingschool.com
    Has events all summer long. $200 a pop or so. I went to Pocono awhile back when they offered it. North Course will definitely test the speed and handling of the V. I did the East Course which is highly technical with 2 hairpins. Had a great time, wish I had the FG2 installed at that point so I could have hit it even harder.
    I haven't gone again due to time constraints and a little hesitation after seeing a couple people wreck at Pocono last time (noone near me, but still).
    Devil_concours is offline Cadillac Owners Connoisseur
    Jan 2003
    Alexandria, VA
    34
    3,684
    Quote Originally Posted by Cal
    i don't know. I've driven the s2k (i would have got one if i fit in there better) and it was one of the best shifters i've used.
    rabid's Avatar
    Apr 2004
    Columbia, Maryland
    302
    Well, as I mentioned, to me the S2000 is exactly what I am looking for and probably the best shifter I have ever used; nice short shifts, but more importantly, it is very precise without any trouble going into each gear.
    The Mallett shifter is shorter-which is good. It does make the throws a little more precise, but not anything near what I was expecting.
    Like I said, it does make a difference and to some, this difference is probably what they want in a shifter. But I can't stand the fact that everytime it takes three tries to go into reverse and I can't tell you how many times I was running hard and went to shift only to spend a good second trying to get it into gear.
    Good shifter, but not worth $350. In my opinion.
    Cal
    Apr 2004
    NJ Shore
    763
    The difficulty in shifting may be due to problems in the car, I know myself I had a problem with it trying to go into R instead of 5th at around 110mph and globed said he has had the same problem since day 1. I can get it into R on the first shot pretty much all the time.
    Someone else will be coming out with a more precise shifter I am positive; this was just the only option we had, and unfortunately it will not live up to everyone's expectations.
    DgtalPimp's Avatar
    DgtalPimp is offline Cadillac Owners Connoisseur
    Automobile(s): CTS-V CAI, CAM, BB X-pipe, Baer Extreme Plus
    May 2004
    Phx, Arizona
    48
    1,129
    R on the first time? Maybe a new form of racing.
    Dgtal
    lasstss's Avatar
    lasstss is offline Cadillac Owners Connoisseur
    Dec 2003
    Ellicott City
    2,873
    Rabid, would you sell me the shifter that you took out for $100 core? I can have my machinist make up a bunch of change parts for those that cant handle or dont want to handle the $350. I was also thinking of putting urethane in place of the rubber that slides out.
    rabid's Avatar
    Apr 2004
    Columbia, Maryland
    302
    Quote Originally Posted by lasstss
    Funny you mention it; I was thinking about machining the couple different parts and selling it. But I will be happy to sell you the stock shifter the way it is, for, $450. Hahaha. j/k Write me back here or at rabid355@yahoo.com and let me know.
  16. #14
    jim mitchell is offline Cadillac Owners Member
    69
    Couple hour install...hummm. Sounds like you didn't have to drop the tranny - did you? If so...you're fast!
  17. #15
    rabid's Avatar
    Apr 2004
    Columbia, Maryland
    302
    Quote Originally Posted by jim mitchell
    With the transmission, I just unbolted the driveshaft from the output shaft on the tranny with 3 bolts. Then there is a cross brace that holds the tranny up;
    remove that (8 bolts) and the tranny lowers with a jack (carefully).
    The exhaust was simple and straightforward to remove (no rust or nothing). The drive shaft had a few bolts, and the trans had the brace/bracket.
  18. Remove Advertisements
