Official Differential Bushing Puller Loan-A-Tool Signup.
Page 1 of 17 1234567891011 ... LastLast
Results 1 to 15 of 242
2004-2007 Cadillac CTS-V Performance Mods Discussion, Official Differential Bushing Puller Loan-A-Tool Signup. in Cadillac CTS-V Series Forum - 2004 - 2007; OK. After speaking with Luke at Lindsay, UUC is shipping out bushings to him within a day or two and ...
    PISNUOFF Guest
    OK. After speaking with Luke at Lindsay, UUC is shipping out bushings to him within a day or two and he should have some out to us within a week. I've had a bushing removal tool made at a die shop and I'll be picking it up tomorrow. I'll work out any bugs this weekend while pulling mine out. This one will be available for 'loan' soon after and I'll be having more made right after a final design is done. How many will depend on how many people sign up on here to use it. Here's how I plan on doing the loan-a-tool program:
    1. I'll keep the list and contact people with an approximate date when a tool is available.
    2. When one is available, I'll contact the next person in line and request $50 via Paypal. Once the $50 is received, I'll ship the tool out via UPS ground.
    3a. Use the tool and return to me within 2 weeks after receiving it and I'll refund $30 via Paypal.
    3b. Use the tool and return it to me within 4 weeks after receiving it and I'll refund $20 via Paypal.
    3c. Keep the tool and use it longer than 4 weeks and you bought it for $50. Unless prior arrangements are made through me.
    Please let me know if you're interested. First-come-first-serve from a list created through this thread so post up.
    trukk's Avatar
    trukk is offline Cadillac Owners Master
    Automobile(s): '05 CTS-V, '12 CTS-V Manny Vagon
    Jul 2004
    Elkridge, MD
    44
    6,063
    Re: Official Differential Bushing Puller Loan-A-Tool Signup.
    Great idea!
    -Chris
    P.S. gald mine is done already
    2005 CTS-V:No Roof|T2+Eibachs|Corsa|UUC:Shifter, 2pc rotors, B-Lines, Motor/Tran Mounts, Diff Bushings|LPE CAI|FFV IntakeTube|Hotchkis Sways|Kooks 1.75 Coated LTs+cats|KARS III |Mamofied Fast90 + NW90|224/228 111+0 XFI/XE-R .609/.588+Dual Springs|ATI 25% UD Pulley|YT 1.7" UltraLites|Melling HiFlow OP|Cloyes Hex Adjust Timing Set|Lucas 42# Flow Matched Injectors|Katech LS9X Clutch Mustang Dyno Tuned (SAE): 412rwhp / 380 rwtq
    2012 CTS-V:No Roof|Wagon|M6|Recaros|<-- SOLD
    2014 ATS: 2.0T-M6
    lollygagger8's Avatar
    lollygagger8 is offline Cadillac Owners Connoisseur
    Automobile(s): Platinum 2004 CTS-V
    Apr 2008
    Indiana
    4,913
    If you get it to work just fine, I'm in....I'll find someone with a big enough (heated) garage to do this in since it's 9 degrees out!
    Taking pics of you using the actual tool on the bushing would be appreciated!
    Thanks Man and kudos for getting this off the ground!!!!!
    DILLIGAF's Avatar
    DILLIGAF is offline Cadillac Owners Connoisseur
    Automobile(s): 04 ctsV platinum,maggied,rt cats,headers,corsa,stealth tune
    Mar 2005
    kansas
    52
    4,750
    Could you post a pic of the tool?Surely I have something at work that I could adapt.
    NormV is offline Cadillac Owners Connoisseur
    Automobile(s): XTS VSport-550+ lb-ft of torque, ATS 2.0T AWD HPTuners tuned
    Jun 2007
    OH-IO!
    2,654
    I just removed and install and modified Energy Suspension bushing. If your work below 50 degrees a little heat on the aluminum helps.
    Norm
    MicoJones is offline Cadillac Owners Member
    Automobile(s): 05 cts \/
    Mar 2008
    Boston
    25
    I'm in if the tool works out...keep us posted
    PISNUOFF Guest
    Removed the bushing tonight while the diff was in the car. The tool worked perfectly and I didn't even remove the hub or half shaft. I already had the exhaust off which made a lot more room. I just dropped the driveshaft, popped the right side half shaft off the snap ring in the diff, removed the front diff bushing bolt and the right side rear bushing bolt completely, loosened the left side rear bushing and used the removal tool to push/pull the bushing out.
    Slithering_Joe's Avatar
    Slithering_Joe is offline Cadillac Owners Enthusiast
    Automobile(s): '05 CTS-V, Powered by Chevrolet
    Oct 2008
    N-NJ
    46
    835
    No pics of the tool?
    What tool would the dealers use?
    PISNUOFF Guest
    Quote Originally Posted by DILLIGAF View Post
    Quote Originally Posted by Slithering_Joe View Post
    Search - EWILL posted a pic of the GM one. GM charges somewhere around $250 to $300.
    You can loan the one I had made for $20. It's not like I'm making any money off this. It costs me $5 for a box and about $10 to ship each time. The extra $5 is to try to recover some of the cost of the tool I had made. You can guess how many times I have to loan each one out to recover that money.
    Oct 2008
    N-NJ
    46
    835
    Looks like I found it. Thanks.
    heavymetals's Avatar
    heavymetals is offline Cadillac Owners Master
    Automobile(s): 05 maggied CTS-V, 03 maggied Z06
    Nov 2004
    8,788
    Put me on the list.
    Thanks for doing this.
    UnsafeAtAnySpd's Avatar
    UnsafeAtAnySpd is offline Cadillac Owners Connoisseur
    Automobile(s): '04 CTS-V, '07 SRT8 Jeep, '86 Fiero
    Aug 2007
    Arlington, VA
    31
    1,647
    Put me down.
    ctsv154's Avatar
    ctsv154 is offline Cadillac Owners Connoisseur
    Automobile(s): 04 CTS-V with a little hp persuasion device
    Oct 2007
    32
    3,824
    I'll hop on the band wagon too.....
  16. #14
    thebigjimsho's Avatar
    Automobile(s): ZIP
    In the barrel of a gun...
    51,885
    Oooooooooooohhhhh, bubble wrap. Gimmie some. *pop* *pop* *poppopopoppp*
  17. #15
    ewill3rd is offline Cadillac Technician
    Automobile(s): none
    Nov 2005
    WOODBRIDGE, VA
    49
    11,051
    Believe it or not, popping those things gets old after a while.
    I don't even notice it anymore.
    Sometimes it is fun to put it under the carpet runners in the hallway and watch...
  18. Remove Advertisements
