06 difficult to get in reverse
Results 1 to 13 of 13
2004-2007 Cadillac CTS-V Performance Mods Discussion, 06 difficult to get in reverse in Cadillac CTS-V Series Forum - 2004 - 2007; Ended up sitting in my car for at least 10 minutes over lunch the other day trying to force it ...
    SLPR 6.0L is offline Cadillac Owners Fanatic
    Automobile(s): Cadillac
    Aug 2007
    292
    Ended up sitting in my car for at least 10 minutes over lunch the other day trying to force it into reverse, parked front end into a fence. I found that if I tried to force the stick into any of the gears without the clutch pedal depressed the gear box would not grind.
    I finally forced the car into reverse (clutch pedal engaged) with enough pressure, that when it went in gear, I busted my knucle on the open ash tray, turning it purple. I though I was going to break the stick.
    Earlier in the week I noticed it was becoming difficult to get the car in to the various gears.
    On the way home for lunch after getting the car on the road, I did not take the time to finess the car into gear, my hands were like Easter hams. Dealer called and is replacing my "clutch". I need to call and get the specifics. I have been complaining for at least a year that the clutch pedal has been difficult to depress and that the slave cylinder needs replaced. Would a defective slave cylinder cause the failure, or is it a bad sycro/rubber bushing?
    What would a UCC shifter cost me?? Could I work out free installation?
    Sorry for lenghty post
    CtsVrod's Avatar
    CtsVrod is offline Cadillac Owners Connoisseur
    Automobile(s): 05 CTS-V / 06 Escalade
    Oct 2007
    So Cal - Agoura Hills
    34
    1,059
    Re: 06 difficult to get in reverse
    First and Reverse are pretty tricky with these Cars... Most of the Time I have to roll forward a bit to loosen up the Synchro's and it will slip into Reverse, I also have issues with it kicking out of gear in reverse... I guess I should take it into the Dealer, and get a Clutch as well!!
    UUC will make shifting much better, and smoother, but wont help your Reverse issue, Def. worth the $$ though... Also get the bushings, if anything those will make a difference.
    rand49er's Avatar
    Jan 2005
    South Lyon, MI
    68
    13,833
    Your car may have the clearance issue that some have had. Can't remember if just a clutch replacement is all you need or not. Sounds like they're finally on it, though. Good for you.
    As mentioned, shifter won't make a difference in getting into reverse, but it sure will make a difference in driving the car.
    Albertan is offline Cadillac Owners Enthusiast
    Automobile(s): 2004 Cadillac CTS REDLINE 2006 CTS-V Infared
    Oct 2006
    Calgary, Alberta
    67
    872
    Gee, sounds like my problem of last year. Except my clutch pedal was never hard to depress. If it goes into gear when the engine is turned off and you depress the clutch pedal, I would say the clutch isn't releasing enough. Mine was like that when I picked it up with 125 miles. On my car the pressure plate wasn't flat. First dealer said I had burned out the clutch and wanted to charge me for everything. Went to another dealer and inside of 5 minutes they said there was a problem and replaced flywheel, clutch disk, pressure plate and slave cylinder all under warranty.
    SFBayV is offline Cadillac Owners Fanatic
    Oct 2008
    The City
    125
    Quote Originally Posted by SLPR 6.0L View Post
    Hi,
    Check your clutch reservoir fluid level. I had a similar issue about 5 months ago, and upon checking the fluid level, I found it to be low. After refilling it, it worked fine. You may have a leak at the slave cylinder or somewhere between it and the reservoir itself. It's more than worth it to pop the hood and check it out.
    Cory
    lollygagger8's Avatar
    lollygagger8 is offline Cadillac Owners Connoisseur
    Automobile(s): Platinum 2004 CTS-V
    Apr 2008
    Indiana
    4,913
    Shift into 4th gear before you try going into reverse......works every time.
    smashn808 is offline Cadillac Owners Fanatic
    Automobile(s): 2009 Radiant Silver CTS-V, 6MT
    Aug 2008
    Bay Area 707
    191
    Same here. I just go from 4th to reverse now eveytime out of habit.
    50 4Ever's Avatar
    50 4Ever is offline Cadillac Owners Connoisseur
    Automobile(s): 2007 CTS-V (Thunder Grey)
    Dec 2005
    Sacramento Kalifornia
    67
    1,667
    I had a similar problem a couple of years ago but the clutch was never hard to depress. Dealer replaced almost everything, the problem was that the flywheel was 0.020" too deep letting the clutch rub on the flywheel and turning the internals of the tranny. When the engine was off the car would shift fine, but start the engine and it was impossible to get into reverse and it was hard to get into 1st. Since the flywheen, clutch and slave were replace I don't have any kind of problem getting it into gear...
    Jimmy3 is offline Cadillac Owners Member
    Automobile(s): 06 cts
    Sep 2012
    tulsa
    36
    really will this work on a cts base ?
    PISNUOFF Guest
    Yes, flush the clutch fluid.
    Z06-V's Avatar
    Z06-V is offline Cadillac Owners Member
    Jul 2013
    Syracuse, UT
    9
    I always do 3rd first then to reverse and it works pretty good for me. Just like smashn808 said with the 4th to reverse.
    Becker's Avatar
    Becker is offline Cadillac Owners Fanatic
    Automobile(s): 2006 black with tan V
    May 2013
    31
    391
    I did have a reverse lockout solenoid fail on an LS1 Transam, but I was used to over coming the spring pressure to get it in reverse. I never have had to use two hands though. I have yet to experience this but I know my clutch fluid is in need of a flush soon keep us posted OP after the clutch fluid flush
    Charlie Costello is offline Cadillac Owners Member
    Automobile(s): 2005 Red CTS-V and a Silver 2005 CTS-V
    May 2006
    Medina, Ohio
    75
    I had the same problem for the last 50k miles. Mike Yeager said the dual mass flywheel was the issue. Replace everything with the LS7 set up from him. What a joy to drive again. Wished I would have done it 2 years ago when I had to have the trans rebuilt. Love to drive it again.
  16. Remove Advertisements
