Go Back   Cadillac Owners Group > Current Cadillac Vehicle Discussion > Cadillac V-Series Forums > Cadillac CTS-V Series Forum - 2004 - 2007 > 2004-2007 Cadillac CTS-V Performance Mods
2004-2007 Cadillac CTS-V Performance Mods Discuss all Cadillac CTS-V performance modifications here. Engine tunes, exhaust, intake, suspension and more.
Cadillac Forums: Too much llift???
Old 12-15-08, 04:05 PM
Naf Naf is offline
Cadillac(s): 2005 CTS-V, 2005 Escalade EXT, 2007 Escalade EXT
View Naf's Photo Album
Casino Cash: $12131
Too much llift???
I did some talkin with my friends and i found out my GTS cam will take an additional 2 weeks before delivery so tats a total of about 3 weeks for my Aussie cam.
Didnt want towait that long so i made a few phone calls and some options were offered to me...
GT2-3
GT11
CCA 444
ESC custom
And so on...
I said no to the GT2-3 for everyone here that i know is runnin it...Couldnt have that. So i discussed about the other cams offered. The CCA 444 was a little to lopie for me. Hear a car with it here with similar setup...
The ESC had a month lead time, and well like my other cam i declined...
I talked to my friend in LPE and he suggusted the GT11, i asked if iwould have any issues with clearance, but he said no, and i keep my stock idle sound. The only part i find uncomfortable is the massive lift. 631 644 THATS MASSIVE. i snooped around LS1tech, and some people are runnin this type of cam...
I talked with my friend here and i still couldnt get over the amount of lift...I am freakin out here...
Help, someone here must have run this cam or similar...
  #2 (permalink)
Old 12-15-08, 04:08 PM
Naf Naf is offline
Casino Cash: $12131
Re: Too much llift???
What i forgot to mention was i would like my car out of the shop by X-mas...Want to drive down to Dubai for a little track time. But i am not closin up the engine without puttin in a cam...This is the whole reason for the start of this little tear down. CF fenders, and rocker panels...DHL dropped the ball on my CF rocker panels so i am waitin till they show up before i remove my stock ones....Sorry buddy, you will get them soon...
  #3 (permalink)
Old 12-15-08, 04:28 PM
trukk's Avatar
Cadillac Owners Master
Cadillac(s): '05 CTS-V
View trukk's Photo Album
Casino Cash: $138365
Naf,
Make sure you mention that you have higher compression heads (I assume they hgave been milled a bit), and let them know what sized head gasket you have as that will affect how big of a cam you can get without flycutting.
That sounds like an awefull lot of lift, however I'd be most concerned about what type of lobes that sucker has. If it has a very agressive lobes (I.E. the ramp rate is very high), it will be hard to control unless you use very strong springs.
If you get supper agressive with your lift and ramp rates, then you are going to need to swap valve springs more often. If you don't put a lot of miles (er KM's) on the car then it doesn't matter as much. I'd also consider getting a nice dual spring set, just for the added piece of mind of having the 2 springs. If you do break a spring, with the duals you will usually have enough time to pull over and shut the car off before the engine eats your valve ($$$$), whereas with a beehive single spring, the valve gets chomped ASAP.
If I were you I'd consider working with Partick G over on LS1TECH and have him spec out a custom ground cam for you. You can get the grind done by Lingenfleter (since you know someone there) fairly easily. They ground mine for me. If you get a custome cam, you can get exactly what you want. Especially given that you want it to be 'different' but not also scare away every girl in the area. Just tell Patrick what you want.
Glad you came around to the idea of getting a cam
-Chris
2005 CTS-V:No Roof|FG2|Corsa|UUC Shifter, B-Lines, Motor/Tran Mounts, Diff Bushings|LPE CAI|FFV IntakeTube|Hawk HP+ |Hotchkis Sways|Kooks 1.75 Coated LTs + cats|KARS III |Mamofied Fast90 + NW90|224/228 111+0 XFI/XE-R .609/.588|ATI 25% UD Pulley|YT 1.7" UltraLites|Melling HiFlow Oil Pump|Comp Chromeoly 7.425" PR's|Cloyes Hex Adjust Timing Set|Lucas 42# Flow Matched Injectors|Patriot Gold Xtreme Springs, Ti retainers, Super 7 locks|All ARP Fasteners|Mustang Dyno Tuned (SAE): 412rwhp / 380 rwtq
  #4 (permalink)
Old 12-15-08, 05:15 PM
lollygagger8's Avatar
Drive It. Break It. Build it Better
Cadillac(s): Platinum 2004 CTS-V
View lollygagger8's Photo Album
Casino Cash: $7733
Naf, post some pics of your V in Dubai
EDIT: by that indoor ski resort if possible......hell any pic downtown would be badass...they have some awesome buildings!
Monster Stage 3 Clutch & 18 lb flywheel, B&B headers w/ hi flow cats, B&B xpipe & catback, Lingenfelter CAI, UUC Gen II Motor Mounts/Trans Mount/Shifter/Diff Bushing, Hotchkis Sways, BMR Trailing Arms & AWH Bushings, Hawk Pads, GM Assy Wheels, Stock Wheels, Drilled GM Rotors, Hendrix Axles, CAGS Elim, '06 Diff, Clear Fogs/Sidemarkers, Tuned by Brent @ EPP on mustang dyno @ 378rwhp/366tq
  #5 (permalink)
Old 12-15-08, 11:35 PM
JonCR96Z's Avatar
Cadillac(s): BANK OWNED!! CTSV & EXT
View JonCR96Z's Photo Album
Casino Cash: $3297139
Valve event timing is more important to PTV clearance than lift measurements. I also agree with getting custom speced cam for your application.
Jon
  #6 (permalink)
Old 12-15-08, 11:57 PM
Cadillac(s): Cadillac
View suppercaddy1's Photo Album
Casino Cash: $1970
yes that is alots of lift if u have a stock engine,it might be hard to tune,u might need bigger fuel injectors and a maf sensor that will read more air,if ur engine is build for low comp than u will be fine
  #7 (permalink)
Old 12-16-08, 12:39 AM
Naf Naf is offline
Casino Cash: $12131
Originally Posted by trukk View Post
Naf,
-Chris
Chris,
The engieers at LPe know everything i have in my block...I have the MLS head gaskets, with HC heads. I even informed them of my cr which is at 11.59:1
I am goin with the double springs from cca...921s if i am not mistaken...
Now would you like to see the pretty girls in the picture for they are extra charges...Or just the buildins?
As mentioned above, i am pretty high on the cr. I called my friend again just to reconfirm and his re-assured me that plenty of people runnin a similar setup have installed this cam with no worries...
Our cars already sound like sewin machines, so i am interested to see how much more it is amplified...
Worse case i take out the cam...
As for tunin my friend at LPe is gonna hep me out...Since i am basically runnin their top end...And intake kit, and i bought most of my mods from them...
  #8 (permalink)
Old 12-16-08, 12:30 PM
View atdeneve's Photo Album
Casino Cash: $9348
Naf, have you had a chance get a run on a dyno yet? Curious as to what numbers you're puttin down and your gains seen.
  #9 (permalink)
Old 12-16-08, 01:40 PM
Naf Naf is offline
Casino Cash: $12131
i tired but my car doesnt liked the dyno...Gave me 9 degrees of Knock retard, and the torque curve didnt work, my PS fluid over flowed, and i did see 325hp at 4500 or 5000 but i dont remember...
I took it on the road with the exact same tune and i saw less then 2 degrees of knock retard at the same rpm...
What can i say she doesnt like to be caged or tied down like me...I have to admit though, i can feel the increases. I had a good tune Stock stock. Then when i had the cai headers and catback it felt great...When i put the heads, intake manifold, and no tune she felt a little weak...Fixed up the tune a bit and it openned up...
Now with the new cam i feel i aught to get 420ish hp with about 400ish of torque. and a nice flat curve to boot. This is what a friend of mine here said about his GT11. He is runnin a 408 with 72ccAFR heads and ported fast 92 intake and made 485/475 with a vertual flat curve.. He is happy...
  #10 (permalink)
Old 12-16-08, 06:14 PM
Cadillac Owners Enthusiast
Cadillac(s): CTS-V
View Bueller's Photo Album
Casino Cash: $5664
I doubt you will get 95 hp out of a cam and retune even if this is the one part your motor needs to work well.
You're building a motor that will have a steep curve with nice peak power and less mid and low range, not a flat torque curve. We all can't wait to see the graph.
Enjoy. Lets see some pics...
  #11 (permalink)
Old 12-17-08, 02:30 PM
JonCR96Z's Avatar
9 degrees of timing could be worth 50 rwhp easily. Not saying that is the case here, but it is possible.
  #12 (permalink)
Old 12-18-08, 12:12 AM
Naf Naf is offline
Casino Cash: $12131
I have to say its all in the tune...I have everything that may point to peak, but to be honest you never know...
Heads are 250cc intake runnners with 85cc exhaust with 60.7cc combustion chambers
FAST 90/90
GT11
LPe/Volant intake kit (May change to OTRCAI)
1 3/4 SW headers
Ti Corsa Catback 2.5"
  #13 (permalink)
Old 12-18-08, 10:42 AM
trukk's Avatar
FAST 90/90
GT11
1 3/4 SW headers
It's all about the combination, or which the tune is a part.
-Chris
P.S. There is no such thing as an OTRCAI, and anyone that says they have one is full-o-crap....yours truely the bolt-on
  #14 (permalink)
Old 12-19-08, 02:32 AM
Naf Naf is offline
Casino Cash: $12131
You would be surprized what i can find talkin to my friends...
Its all about information and bein in the right place at the right time...
Give me some time, i will get you pics of this mysterious OTRCAI...
  #15 (permalink)
Old 12-19-08, 11:50 AM
trukk's Avatar
LOL, the OTRCAI is just a dig at Jon, who has one.
I wasn't joking about eh combination though. You need to really sit down and talk with someone and really plan out your mods. You are all over the place.
-Chris
llift
Censor is OFF
