Go Back   Cadillac Owners Group > Current Cadillac Vehicle Discussion > Cadillac V-Series Forums > Cadillac CTS-V Series Forum - 2004 - 2007 > 2004-2007 Cadillac CTS-V Performance Mods
2004-2007 Cadillac CTS-V Performance Mods Discuss all Cadillac CTS-V performance modifications here. Engine tunes, exhaust, intake, suspension and more.
Cadillac Forums: Engine Stumbles when turned off...
Old 12-04-08, 10:26 PM
Cadillac(s): Cadillac
View hevnbnd's Photo Album
Casino Cash: $1830
Exclamation Engine Stumbles when turned off...
Ok, When I shut of the car i get a stumble like I get with my old 77 carb. truck. What causes this? How can I fix it? Thanks
  #2 (permalink)
Old 12-04-08, 10:30 PM
CTSV_510's Avatar
<----- go ahead and stare
Cadillac(s): Maggied '05 CTS-V
View CTSV_510's Photo Album
Casino Cash: $14580
Re: Engine Stumbles when turned off...
Motor mount possibly, its a common issue. Look for fluid leakage on the lower driver side of the motor.
Authorized Vendor, what do you sell?
05 CTS-V / maggie 2.8 / b&m shifter & uuc bushings / gto shift knob / kooks lts 1 3/4 + cats / magnaflow / k&n cai / fg2 shocks / hotchkis sways / hawk hps / 265|40 bfg kd / ngk tr6
434 rwhp / 412 rwtq
..........are you new to the forum? READ THIS and then TRY THIS.
  #3 (permalink)
Old 12-04-08, 10:34 PM
Casino Cash: $1830
http://www.cadillacforums.com/forums...dio-knobs.html
So a motor mount can cause it to stumble? That is odd. It is like it is cutting out every time after I turn it off. I had it up on my lift yesterday and did not notice any leaks other than the big one I caused when I missed my oil pan.
  #4 (permalink)
Old 12-04-08, 10:44 PM
ctsv154's Avatar
Cadillac(s): 04 CTS-V with a little hp persuasion device
View ctsv154's Photo Album
Casino Cash: $15597
Well the V's stock flywheel is very heavy (I think Luke said like 47-57 lbs). So take that into consideration. If the mounts are bad, which 99% of the time they are, the heavy flywheel makes the dieseling or stumbling worse. Also, sometimes you cant see the leak. Mine was replaced at the dealer less than a year ago and it still looked new but it was completely torn all the way around it at the top under the heat shield. Put a set of UUC mounts and an aluminum flywheel and it will completely go away.
  #5 (permalink)
Old 12-04-08, 10:45 PM
CTSV_510's Avatar
Casino Cash: $14580
Well our heavy dual mass flywheel takes time to come to a stop, and when the motor mounts have gone, it shakes the motor around. That may be what you're experiencing. Mine was pretty bad, making a dieseling sound for a few seconds when I turned the key. When I had my driver side mount replaced it went away.
Luke has some badass UUC mounts that won't bust like the fluid-filled stock ones.
  #6 (permalink)
Old 12-05-08, 11:37 AM
lollygagger8's Avatar
Drive It. Break It. Build it Better
Cadillac(s): Platinum 2004 CTS-V
View lollygagger8's Photo Album
Casino Cash: $7843
+1 on the motor mounts.
The drivers side usually goes bad first. Look for a greenish or brownish deposit around the mount area. Most of the time it leaks out onto the side of the oil pan. Could be mistaken for an oil leak if it weren't for the color.
If and When you find this, get the UUC mounts from Luke.....that way you only have to replace the mounts ONCE.
Monster Stage 3 Clutch & 18 lb flywheel, B&B headers w/ hi flow cats, B&B xpipe & catback, Lingenfelter CAI, UUC Gen II Motor Mounts/Trans Mount/Shifter/Shifter Bushings/Diff Bushing, Hotchkis Sways, BMR Trailing Arms & AWH Bushings, Hawk Pads, GM Assy Wheels, Stock Wheels, Drilled GM Rotors, Hendrix Axles, CAGS Elim, '06 Diff w/updated pinion, Clear Fogs DDM bulbs, Clear Sidemarkers, CTS center console, Tuned by Brent @ EPP on mustang dyno @ 378rwhp/366tq
  #7 (permalink)
Old 12-05-08, 11:46 AM
BacDoc's Avatar
Cadillac Owners Enthusiast
View BacDoc's Photo Album
Casino Cash: $10490
You bought a diesel.
  #8 (permalink)
Old 12-05-08, 12:22 PM
Cadillac(s): Cadillac cts-v
View smoothq's Photo Album
Casino Cash: $7525
Are your motor doesnt say cummins on it....
  #9 (permalink)
Old 12-05-08, 07:45 PM
ProdigalSON's Avatar
Cadillac(s): BLACK 05' CTS-V
View ProdigalSON's Photo Album
Casino Cash: $1180
I have this same issue in my 05 V that I bought and when we had it up on a lift we noticed a slight leak that sounds like the one you guys are describing. Going to be ordering from Luke soon.
  #10 (permalink)
Old 12-05-08, 08:50 PM
View bigbadboss101's Photo Album
Casino Cash: $1835
I spotted a leak but I thought it was ps fluid. If it's not oil, what is it leaking? I check oil frequently and it's fine.
  #11 (permalink)
Old 12-05-08, 08:58 PM
CTSV_510's Avatar
Casino Cash: $14580
The motor mounts are leaking...they're not solid mounts, they're rubber with fluid inside. They end up cracking and spilling fluid all over the side of the oil pan.
Tags:
engine, stumbles, turned
Censor is OFF
