Go Back   Cadillac Owners Group > Current Cadillac Vehicle Discussion > Cadillac V-Series Forums > Cadillac CTS-V Series Forum - 2004 - 2007 > 2004-2007 Cadillac CTS-V Performance Mods
2004-2007 Cadillac CTS-V Performance Mods Discuss all Cadillac CTS-V performance modifications here. Engine tunes, exhaust, intake, suspension and more.
Cadillac Forums: 04 Clutch replacement Questions
Old 11-16-08, 02:50 PM
View pjcnlv's Photo Album
Casino Cash: $340
My 04 is right at 50000 miles and I noticed the clutch being a bit soft in the morning. Unfortunately I found the clutch fluid reservoir pretty much dry.
I imagine it's a good time to change the dick, pressure plate out and resurface the flywheel.
The car is pretty much stock, with only a Corsa exhaust as an add-on. I don't expect to much more in the performance area as I am happy with the car as a daily driver.
So, what is the "best bang for the buck" on a replacement clutch kit?
Also, should I replace the slave and master cylinder in the process?
Also, I am looking for a performance shop in Las Vegas that can be recommended for V work. I would like to try a few of the aftermarket traction kits.
  #2 (permalink)
Old 11-16-08, 04:15 PM
ctsv154's Avatar
Cadillac(s): 04 CTS-V with a little hp persuasion device
View ctsv154's Photo Album
Casino Cash: $15572
Re: 04 Clutch replacement Questions
Your car has a dick!? Thats pretty cool!
  #3 (permalink)
Old 11-16-08, 04:20 PM
ctsv154's Avatar
Casino Cash: $15572
On a more serious note, I would replace the slave while your in there. Cant really give much on options for clutches but I have a Fidanza LS7 flywheel with stock LS7 disk and pressure plate. You will need a spacer for the stock slave or McLeod makes one that you can order with the right piston. The stock disk and pressure plate is also good with the UUC flywheel.
  #4 (permalink)
Old 11-16-08, 04:26 PM
Casino Cash: $340
Damn spell check missed that one.. SHEESH!!!
  #5 (permalink)
Old 11-16-08, 07:58 PM
ctsv154's Avatar
Casino Cash: $15572
Also, I dont believe anybody makes a good performance oriented clutch disk and pressure plate for the stock dual mass flywheel. A stock replacement would probably be the best, or better yet go the way of many and get a single mass like the LS7 or the Vette LS6.
  #6 (permalink)
Old 11-16-08, 08:46 PM
PISNUOFF's Avatar
Cadillac Owners Enthusiast
Cadillac(s): 2007 CTS-V
View PISNUOFF's Photo Album
Casino Cash: $9210
A stock GM LS1 slave has the proper piston length also.
  #7 (permalink)
Old 11-17-08, 06:40 AM
ctsv154's Avatar
Casino Cash: $15572
Is that for the LS6 Z06 clutch or will it fit the the LS7 as well?
  #8 (permalink)
Old 11-17-08, 12:14 PM
Rey Rey is offline
View Rey's Photo Album
Casino Cash: $5935
The stock Z06 clutch/flywheel assembly is a drop in fit. All you need to do is enlargen the bell housing hole for the clutch line and add a spacer. TPIS and Katec sell the spacer. I have had this combo now for over 60K miles. Car feels 500 lb lighter. Clutch action is lighter. It is hard to measure the change on a dyno, but it feels like 25 hp or so. You are removing 30 lb of reciprocating weight.
I don't know if the Z07 assembly is any better or fits as well. The Z06 flywheel with clutch part number is 12570806 - about $413 at GM Parts Direct.
The part number for the LS7 clutch alone is 24238412.
Conclusion: there are no disadvantages to this change. The car feels "stock". Clutch engagement feels just fine. You will be very happy with this change.
  #9 (permalink)
Old 11-17-08, 12:42 PM
benelliwang's Avatar
Cadillac(s): CTSV, C5TT, STi, 70Camaro
View benelliwang's Photo Album
Casino Cash: $6567
If it is a bit soft, it could be that you just need to bleed it. But Caddie designed the bullshit bell housing such that it is impossible to bleed it properly, hence people use the suck it up from the reservoir and pump method.
Here are some options:
OEM pressure plate and disk, but you still have the POS dual mass flywheel.
LS1/LS6 flywheel, disk, and pressure plate. I went this route because there are so many after market parts for it. I decided on a Kartec clutch rated at 700hp. But you need to buy a spacer for the slave and since I also used a LS6 slave, I had to modify the master's line to make it work. I also added a speed bleeder.
LS2/LS7 flywheel, disk, pressure plate, and slave. Lindsay has a set up for you.
I am from Vegas and I did the work myself but I am no mechanic. I have a friend who built my twin turbo Corvette what can do the job, pm me if you are interested and I will give you his number.
  #10 (permalink)
Old 11-17-08, 01:03 PM
PISNUOFF's Avatar
Casino Cash: $9210
Slave part number to switch to the LS7 is 24237634. Luke also sells this with his LS7 kit.
  #11 (permalink)
Old 11-17-08, 02:46 PM
nmaier2201's Avatar
Truck Motor FTW!
Cadillac(s): 2006 CTS-V
View nmaier2201's Photo Album
Casino Cash: $504234
Before you do antying flush the clutch fluid with a good dot4 and see if that helps any. My clutch felt loads better after getting some new fluid in there. If that doesn't do anthing your only out 15 bucks and you can really have some fun getting a LS7 clutch with a better flywheel.
Tags: , ,
clutch, questions, replacement
Censor is OFF
