Headers - Page 3
Page 3 of 16 FirstFirst 1 2 3 4 5 6 7 8 9 10 11 12 13 ... LastLast
Results 31 to 45 of 226
2004-2007 Cadillac CTS-V Performance Mods Discussion, Headers in Cadillac CTS-V Series Forum - 2004 - 2007; My Kooks included an extension. And, "Yeah," you'll need it....
  1. #31
    rand49er's Avatar
    Jan 2005
    South Lyon, MI
    68
    13,815
    Re: Header Questions
  2. #32
    lollygagger8's Avatar
    lollygagger8 is offline Cadillac Owners Connoisseur
    Automobile(s): Platinum 2004 CTS-V
    Apr 2008
    Indiana
    4,913
    I bought the used B&B's off classifieds....so I'm going to need to get extensions.
    Anybody know the best place to get em (e.i. cheapest) and how long will I need? 12" or 24" ?
  3. #33
    terminal Velocity is offline Cadillac Owners Fanatic
    Sep 2005
    132
    Which B&B did you get? The ones with cats don't need extensions, I believe.
  5. #34
    Apr 2008
    Indiana
    4,913
    I bought the B&B headers w/ the cats...and you are right, I don't think I'll need extensions (but we'll see)
    I got the strut brace/coils/plugs/O2s/ and stock manifolds off last night! I started at 6pm and quit about 9:15...so about 3 hrs total after setup then clean up.
    FYI: with just the ramps under the front and rear tires, there is NOT enough clearance to pull the stock manifolds/cats out. So I had to jack up the front end as high as my jack would go (with a piece of wood even) to get enough clearance. The PITA was having to hold the manifold up with one hand, and unscrew the last bolt holding it in so it wouldn't come crashing down.
    $hitty cell phone pic....
    Surprisingly, my spark plug wires came out easier than I expected!
    So I'm going back in after work today and going after the MM's and then the headers.
    Brent @ EPP said he can get me in on monday to get it tuned up, so I'll keep ya posted
  6. #35
    Apr 2008
    Indiana
    4,913
    Got the old MM's and new UUC mounts in last night.....whatta PITA job!! Here's a pic of the drivers side mount...the top completely seperated from the rest of the mount. The passenger side was fine.
    Took me about 4 hours total since the old manifolds were already off....plus I was using hand tools. I don't know how they do it with the manifolds/headers on.....that is a TIGHT fit in there!
    Headers going on tonight!
  7. #36
    whisler151's Avatar
    whisler151 is offline Cadillac Owners Connoisseur
    Automobile(s): 2012 CTS-V Sedan, 2011 CTS Coupe, 2010 Ford Raptor
    Apr 2007
    Dallas, TX
    3,547
    Quote Originally Posted by lollygagger8 View Post
    Congrats! You will LOVE your car even more once the headers are on.
  8. #37
    CadiBlk's Avatar
    CadiBlk is offline Cadillac Owners Connoisseur
    Automobile(s): Silver '05 V
    Jun 2007
    Atlanta
    1,238
    Did you only have one bad MM? How much shimmy shake did you have? I have the shutdown wiggle and some low idle waggle, but I have been crediting that to the torque monster that lives under my hood.
  9. #38
    Apr 2008
    Indiana
    4,913
    Ya just the drivers side was bad (pretty f'n bad since the top ripped off completely) the passenger side was fine. Most people's driver side MM's go bad first. Shutdown definitely had vibes....started getting a weird vibe at around 65mph up front, and I just had my tires balanced last week and it was still vibrating......I'm thinking this will help that as well.
    Look for a fluid leak around the bottom of the MM. It looks greenish in color. After mine had been exposed to air/water the fluid was more of a brown color though. I noticed the leak at first on the side of the oil pan since it was so close....don't mistake that for an oil leak!
  10. #39
    CadiBlk's Avatar
    Jun 2007
    Atlanta
    1,238
    How much fluid will leak out that mother? If it has been bad for while, should most/all the fluid have leaked out and I might not be able to see any evidence? Thanks for your info on this as I am doing my headers over Thanksgiving and if I have bad MM I will be wanting to do that at the same time as you are doing.
    Man are the stock headers ugly. You have any problems with stuck bolts? Use any penetrating spray?
  11. #40
    Apr 2008
    Indiana
    4,913
    Quote Originally Posted by CadiBlk View Post
    There is quite a bit of fluid in those. If the mount is only ripped up top though, the fluid will only leak so much. Gravity/weight of the engine should keep the rest in. Mine was ripped all the way around the top and still about a 1/4 ounce came out when I turned it upside down.
    If you are going to change out the manifolds with headers, I would suggest doing the UUC MM's while you are there. Much easier w/ exhaust off. You might not see any traces of leakage yet but eventually at least one of your MM's will go bad. With all the good talk about the UUC's you can't go wrong.
    When you do the headers, the header bolts are 13mm. None of my bolts were stuck too hard, and didn't need any pb blaster. And ya headers are 10x sexier than the manifolds, ha! Ewill says they use blue loctite on the bolts when you reapply em though and 18 ft lbs of torque! Get new OEM manifold gaskets too, and wear gloves! (bloody knuckles)
    Let me know if you decide to change your MM's and I'll help you if you get stuck anywhere.
  12. #41
    CadiBlk's Avatar
    Jun 2007
    Atlanta
    1,238
    Sounds good, I will try to get in there this weekend and see if I can spot any fluids.
    On a different note. I am originally from Auburn. Back in the day I used to play myself a little bass and the guys I played with went on to form Pheen when I went off to school (those basdids kept rockin in the free world while i went off to hit the books). Not too many V owners in NE Indiana. I am a lil unhappy that I had to move away when I started to do my mods, with EPP being so close. My dad still lives up there and I will be there around x-mass time. I will be sans V since Jax to NE Indiana is a little bit of a haul and my V refuses to touch snow.
    Good luck with the rest of your install and be sure to keep the pics/video coming.
  13. #42
    Apr 2008
    Indiana
    4,913
    No shit!? I've heard of Pheen before. I'm the singer in PLOW.
    [ame="http://www.youtube.com/watch?v=8yhayHWB6Qk&feature=related"]YouTube - Plow playing "Before I Forget" by Slipknot[/ame]
    You'll have to hit me up when you come back for the holidays....we'll go catch some brews!!
    Ya I hear on the snow......my V will be put up as well, and the Jeep gets the nod in the winter!
  14. #43
    Apr 2008
    Indiana
    4,913
    The title of this thread should be F@&*(#)$ BADA$$!!!!
    OMG......my V is a MONSTER!!!!!
    It sounds soooooooooo good! It was actually pretty easy to get the headers in. I used a jack stand to hold em up from underneath, then just grabbed em up top and started the bolts. The most time consuming thing was I had to go to Lowe's to get some new bolts cuz the manifolds had studs and the headers didn't. It wants to go alot now....I can't explain it...the car seems more "eager"? I started it up with just headers once....sounded like the baddest Harley on earth!
    With the B&B xpipe and catback.....I don't think I've ever heard a more glorious sound! It sounds more "metallic" (no not metallica they suck now) Like how a mustang with flowmasters sounds.....but BETTER of course!
    I'll get somebody with a video camera to post some clips.
    The new UUC MM's make the V feel extremely Solid!! From downshifting from like 6th to 4th, the body used to lurch a bit...now it just takes it with ease. Very well grounded. Even cornering seems better (prolly cuz the engine was leaning/pulling on the old torn up mount) I'm in Love again!
    Vibrations I was feeling at 65mph...GONE!!!
    Death Shimmy on shut off...GONE!!!
    Pull up next to the V, light turns green and I'm....GONE!!!
    Power feels more transplanted to the ground (more immediate)
    I would suggest this to ANYONE who is on the fence about it, or if you have a broken mount now. You will just break the stock mount(s) again...so fix it and forget it! Call Luke and buy a pair....you won't regret it!
    I go to EPP monday afternoon for the tune, so we'll see how much HP I get out of the headers/tune. I left the header wrap on since the spark plug wire boots were sitting right next to the header ports. I'll keep an eye on the wires to make sure they don't melt. If they do, I'll probably go with Taylor wires.
    I my V all over again!!!
  15. #44
    CadiBlk's Avatar
    Jun 2007
    Atlanta
    1,238
    Glad to see you got everything in alright and that you're lovin it. As for the loudness you feel like cats would have made a big difference? Have you done a hwy speed test for drone? I will be pulling the trigger on some headers in the near future and I want to get it right.
  16. #45
    Apr 2008
    Indiana
    4,913
    I got hi flow cats that are part of the B&B headers. They definitely flow MUCH better than the factory cats. I started up my exhaust: once with just the stock manifolds/cats, once with just headers/hi lfow cats. Compared to just the headers/hi flow cats, the stockers weren't loud at all!
    I got up to 70mph this morning.....there is a drone at low rpms (like if you were in 6th at 40 mph) but I have the xpipe. If I switch back over to the resonator, I'm sure that would go away. But I like the way it sounds, and like the HP gains of the xpipe. Even though I'm a B&B guy, get the Kooks ones from Luke since they are on sale and they come with hi flow cats.....gets headers / you will NOT be sorry!!!
  17. Remove Advertisements
