Quote Originally Posted by CadiBlk View Post
So I got my car into the dealer this morning and they are swappin my diff. Does the SRX use same diffs as us?
I went out to look under the car while they had it up on the lift. Damn a lift would make the header install easy. Guy on the faq doing the bb header install just used ramps. Is that enough clearance to get the headers in/out? Did you use a special O2 socket?
I backed the V onto Rhino Ramps and then jacked up the front end and used stands. Tons of space. If you can get an O2 socket tool, do it. If not, plenty of WD40 and an open box wrench may work for you...
