| 2004-2007 Cadillac CTS-V Performance Mods Discuss all Cadillac CTS-V performance modifications here. Engine tunes, exhaust, intake, suspension and more. | Cadillac Forums: Everything I ever wanted to know about a Maggie,,,and your gonna tell me!!!
08-23-08, 11:09 AM
|  | Mods on hold till diff gets fixed. Cadillac(s): 2005 CTS-V | | Join Date: Jan 2005 Location: South Lyon, MI Age: 60 | | | Re: Everything I ever wanted to know about a Maggie,,,and your gonna tell me!!! Quote:
Originally Posted by CTSV_510 Can you explain why that's a better orientation for the heat exchanger? Why wouldn't you want the coolant going right from the hex to the intercooler instead of passing through the hex after running through the intercooler? | A heat exchanger is designed to transfer heat energy and the amount of heat it transfers is a function, among other things, of the temperature differential between, in this case, the hot coolant exiting the intercooler and the cooler ambient air. I rationlized that I wanted to take the most advantage of the HEX's ability to do this since that's what it's designed to do while the temperature difference was greatest, and that's when it first exits the intercooler (i.e. when the coolant is at its hottest). Then, when the maximum amount of heat is extracted, it can further cool to a small extent in the reservoir which is not designed to provide cooling but is simply what it is, a reservoir, before passing through the pump again and reintroduced into the intercooler.
This is as opposed to the reverse where the coolant would be slightly cooler exiting the reservoir before going into the HEX thereby lessening the amount of heat transferred through it.
Thus, in my configuration, the heat transferred in the HEX is certainly more, and the heat transferred to the surroundings in reservoir is probably less. However, my thinking is that the net effect is that this arrangement is better. How much? Some ... maybe not a lot, but some. Is it worth it? Maybe, maybe not ... depends. The point is, it would have bugged the heck out of me had I not done it according to my instincts/understanding of heat transfer.
__________________ '05 CTS-V, Stealth Gray, Sunroof, 3M Clear Bra, B&M Shifter w/UUC Bushings, Specter Werkes Bushings, V Headrests, Wheel To Wheel Powertrain Tune, Corsa, Kooks w/Hi-Flo Cats, Ultimate Grid Pedals, Hotchkis Anti-Sways, STS-V Fogs, Ground Control 650R/600F, WW Clear Sidemarkers, Full-Size Spare, Magnuson SC Polished, CTS Console, FG2, Aggressive Street Alignment, MOMO Shift Knob, DSS/Hendrix Engrg Axles, UUC Flywheel. Soon: UUC MMs. 472 RWHP/411 RWTQ (Mustang dyno). |
08-23-08, 12:02 PM
|  | Mods on hold till diff gets fixed. Cadillac(s): 2005 CTS-V | | Join Date: Jan 2005 Location: South Lyon, MI Age: 60 | | | Re: Everything I ever wanted to know about a Maggie,,,and your gonna tell me!!! We're way ahead, but I thought I'd give you a heads up on the TB nipple.
You'll have to bend it up slightly since it hits the maggie as shown here. I used a nut driver of the appropriate size and tweaked it. |
08-23-08, 12:55 PM
|  | Cadillac Owners Fanatic Cadillac(s): 06 CTS-V | | Join Date: Jan 2008 Location: No. VA Age: 42 | | | Re: Everything I ever wanted to know about a Maggie,,,and your gonna tell me!!! Tony Be careful as to make sure that your hood does not touch the top of the throttle (may need to shave off the top a bit). As my 05 maggie on a 06 LS2 sits a bit higher and is almost ready to break through the hood. Finally determined that the way we had to fab to fit the 06 made it to sit a bit higher. Oh well - Just about ready to get a cowl hood (Darn if I must). First I thought and also Bill @ Lindsay that it was my MM not holding the maggie in place strong enough, but after the install of MM the engine did not torgue as much but still hits the hood.
Just take your time and always helps to have another technical hand to work with you.
Good luck - Another maggied V at the VII day -
BTW - How many maggied V showing up at the VII dayn - I wonder??
Mick
__________________ 06 Blacked out V, BEHE tuned 484rwbhp & 473 ft/lb torque, Lingenfelter COMP CAM, CAI, BFG KD 265/40/18, Sway bars, rear strut bar, Callaway spark wires,Maggie , LS7 FLYWHEEL:High Flow Cats, Resonator, Kooks Headers, Corsa exhaust, UUC Knob, shifter, UUC Bushings, UUC MM, GM cross drilled rotors, hawk pads, SS Brakeline,Red calipers, blacked, tinted windows, racing pedals,Spoiler,full size spare,V sign headrest,DVD headrest,boost gauge. |
08-23-08, 01:19 PM
|  | Cadillac Owners Member Cadillac(s): 05 maggied CTS-V, 03 maggied Z06 | | | | | Re: Everything I ever wanted to know about a Maggie,,,and your gonna tell me!!! Originally Posted by heavymetals The wrap around fuel inlet has got to go.
Agreed. Are you still working on anything?
Yep, since I already have mine I have been emailing a forum member who is a machinest about modifing or making a few more for the newer maggie crowd.
What it may come down to is:
the cheapest way to get it done is to ship the replacement and then have the original returned for modification.
Just a question of either capping off the original hole or screwing in a pressure transducer for fuel pressure monitoring.....
__________________ I am so expensive I can't even afford to hire me.... |
08-23-08, 06:42 PM
|  | Cadillac Owners Connoisseur Cadillac(s): '05 CTS-V, '00 SLS, 98 SLS, 89 Eldo, '80 Eldo | | Join Date: Mar 2006 Location: NYC Age: 38 | | | Re: Everything I ever wanted to know about a Maggie,,,and your gonna tell me!!! Quote:
You can bypass the Magnavolt if it fails so you don't get stuck. | Good, I guess you disconect the magnavolt from the trunk, and reconect the stock grey wires?
Wire cutters and some black tape sounds much better than a flat bed.
__________________ '05 Platinum l LPE CAI l Magnaflow l V1 (hardwired), w/ custom mount l UUC shifter w/Lindsay bushings l UUC leather shift knob l K9 GEAR rear seat cover l CruiseCam l HID fogs l Falken RT-615s l Hotchkis sways W/Z06 end links l Billet A/C vent knobs l Hawk HP+/HPS l CG-Lock l Specter Werkes Bushings l Noah Custom cover l FG2s l Ground control 550/600 l MAGGIE 436RWHP/ 412RWTQ (Dynojet) l Heavys fire extinguisher bracket l Intercepter scan-gauge l Billet pedals l Meth l NO HEADERS |
08-23-08, 06:47 PM
Originally Posted by heavymetals Seriously consider replacing the valve springs as one of your next mods. IMHO | Something to do with the supercharger, or just good to do on an LS6? |
08-23-08, 09:15 PM
Originally Posted by heavymetals ... the cheapest way to get it done is to ship the replacement and then have the original returned for modification. ... | As winter approaches, I am more likely to be able to do this. |
08-23-08, 09:53 PM
| | BLING IS AMERICAN RICE Cadillac(s): '04 CTS-V | | Join Date: Jun 2004 Location: Just North of Titletown... | | | Re: Everything I ever wanted to know about a Maggie,,,and your gonna tell me!!! Don't you fools know N/A is the way to go?
hahaha, seriously, have fun guys. I'm just waiting for V2 to have a soopercharged V...
__________________ The Caddy that zigs?
So they were a generation late... Will getting rid of poast counts change how I poast? Dream on...
Currently in the rare 20,000 poast club. 23,165 and counting... |
08-23-08, 09:57 PM
| | BLING IS AMERICAN RICE Cadillac(s): '04 CTS-V | | Join Date: Jun 2004 Location: Just North of Titletown... | | | Re: Everything I ever wanted to know about a Maggie,,,and your gonna tell me!!! and what's with the ,,, deal? The period key is one to the right... |
08-23-08, 11:45 PM
| | Cadillac Owners Member Cadillac(s): 2005 CTS-V | | Join Date: Jan 2008 Location: NE PA Age: 32 | | | Re: Everything I ever wanted to know about a Maggie,,,and your gonna tell me!!! Quote:
Originally Posted by Twitch Good, I guess you disconect the magnavolt from the trunk, and reconect the stock grey wires?
Wire cutters and some black tape sounds much better than a flat bed.  | Easier than that even. Fab up a wire to short the two new wires that you run from the trunk up to the magnavolt connector. If it fails, just pop the connector off of the magnavolt and plug in your jumper wire across the appropriate connections.
Keep the jumper wire, a spare belt, and long wrench for the tensioner in the trunk just in case....
Toss in a photocopy of the belt routing as well if you are paranoid... |
08-24-08, 01:08 AM
Originally Posted by thebigjimsho Don't you fools know N/A is the way to go?
hahaha, seriously, have fun guys. I'm just waiting for V2 to have a soopercharged V... | Could there BE a worse time for you to bring that up?!! Quote:
Originally Posted by thebigjimsho and what's with the ,,, deal? The period key is one to the right... | Uh,,,,,, Quote:
Originally Posted by smackdaddy Easier than that even. Fab up a wire to short the two new wires that you run from the trunk up to the magnavolt connector. If it fails, just pop the connector off of the magnavolt and plug in your jumper wire across the appropriate connections.
Toss in a photocopy of the belt routing as well if you are paranoid... | lol I was thinking of a toggle switch. But that's like waiting for it to happen (like the wire cutters are any better  ).
The breaker bar is always in the car anyway. Just have to put a 15mm next to the 19. |
08-24-08, 08:08 AM
Originally Posted by smackdaddy ... Keep ... a spare belt, and long wrench for the tensioner in the trunk just in case. ... | Ever since I heard heavy suggest this, I do it, too.
I'm sure you've already realized, but you could get started even before your maggie arrives by doing the mod involving the wiper system.
Another random thought, here ... if you don't have someone to help you lift the maggie onto the motor (like me), I rigged up a "hoist" of sorts and lowered it on myself. Looked like some kind of a redneck sex harness, but it got it done. |
08-24-08, 02:21 PM
|  | <----- go ahead and stare Cadillac(s): Maggied '05 CTS-V | | Join Date: Jan 2008 Location: West Chester, PA Age: 26 | | | Re: Everything I ever wanted to know about a Maggie,,,and your gonna tell me!!! Quote:
Originally Posted by rand49er I'm sure you've already realized, but you could get started even before your maggie arrives by doing the mod involving the wiper system. | I could do this step early if can be easily cut with a standard hacksaw. I was waiting for next weekend when I'll have a grinder available, but if I can get this done ahead of time, it'd be a plus.
So has anyone successfully cut the wiper arm with a hacksaw?
__________________ 05 CTS-V / maggie 2.8 / b&m shifter & uuc bushings / gto shift knob / kooks lts 1 3/4 + cats / magnaflow / k&n cai / fg2 shocks / hotchkis sways / hawk hps / 265|40 bfg kd / ngk tr6
434 rwhp / 412 rwtq..........are you new to the forum? READ THIS and then TRY THIS. |
08-24-08, 05:09 PM
| | Cadillac Owners Fanatic Cadillac(s): cts v | | Join Date: Jul 2004 Location: Bay Shore NY Age: 47 | | Re: Everything I ever wanted to know about a Maggie,,,and your gonna tell me!!! Hey Twich
Thanks a lot man, all this maggie talk made me whip out my master card which was still smoking from my recent trip to Europe and order one. The maggie coming to me and you'll be getting the bill  By the way I was told that only a few maggies are left and when they are sold thats going to be it. |
08-24-08, 05:58 PM
Originally Posted by SlvrVee ... By the way I was told that only a few maggies are left and when they are sold thats going to be it. |  | | Cadillac Discussion Tools | | |
Censor is OFF | | | |
