Everything I ever wanted to know about a Maggie,,,and your gonna tell me!!! - Page 24
Page 24 of 32 FirstFirst ... 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 LastLast
Results 346 to 360 of 478
2004-2007 Cadillac CTS-V Performance Mods Discussion, Everything I ever wanted to know about a Maggie,,,and your gonna tell me!!! in Cadillac CTS-V Series Forum - 2004 - 2007; This has me thinking about gauges now. Can I connect an A/F gauge? If so, where would that hook up ...
  1. #346
    Twitch's Avatar
    Twitch is offline Cadillac Owners Connoisseur
    Automobile(s): '05 CTS-V, '00 SLS, 98 SLS, 89 Eldo, '80 Eldo
    Mar 2006
    NYC
    46
    4,001
    Re: Everything I ever wanted to know about a Maggie,,,and your gonna tell me!!!
    This has me thinking about gauges now. Can I connect an A/F gauge? If so, where would that hook up to?
    Also boost, what do you tie into?
    I saw some pics of an electronic gauge that can monitor several things. That's probably the best route, but I love the look of the analog.
    Any advice (brand, where to look,,,,)?
    I'll think about mounting it later.
    Thanks
    Tony
  2. #347
    CTSV_510's Avatar
    CTSV_510 is offline Cadillac Owners Connoisseur
    Automobile(s): '06 Z06, '05 CTS-V 453rwhp/434rwtq (sold)
    Jan 2008
    West Chester, PA
    34
    4,455
    Well...
    It happened again today. I can now describe it as a deep fluttering sound that happens above 3500 rpms at WOT, or very near WOT.
    I checked the lines (including hose to the magnavolt) and all are connected with no pinching, kinks, or loose connection. I re-read the DTCs (I am used to seeing them from the O2 sensors due to the headers).
    P0113 - Intake Air Temperature (IAT) Sensor Circuit High Voltage
    According to what I have read, this MIL will be thrown if the following conditions are met for 4.5 seconds or more:
    - Vehicle speed less than 7 mph
    - MAF less than 15 grams per second
    - Engine coolant temp greater than 32 F
    - Intake air temp below -35 F ????
    P0332 - Knock Sensor 2 Circuit Low Input (Bank 2)
    I'm thinking that the one knock sensor wire may have gotten pinched or something the second time I put the maggie on. I don't know about the IAT sensor - that one's got me stumped.
    Needless to say, there will be no more flogging it until I can get everything fixed. Anyone think these issue could in any way contribute to my issue? It really feels/sounds like the bypass valve isn't working properly.
    Maybe it's time for a call to Magnuson.
  3. #348
    Twitch's Avatar
    Mar 2006
    NYC
    46
    4,001
    That reminds me. I threw a code last night. I'll check it in a bit.
    I know how you feel man. Deff call Magnuson before they close for the weekend. Hopefully this happened before.
  5. #349
    heavymetals's Avatar
    heavymetals is offline Cadillac Owners Master
    Automobile(s): 05 maggied CTS-V, 03 maggied Z06
    Nov 2004
    8,787
    I think it is either spark or fuel related.
    Maybe the knock sensor is sending some bad info and the spark gets retarded.
    If the magnavolt is funky that would explain the WOT problem as that is when the vacuum line activates the doggone thing.
    Bypass it and see if the problem is still there.
    Did you make sure to put the rubber "O" rings on the knock sensor plate?
  6. #350
    CTSV_510's Avatar
    Jan 2008
    West Chester, PA
    34
    4,455
    Quote Originally Posted by heavymetals View Post
    The rubber O rings are all in place.
    If I bypass the magnavolt, then I can't push it to WOT where I would need to to test this problem, right? At least without chancing a "boom".
    Maybe I should just plan on taking it off again this weekend to check the knock sensors out.
    Who knows which knock sensor is bank 2?
  7. #351
    Nov 2004
    8,787
    You could connect a voltmeter to the output of the Magnavolt and have someone monitor it when you go WOT and see if it is dropping out.
    Worse then bypasssing as at least your getting fuel instead of it shutting off, athough not recomended for extended periods.
    Your just trying to limit it down as to what's causing it anyway, not run around.
    You can also "fool" the Magnavolt just by putting vacuum to the input and monitoring the output, however I prefer "real world" testing.
    Actually, I guess you could just disconnect the vacuum hose from the Magnavolt and see if the problems happens.
    You sure your not bouncing off the rev limiter?
  8. #352
    Luna. is offline Cadillac Owners Connoisseur
    Automobile(s): 2005 Stealth Gray CTS-V, 2009 Black CTS-V
    Jun 2005
    CA
    3,571
    With a maggie you can give away the hole shot and then just reel them in.
    Especially true with the Subarus and Mitsus that will hole shot the heck out of you...and then you reel them in...
    Quote Originally Posted by CTSV_510 View Post
    2.6" pulley & 90 mm TB & retune.
    I'm still a believer in the 8' crankshaft balancer and 8-rib pullies all the way around, but that's just me. 2.6" for me was too hard to avoid belt-slip. Those of you who don't, smile, for I couldn't get it to not-slip after several 1000 miles...
    Quote Originally Posted by Twitch View Post
    A/F gauge would be interesting. I can't recall anyone actually having a guage monitor that though.
    I tied mine into a vacuum hose coming off the driver-rear of the intake manifold (which is exactly where A&A plugged into during my dyno runs). Should be fairly obvious when you look at it. There doesn't seem to be too many other places to hook up to...at least that we could find.
  9. #353
    CTSV_510's Avatar
    Jan 2008
    West Chester, PA
    34
    4,455
    Not the rev limiter - I've never hit that before. I'm not interested in anything after 6500 rpms. This is occuring at 3500 and up.
    What about a fuel pressure test? Wouldn't that also tell me? Idle should be around 55 psi, right? What about WOT? I think I saw fuel pressure gauges at pep boys for $20 or so. I don't own a voltmeter yet. I guess I should probably get both.
    I think the spark retard could have something to do with it, but what about the fluttering sound? Does an engine pulling timing make a fluttering noise?
  10. #354
    Jun 2005
    CA
    3,571
    If memory serves, it should be between 55-65 psi.
  11. #355
    rand49er's Avatar
    Jan 2005
    South Lyon, MI
    68
    13,824
    60 psi here.
    Boost pressure can be gotten as Luna described ... mine has a cap on it at present. I've got a gauge, but have yet to find a way to mount it befitting a Cadillac.
    Hey, Luna, how much did the 8-rib setup set you back? THAT is the best way to do it. Wasn't it something like $2k or some crazy amount?
  12. #356
    terminal Velocity is offline Cadillac Owners Fanatic
    Sep 2005
    132
    All this and heat soak too? Egads, I'm staying NA...
  13. #357
    Max-Q is offline Cadillac Owners Fanatic
    Automobile(s): Cadillac CTS-V & Escalade
    Feb 2007
    St. Louis
    247
    Are you sure the knock sensors and rubber O-rings are installed correctly? It sounds like they are sensing knock and pulling timing. The fluttering is probably the bypass valve releasing the boost pressure after knock is detected.
    I used a lot of high temp silicone to hold the wires into place and as an added cushion between the supercharger intake and the valley cover. There are a lot of vibrations coming from the Maggie and the knock sensors could simply detect those vibrations as knock.
  14. #358
    CTSV_510's Avatar
    Jan 2008
    West Chester, PA
    34
    4,455
    Quote Originally Posted by Max-Q View Post
    I am sure the O-rings are in place, and that the knock sensors are properly torqued. I think the wires are just pinched. I'm going to pull it tomorrow morning and see what I find. Are those 14 gauge wires? I will probably end up having to re-wiring at least the back sensor. I will also will also be using plenty of silicone to keep them in place.
    How does the bypass valve know that knock is detected? Unless the detected knock effects the throttle position, I don't even know if these two things are related.
    The whole other side is the IAT code which makes no sense.
    We'll see - Schedule for tomorrow: maggie removal, knock sensor wire fixing, maggie reinstallation, fuel pressure testing, IAT wire checking.
  15. #359
    MauiV's Avatar
    MauiV is offline Cadillac Owners Connoisseur
    Automobile(s): Tis Gone :(
    Nov 2007
    3,414
    Maggie Install procedure:
    Drop off to guy that has done this a couple hundred times vs my zero.
    Pay bill.
    Drive home.
    At least I hope it all goes this easily, it looks good on paper.
  16. #360
    CTSV_510's Avatar
    Jan 2008
    West Chester, PA
    34
    4,455
    Small Update #1:
    Knock sensor wires all look fine. Maybe it's the rear sensor that was submerged in water?
    Deja Vu WildWhl?
    Rain while the maggie was off at Magnuson must have leaked in? Everything was covered well, and the tape covering the intake ports was dry as well as everything under them when I pulled it off that day. I never pulled knock sensor covers to check. I'm an idiot and should have had the damn thing completely covered. I am more than lucky that no water made it into the cylinders.
    I picked up a new sensor form the local chevy dealer and it's going on now.
    I think I'm going to build a garage. I NEVER should have bought a house without a garage.
  17. Remove Advertisements
