Go Back   Cadillac Owners Group > Current Cadillac Vehicle Discussion > Cadillac V-Series Forums > Cadillac CTS-V Series Forum - 2004 - 2007 > 2004-2007 Cadillac CTS-V Performance Mods
2004-2007 Cadillac CTS-V Performance Mods Discuss all Cadillac CTS-V performance modifications here. Engine tunes, exhaust, intake, suspension and more.
Cadillac Forums: Traction Kit Group Buy info "Upgraded KARS Stage III Kit"
  #46 (permalink)
Old 08-04-08, 06:30 PM
rand49er's Avatar
If compensating = Maggied V, I'm guilty.
Cadillac(s): 2005 CTS-V
View rand49er's Photo Album
Casino Cash: $47574
Re: Traction Kit Group Buy info "Upgraded KARS Stage III Kit"
Originally Posted by deedubb View Post
I'm not meaning this to sound rude, but if the data doesn't exist, on what basis did you come to your conclusion with?
Just playing devils advocate here.
I started a thread way back when to find out how I should proceed with protecting my new diff after my maggie install:
http://www.cadillacforums.com/forums...rotection.html
I was considering BMR or KARS or ? Saw my KARS on eBay last October and snagged it. Paid about the same as if it was new from Doug. Debated about installing it, then decided to go ahead this past April prior to Summit Point.
Chris' video (as do other vids) shows not even a hint of WH from my casual observance. But, what if you put on some sticky tires? What if there was some sticky pavement? What if the temperature was high? ... low? ... worn tires? ... wet pavement? ... and on and on. When I was stock, mine would hop on wet pavement and even on a bit of ice! That was with nearly virgin F1 runflats. There's just a lot of variables involved ... it'd be nice to be able to understand the whole thing better, that's all.
(No, you didn't sound rude at all. Hope I didn't/don't.)
'05 CTS-V, Stealth Gray, Sunroof, 3M Clear Bra, B&M Shifter w/UUC Bushings, Specter Werkes Bushings, V Headrests, Wheel To Wheel Powertrain Tune, Corsa, Kooks w/Hi-Flo Cats, Ultimate Grid Pedals, Hotchkis Anti-Sways, STS-V Fogs, Ground Control 650R/600F, WW Clear Sidemarkers, Full-Size Spare, Magnuson SC Polished, CTS Console, FG2, Aggressive Street Alignment, MOMO Shift Knob, DSS/Hendrix Engrg Axles, UUC Flywheel. Soon: UUC MMs. 472 RWHP/411 RWTQ (Mustang dyno).
  #47 (permalink)
Old 08-04-08, 07:42 PM
Errol @ TPS's Avatar
Cadillac(s): None
View Errol @ TPS's Photo Album
Casino Cash: $2375
The cradle has very soft mounts in this car for ride quality purposes. The Kars kit bolts to the cradle in two locations, and the bottom of the rockers to tie them together, and reduce the ability for the cradle to move around so much. The KARS kit at the same time reduces the amount of movement from the diff, via the pinion support, while at the same time not being too rigid. When things are too rigid, they break. When things are to soft, they are able to bounce around too much. The movement throws camber, caster, and most importantly toe out during heavy load. There is no stability. The KARS kit should work well in most, if not all conditions by introducing the much needed stability under heavy load. On my IRS street/drag car, that weighs 3400lbs with driver, I am able to cut 1.31 short times with a few little tricks and the correct alignment for that situation. I actually toe the rear tires out 1 degree because during heavy acceleration they toe back it that far. The only rubber bushings that remain in the car are those at the upper and lower control arms, and the toe links. Rear end and cradle are solid mounted.
Hope the explanation makes sense.
  #48 (permalink)
Old 08-04-08, 08:29 PM
Cadillac(s): Maggied 2004 CTS V Black Raven cause its faster
View MauiV's Photo Album
Casino Cash: $12065
I would be interested to see how this works with a set of BFG drag radials hooking instead of the wheels spinning and all that power grabbing on these infamously weak diffs.
How hard to remove the kit before taking the car into the dealer if I do happen to blow my diff in the next 16 months of warrenty?
  #49 (permalink)
Old 08-04-08, 08:31 PM
deedubb's Avatar
Let Me See Your War Face!!!
Cadillac(s): 05 CTS-V
View deedubb's Photo Album
Casino Cash: $12145
I understand your point.
2005 Black on Black - Maggie MP112 (2.8 Pulley) - 90mm TB - Dyno tuned 430RWHP - B&M Shifter/UUC Bushings - 15% Tint - Red Z06 FRC's - Muffler Delete - Blacked out lights - SRP Pedals
PENDING installs: 2.6" blower pulley, Hawk HPS.
FUTURE MODS: FI Cam, Headers, 160 T-Stat.
  #50 (permalink)
Old 08-04-08, 08:46 PM
stkshkr's Avatar
Cadillac(s): 05 Maggied V Black/Black
View stkshkr's Photo Album
Casino Cash: $10760
I had lots of drag and street launches with Doug's KARS (over 300). It does not cure wheel hop but greatly reduces it. Doug clearly stated that when he sold the kits. Rand49er is exactly right. With drag radials at a 2500 RPM launch I had no hop. On Eagle F1's NRF it would hop a little and above 2500 it would hop like a bunny.
I have Dougs KARS Traction package with subframe connectors and I have no hop under any conditions!!! (1.60 60' times)
  #51 (permalink)
Old 08-04-08, 08:57 PM
Cadillac(s): None
Casino Cash: $2375
Very Nice!
What does it run?
  #52 (permalink)
Old 08-05-08, 01:15 AM
Cadillac(s): Cadillac
View 04vman's Photo Album
Casino Cash: $8419
Still have not heard a word on the kit. How much? Are they even available?
  #53 (permalink)
Old 08-05-08, 01:20 AM
csp3000's Avatar
Cadillac Owners Enthusiast
Cadillac(s): 2007 Escalade, 2010 CTS V soon... =)
View csp3000's Photo Album
Casino Cash: $10321
PM sent
  #54 (permalink)
Old 08-05-08, 02:19 PM
Cadillac(s): 05 Silver CTS-V
View By By C Ya's Photo Album
Casino Cash: $281
How long before they are ready for shipment??
  #55 (permalink)
Old 08-05-08, 02:22 PM
csp3000's Avatar
Casino Cash: $10321
Hopefully Friday kits are going to be shipped.
  #56 (permalink)
Old 08-05-08, 03:09 PM
buf05CTSV's Avatar
Cadillac(s): 2005 Cadillac CTS-V LS6
View buf05CTSV's Photo Album
Casino Cash: $1610
So if I read correctly, there is minimal welding required, or no? And this does not cure wheel hop, but reduces it significantly, correct?
  #57 (permalink)
Old 08-08-08, 08:40 PM
CTSV05's Avatar
Baddass V Lover
View CTSV05's Photo Album
Casino Cash: $897
Well, well, well, I was wondering how long it would take.
No, I'm not proud, other than more expensive materials, and a TIG process as opposed to a MIG process, I see a less hand crafted unit, AND...and its wayyyyyyyyyyyyy more expensive than the one I !INVENTED! that I only sold less than 50 of in almost 3 years, btw.
Oh, Mine only weighed 15lbs shipping weight, you do the math.
BUT...I do appreciate some name recognition anyway, Ty.
Good Luck.
  #58 (permalink)
Old 08-08-08, 11:19 PM
Cadillac(s): None
Casino Cash: $2375
You should be proud. It is an excellent design, and it works extraordinarily well.
Good Luck.
  #59 (permalink)
Old 08-09-08, 01:51 AM
CTSV05's Avatar
Baddass V Lover
Casino Cash: $897
Ok, you're right...lol...I was and always will be proud of My kit, I think Florian meant of being copied though.
It was kickass, it was on Our car for over 40,000k miles with no issues.
Gawd I miss My V....wahhhhh!
  #60 (permalink)
Old 08-09-08, 02:07 AM
stkshkr's Avatar
Casino Cash: $10760
Good to see you back on the board Doug!
buy, group, info, kit, traction
Censor is OFF
