| 2004-2007 Cadillac CTS-V Performance Mods Discuss all Cadillac CTS-V performance modifications here. Engine tunes, exhaust, intake, suspension and more. | Cadillac Forums: Do These Kooks Cats Look Right?
03-12-08, 12:42 AM
|  | Cadillac Owners Connoisseur Cadillac(s): 2005 Redline CTS-V, 1997 Catera | | Join Date: Mar 2007 Location: Purdue University | | | Do These Kooks Cats Look Right? I got my kooks headers and the factory catted connections today and I was wondering if you guys think that they are the correct ones? These seem to have a slip fit at the end and all the other ones that I have seen either have flush cut pipes or a flange at the end. Thanks in advance for helping me out. I am planning on doing the install tonight (passenger header is already on)!
__________________ R.I.P. Cadillacforums..... |
03-12-08, 01:00 AM
| | Cadillac Owners Connoisseur Cadillac(s): Kooks,MOMO seats,C5 hubs,3489# | | Join Date: Jun 2007 Location: Ashland, Ohio | | | Re: Do These Kooks Cats Look Right? The Kook's do slip right in!
Not sure if your setup was designed to connect to the stock cat back, but the stock system will have to be cut. The stock cat back comes right up to the collector it is so long.
Currently trying to fit Kook's Corsa cats to stock pipe.
Norm Quote:
Originally Posted by SkullV I got my kooks headers and the factory catted connections today and I was wondering if you guys think that they are the correct ones? These seem to have a slip fit at the end and all the other ones that I have seen either have flush cut pipes or a flange at the end. Thanks in advance for helping me out. I am planning on doing the install tonight (passenger header is already on)!  | |
03-12-08, 06:55 AM
|  | Mods on hold till diff gets fixed. Cadillac(s): 2005 CTS-V | | Join Date: Jan 2005 Location: South Lyon, MI Age: 60 | | | Re: Do These Kooks Cats Look Right? It's been two years since I put mine in, and I can't remember yesterday. I do recall having to rotate them to find the best angle to mate up downstream ... kind of a pain.
Hey, Skull, you didn't mention it so I'm assuming you had no issues with the dipstick tube?
__________________ '05 CTS-V, Stealth Gray, Sunroof, 3M Clear Bra, B&M Shifter w/UUC Bushings, Specter Werkes Bushings, V Headrests, Wheel To Wheel Powertrain Tune, Corsa, Kooks w/Hi-Flo Cats, Ultimate Grid Pedals, Hotchkis Anti-Sways, STS-V Fogs, Ground Control 650R/600F, WW Clear Sidemarkers, Full-Size Spare, Magnuson SC Polished, CTS Console, FG2, Aggressive Street Alignment, MOMO Shift Knob, DSS/Hendrix Engrg Axles, UUC Flywheel. Soon: UUC MMs. 472 RWHP/411 RWTQ (Mustang dyno). |
03-12-08, 07:33 AM
|  | Cadillac Technician Cadillac(s): none | | Join Date: Nov 2005 Location: Alexandria, VA Age: 41 | | | Re: Do These Kooks Cats Look Right? I think those are the ones we use to connect to a stock exhaust, as noted it will have to be cut.
If you were connecting to a Corsa they would have longer pipes, but it is the same slit, slip on design it is just the slit is in the resonator for a Corsa so the pipe is straight.
We used those to hook to another type of exhaust too, but I forgot which one, and the right cat had to be modified. I think it was a Magnaflow setup.
I haven't done one to a stock exhaust.
So far of the ones I have done, the Corsa is the best fit right out of the box with the Kooks setup.
__________________ Views expressed by the author of this post do not necessarily represent those of the Lindsay Automotive Group. |
03-12-08, 08:27 AM
|  | Cadillac Owners Connoisseur Cadillac(s): '05 CTS-V, '00 SLS, 98 SLS, 89 Eldo, '80 Eldo | | Join Date: Mar 2006 Location: NYC Age: 38 | | | Re: Do These Kooks Cats Look Right? Sound clip please,,,,thank you
__________________ '05 Platinum l LPE CAI l Magnaflow l V1 (hardwired), w/ custom mount l UUC shifter w/Lindsay bushings l UUC leather shift knob l K9 GEAR rear seat cover l CruiseCam l HID fogs l Falken RT-615s l Hotchkis sways W/Z06 end links l Billet A/C vent knobs l Hawk HP+/HPS l CG-Lock l Specter Werkes Bushings l Noah Custom cover l FG2s l Ground control 550/600 l MAGGIE 436RWHP/ 412RWTQ (Dynojet) l Heavys fire extinguisher bracket l Intercepter scan-gauge l Billet pedals l Meth l NO HEADERS |
03-12-08, 11:10 AM
|  | Cadillac Owners Master Cadillac(s): '05 CTS-V | | Join Date: Jul 2004 Location: Elkridge, MD Age: 37 | | | Re: Do These Kooks Cats Look Right? Quote:
Originally Posted by ewill3rd I think those are the ones we use to connect to a stock exhaust, as noted it will have to be cut.
So far of the ones I have done, the Corsa is the best fit right out of the box with the Kooks setup. |
EWill is right on. Coars lead pipes are longer to mate up with the resonator.
Whatever you do, take the extra time to get those slip fit's welded in. The only join you want in your system is between the header collectors, and the lead pipes.
BTW, you are gonna LOVE the sound
-Chris
__________________ 2005 CTS-V:No Roof|FG2|Corsa|UUC Shifter, B-Lines, Motor/Tran Mounts, Diff Bushings|LPE CAI|FFV IntakeTube|Hawk HP+ |Hotchkis Sways|Kooks 1.75 Coated LTs + cats|KARS III |Mamofied Fast90 + NW90|224/228 111+0 XFI/XE-R .609/.588|ATI 25% UD Pulley|YT 1.7" UltraLites|Melling HiFlow Oil Pump|Comp Chromeoly 7.425" PR's|Cloyes Hex Adjust Timing Set|Lucas 42# Flow Matched Injectors|Patriot Gold Xtreme Springs, Ti retainers, Super 7 locks|All ARP Fasteners|Mustang Dyno Tuned (SAE): 412rwhp / 380 rwtq |
03-12-08, 01:04 PM
|  | Cadillac Owners Connoisseur Cadillac(s): 2005 Redline CTS-V, 1997 Catera | | Join Date: Mar 2007 Location: Purdue University | | | Re: Do These Kooks Cats Look Right? I can't find a muffler shop that welds stainless!!!! |
03-12-08, 01:12 PM
|  | Cadillac Technician Cadillac(s): none | | Join Date: Nov 2005 Location: Alexandria, VA Age: 41 | | | Re: Do These Kooks Cats Look Right? Chris, actually I have found the kooks pipes mate with the resonator much better than the Corsa pipes that go between the stock cats and the resonator.
The pipes for the stock cats are too small and it makes it impossible to clamp them down to prevent leaks.
The Kooks cat pipes are a beautiful fit into the resonators and the clamps will hold without leaking.
Depending on how it is set up though, like what equipment you have, welding at the inlet of the resonator could be a great idea.
Be sure stuff lines up right, those cats are not labeled but there is a left and a right. Mixing them up can cause fit issues. |
03-12-08, 01:55 PM
| | Cadillac Owners Enthusiast Cadillac(s): 04 CTS-V | | Join Date: Mar 2008 Location: Schaumburg, IL Age: 27 | | | Re: Do These Kooks Cats Look Right? i had my kooks headers installed a little over a week ago at Speed Inc. the CAI, headers and exhaust sound SAWEEEEEEEEET! if i can find a charger for my videocamera i'll take a vid w sound. |
03-12-08, 04:06 PM
|  | Cadillac Owners Connoisseur Cadillac(s): 2005 Redline CTS-V, 1997 Catera | | Join Date: Mar 2007 Location: Purdue University | | | Re: Do These Kooks Cats Look Right? Alright, the V is at Exhaust Specialists in Valparaiso, Indiana. They are getting everything to fit up right and welding the seams on the cats! It will be done in about an hour and I will get some videos posted! |
03-12-08, 04:20 PM
| | Cadillac Owners Fanatic Cadillac(s): 07 cts v | | Join Date: Jul 2006 Location: Joliet IL Age: 22 | | | Re: Do These Kooks Cats Look Right? rangerrob i just got mine done at speed inc like 3 weeks ago what did u make at the dyno |
03-12-08, 04:26 PM
| | Cadillac Owners Enthusiast Cadillac(s): 04 CTS-V | | Join Date: Mar 2008 Location: Schaumburg, IL Age: 27 | | | Re: Do These Kooks Cats Look Right? 374rwhp/359rwtq. how about yours? what mods do you have? i'd send you a PM, but i don't have 30 posts yet... |
03-12-08, 04:29 PM
|  | Cadillac Owners Connoisseur Cadillac(s): 2005 Redline CTS-V, 1997 Catera | | Join Date: Mar 2007 Location: Purdue University | | | Re: Do These Kooks Cats Look Right? Start Posting Rangerbob! Did you get my PM? I never got an email from ya! |
03-12-08, 04:41 PM
Originally Posted by SkullV Start Posting Rangerbob! Did you get my PM? I never got an email from ya! | Carefull, nothing get's Urby's panties in a twist quicker than spam posting to get to 30. Just trying to warn ya on that one.
Skull, PM him your e-mail or give him a call if it's urgent, or have Rob become a supporter, and he get's instant PM access.
-Chris |
03-12-08, 04:47 PM
|  | Cadillac Owners Connoisseur Cadillac(s): 2005 Redline CTS-V, 1997 Catera | | Join Date: Mar 2007 Location: Purdue University | | | Re: Do These Kooks Cats Look Right? Quote:
Originally Posted by trukk Carefull, nothing get's Urby's panties in a twist quicker than spam posting to get to 30. Just trying to warn ya on that one.
-Chris | Good point....twisty panties are no good... | | Cadillac Discussion Tools | | |
Censor is OFF | | | |
