Go Back   Cadillac Owners Group > Current Cadillac Vehicle Discussion > Cadillac V-Series Forums > Cadillac CTS-V Series Forum - 2004 - 2007 > 2004-2007 Cadillac CTS-V Performance Mods
2004-2007 Cadillac CTS-V Performance Mods Discuss all Cadillac CTS-V performance modifications here. Engine tunes, exhaust, intake, suspension and more.
Cadillac Forums: B&B exhaust tabs..help
Old 01-28-08, 11:14 AM
Dean400hp's Avatar
Cadillac(s): Silver CTS V, Custom CAM, B&B Headers & pipes, K&N cai
View Dean400hp's Photo Album
Casino Cash: $1260
anyone run into the problem of rubber stoppers breaking away from tabs that hold pipes to frame of car ?
Dean
  #2 (permalink)
Old 01-28-08, 01:00 PM
jpoole's Avatar
Cadillac(s): 2005 Cadillac CTS-V
View jpoole's Photo Album
Casino Cash: $2145
Re: B&B exhaust tabs..help
Happened to me. I emailed B&B and they shipped some more out to me.
2005 Cadillac CTS-V (LS6/M6) - Red Line / Ebony (366 RWHP)
Ported & Polished TB, K&N CAIK, Taylor ThunderVolt 10.4 mm Wires, Dyno Tune, UUC Mounts
B&B Long Tube Headers with Cat-Less Connection Pipes, B&B Cat-Back with X-Pipe (cat-less and x in garage)
UUC Shifter & Bushings, UUC Flywheel, UUC Drilled & Slotted Rotors, HPS Pads, Hendrix Pro Axles
Z06 FRCs, V Headrests & Mats, BlueTooth, CTS Armrest, 3M Frontend Film, 35% Tint, BMR Strut Brace
  #3 (permalink)
Old 01-28-08, 02:47 PM
Cadillac(s): Cadillac
View mooreman6's Photo Album
Casino Cash: $2000
I recently installed the B&B system on my 05-V. The original GM exhaust does not mount to the car, the rear hangers hold the weight of the system up. I was wondering if the same could be done for the B&B, although I have not tried (I have the rubber mounts also). I realize the GM system is one-piece, and the B&B is several pieces held together by bolts, etc. My thoughts are that the rubber mounts may be transmitting some amount of noise or vibration into the cabin. Anyone tried running without the mounts?
  #4 (permalink)
Old 01-28-08, 03:02 PM
Cadillac Owners Enthusiast
Cadillac(s): CTS-V
View Bueller's Photo Album
Casino Cash: $5664
HMMM. I bought my B&B used and slid the muffler tabs into the stock rubber hangers. It didn't come with any other rear mounts other than what is welded to the muffler. No problems here.
  #5 (permalink)
Old 01-28-08, 03:35 PM
Cadillac(s): 05' Stealth Gray CTS-V, UUC STS, Cags Eliminator
View keithsm2's Photo Album
Casino Cash: $4034
anyone have a loud resonance or drone in 6th gear between 50 and 60 mph???
I end up using 5th gear more.....maybe the mounting could be changed??
  #6 (permalink)
Old 01-28-08, 04:15 PM
heavymetals's Avatar
Cadillac(s): 05 maggied CTS-V, 03 maggied Z06
View heavymetals's Photo Album
Casino Cash: $19122
I don't use 6th until I am at 62 as the drone when adding gas at that speed is a little objectionable.
I am so expensive I can't even afford to hire me....
  #7 (permalink)
Old 01-28-08, 04:17 PM
Casino Cash: $2000
Bueller, the mufflers do mount to the existing rear rubber hangers. The resonator has a hanger molded to it that screw into the belly of the car where the original piece of aluminum with two bolts went. That piece was about 12 inches wide. Also, Keithsm2, I have the drone in 6th around 50mph or so.
  #8 (permalink)
Old 01-28-08, 10:45 PM
Crawler's Avatar
Cadillac(s): 07 CTS-V
View Crawler's Photo Album
Casino Cash: $3660
I wouldn't worry about the drone at 50 in 6th. I'd worry about the fuel mileage.
I don't know about your V but mine better be at 55 or better to use 6th. Otherwise my mileage tanks.
~WS~
  #9 (permalink)
Old 01-29-08, 12:55 AM
PISNUOFF's Avatar
Cadillac(s): 2007 CTS-V
View PISNUOFF's Photo Album
Casino Cash: $9210
I have the drone also. It really coincides with about 1500 rpm's more than any distinct vehicle speed. I was thinking about sound deadening the trunk area and under the rear seat. Has anyone else done this, and did it help any?
  #10 (permalink)
Old 01-29-08, 03:03 AM
GMBOUND's Avatar
Cadillac(s): 2006 INFRARED CTS-V - BADCADY
View GMBOUND's Photo Album
Casino Cash: $4824
~WS~
I jump into 6th while obeying the 40MPH speed limit while in the residential area before I make it to the freeway.
I thought I was saving gas by keeping my RPMs down.
Trunk, Self panel and just under the rear seat is sound deadened. Makes a difference but not much.
Dean
NO
  #11 (permalink)
Old 01-29-08, 08:58 AM
Casino Cash: $4034
I checked my instant mileage at 60 mph...between 5th and 6th gear........6th gear provided the best mileage....by 3 or 4 mpg at least..
  #12 (permalink)
Old 01-29-08, 09:43 AM
Dean400hp's Avatar
Casino Cash: $1260
I talked to B&B and they are sending me new ones...great guys!
Only problem is I screwed a bolt in there temporarily and it freak'n snapped!
can the dealer get it out and still be able to put correct threading in frame part?
  #13 (permalink)
Old 01-29-08, 10:23 AM
Crawler's Avatar
Casino Cash: $3660
Mine was exactly the opposite.
Maybe it has to do with LS2 vs LS6.
~WS~
  #14 (permalink)
Old 01-29-08, 11:31 AM
View atdeneve's Photo Album
Casino Cash: $9348
Dude, check it again. Regardless of vehicle/engine/fuel/whatever, you'll always get better gas mileage when coasting in a higher gear, at any given speed.
Try this. Hop on a bike and pedal for a mile in 1st gear. Now do it again, but in the highest gear. Which one was easier? Yup. So, which one do you think expended more fuel. There you go. With the amount of energy you spent pedaling for one mile in first gear, you could have probably gone ten miles in the highest gear, without breaking a sweat.
  #15 (permalink)
Old 01-29-08, 11:59 AM
Cadillac(s): CTS-V
Casino Cash: $5664
Gotcha,
Mine has a different setup at the resonator, I got it used. I know it didn't come with this mount. It is a rubber mount with a threaded bolt out of both sides. This screws into the stock location and has a rubber bushing between the tabs with a nut holding it on the other side. Like a 2 sided threaded rod with a rubber center. Works well and allows a bit of movement like the muffler hangers.
I have the 2.5" touring and no drone but it is kinda quiet all the time, just deeper than stock.
As for 6th when going slow, I think your mileage would be worse too. Try the same bicycle test when going very slow. Go a mile at 1 mph in low gear, then go the same mile in top gear when it is very hard to turn to start off, and continue at low speed. Keep going slow and your legs will kill after that mile in top gear, and you barely have to put any effort into getting it to crank over in low gear, although it goes around many more times. Lugging the motor is not efficient.
Tags: , ,
bandb, exhaust, tabshelp
Censor is OFF
