| 2004-2007 Cadillac CTS-V Performance Mods Discuss all Cadillac CTS-V performance modifications here. Engine tunes, exhaust, intake, suspension and more. | Cadillac Forums: Take off your "performance" intake. You'll thank me.
12-31-07, 01:31 AM
|  | Cadillac Owners Connoisseur | | Join Date: Feb 2006 Location: Arizona | | | Re: Take off your "performance" intake. You'll thank me. |
12-31-07, 04:32 PM
|  | SUPERBOWL Champions. Just saying. Cadillac(s): 560 HP Blitzburgh Edition CTS-V | | Join Date: Sep 2004 Location: Steeler Nation | | | Re: Take off your "performance" intake. You'll thank me. Quote:
Originally Posted by The Tony Show My tune is set for "no-pop" already. This wasn't the little popcorn noise on decel, either- it literally backfired on the 1-2 and 3-4 shift until the engine was warmed up.
WoooooooOOOOOO- POW! - WoooooooOOOOOOO - POW! | lol, I've had sex that sounds kind of like that.
__________________ { This message is composed of 100% recycled sub-atomic particles. No trees were harmed in the posting of this message. However, billions of electrons were temporarily inconvenienced. |
12-31-07, 11:35 PM
|  | <10 poasts, CF newbie Cadillac(s): 2007 CTS-V Thunder Gray w/ Lt Gray interior | | Join Date: Mar 2007 Location: Sunny CA. Age: 43 | | | Re: Take off your "performance" intake. You'll thank me. Might want to see a doctor.
__________________ Friendship is like peeing your pants, everyone can see it, but only you can feel it's true warmth. |
01-02-08, 12:13 PM
|  | How YOU doin? Cadillac(s): 2007 SRX (Previously 04 CTS-V) | | Join Date: Dec 2004 Location: Over here. No, not there. | | | Re: Take off your "performance" intake. You'll thank me. C'mon, people- All you defenders of the intake that are crafting crossover systems that would make MacGuyver proud, and no one's bought my Lingenfelter yet?
__________________ |
01-02-08, 10:52 PM
| | Cadillac Owners Connoisseur Cadillac(s): 2005 CTS-V, 2005 Escalade EXT, 2007 Escalade EXT | | Join Date: Apr 2007 Location: Sandbox, Kuwait | | | Re: Take off your "performance" intake. You'll thank me. Quote:
Originally Posted by The Tony Show C'mon, people- All you defenders of the intake that are crafting crossover systems that would make MacGuyver proud, and no one's bought my Lingenfelter yet?  | Sorry buddy, got a new virgin one from them with other little goodies....
If only you put it up sooner, would have grabbed it like the other stuff... |
01-02-08, 11:26 PM
|  | <10 poasts, CF newbie Cadillac(s): 2007 CTS-V Thunder Gray w/ Lt Gray interior | | Join Date: Mar 2007 Location: Sunny CA. Age: 43 | | | Re: Take off your "performance" intake. You'll thank me. There must be someone out there that would want it. |
01-03-08, 07:19 AM
| | Cadillac Owners Member | | Join Date: May 2006 Location: Poughkeepsie, New York | | | Re: Take off your "performance" intake. You'll thank me. Folks:
I to removed the POS Lingfelter 'performance filter' off of my 06. Bascially it doesn't fit properly, uses a heat soaking metal runner tube that simply too short... Notified LPE and they sent me the exact same POS. The units I installed on GTO's are far superior to this unit. I too went back to the stock box, and might fabricate a new runner tube, and give it another next spring..... |
01-03-08, 12:59 PM
|  | Cadillac Owners Master Cadillac(s): '05 CTS-V | | Join Date: Jul 2004 Location: Elkridge, MD Age: 37 | | | Re: Take off your "performance" intake. You'll thank me. Quote:
Originally Posted by japx Folks:
I to removed the POS Lingfelter 'performance filter' off of my 06. Bascially it doesn't fit properly, uses a heat soaking metal runner tube that simply too short... Notified LPE and they sent me the exact same POS. The units I installed on GTO's are far superior to this unit. I too went back to the stock box, and might fabricate a new runner tube, and give it another next spring..... | It took me a while to get the LPE sorted out just right on my car, so it wouldn't pop off.
The metal insert is in there, so the airbox doesn;ty saw a hole through a softer material. That was a huge issue with the More Performance Intake, when it first came out.
I've found that the best way to install the LPE, is to connect the metal pipe to the airfilter first. push it all the way into the cone, so that you have between 5/8th and 3/4'ers of and inch depth, and then really crank the filter on tight. Next install the heat shield, but don't tighten down the bolts. There needs to be some play in the heat shield, so you can #1 get the filter in with the metal insert already attached, and #2, so that when you engine moves due to torque, the heat shield can move some, and won't pop off your filter. After that connect the metal tube to the MAF, and tighten that sucker up. This should keep your LPE nice and tight, and leak free. I'm in the habit now of checking the oil level in the car at least once a week (to be safe), at the same time, I do a quick double check on the LPE for leaks. After the first few months, and really getting it sorted out, I haven't had a leak since.
-Chris
__________________ 2005 CTS-V:No Roof|FG2|Corsa|UUC Shifter, B-Lines, Motor/Tran Mounts, Diff Bushings|LPE CAI|FFV IntakeTube|Hawk HP+ |Hotchkis Sways|Kooks 1.75 Coated LTs + cats|KARS III |Mamofied Fast90 + NW90|224/228 111+0 XFI/XE-R .609/.588|ATI 25% UD Pulley|YT 1.7" UltraLites|Melling HiFlow Oil Pump|Comp Chromeoly 7.425" PR's|Cloyes Hex Adjust Timing Set|Lucas 42# Flow Matched Injectors|Patriot Gold Xtreme Springs, Ti retainers, Super 7 locks|All ARP Fasteners|Mustang Dyno Tuned (SAE): 412rwhp / 380 rwtq |
01-03-08, 01:45 PM
|  | Cadillac Owners Connoisseur Cadillac(s): '05 CTS-V, '00 SLS, 98 SLS, 89 Eldo, '80 Eldo | | Join Date: Mar 2006 Location: NYC Age: 38 | | | Re: Take off your "performance" intake. You'll thank me. I dont know how you guys can argue against the power gained from a CAI. When I got mine, the box said up to 15 RWHP! I wish I could put 4 of them in my car. That's 60 RWHP for 1000 bucks!!! How many people wouldn't jump on that?
On top of that, its so easy to install. In my book, a quality CAI is by far the best mod you can get for your car.
__________________ '05 Platinum l LPE CAI l Magnaflow l V1 (hardwired), w/ custom mount l UUC shifter w/Lindsay bushings l UUC leather shift knob l K9 GEAR rear seat cover l CruiseCam l HID fogs l Falken RT-615s l Hotchkis sways W/Z06 end links l Billet A/C vent knobs l Hawk HP+/HPS l CG-Lock l Specter Werkes Bushings l Noah Custom cover l FG2s l Ground control 550/600 l MAGGIE 436RWHP/ 412RWTQ (Dynojet) l Heavys fire extinguisher bracket l Intercepter scan-gauge l Billet pedals l Meth l NO HEADERS |
01-03-08, 02:55 PM
| | Cadillac Owners Fanatic Cadillac(s): 05 Black CTS-V | | Join Date: Oct 2007 Location: Central FL | | | Re: Take off your "performance" intake. You'll thank me. Quote:
Originally Posted by Twitch I dont know how you guys can argue against the power gained from a CAI. When I got mine, the box said up to 15 RWHP! I wish I could put 4 of them in my car. That's 60 RWHP for 1000 bucks!!! How many people wouldn't jump on that?
On top of that, its so easy to install. In my book, a quality CAI is by far the best mod you can get for your car. | http://contour.org/ceg-vb/showthread...ghlight=intake
A system like the one in the link should get you about twice the power! |
01-03-08, 03:43 PM
Originally Posted by randycsvt | Hey now, duals have their place, just not on that POS http://www.hennesseyperformance.com/...ctionReq=Where
-Chris
P.S. This intake cost $800, and adds 6rwhp!! |
01-17-08, 03:15 AM
|  | Cadillac Owners Member Cadillac(s): 09 CTS-V, 06 EXT, former 05 CTS-V | | Join Date: Apr 2006 Location: Seattle | | | Re: Take off your "performance" intake. You'll thank me. don't get me wrong i love my V but that is pretty. | | Cadillac Discussion Tools | | |
Censor is OFF | | | |
