| 2004-2007 Cadillac CTS-V Performance Mods Discuss all Cadillac CTS-V performance modifications here. Engine tunes, exhaust, intake, suspension and more. | Cadillac Forums: Easy guide to installing UUC shifter from the top
04-01-09, 06:22 PM
|  | Truck Motor FTW! Cadillac(s): 2006 CTS-V | | Join Date: Aug 2007 Location: Chicago, IL | | | Re: Easy guide to installing UUC shifter from the top oh chamfer is really just a beveled edge. So in the case of these bushings, when they to chamfer it a little what they mean is taking a little material out from the inside of the bushing to help it slide in a little. Leave the outside alone as it's used to "lock into place"
Peeling a little on the inside on like a 45 degree from the outside edge is what they are talking about. I'm trying to picture what heavy is talking about.... +1 on WD40 or some soapy water... that helps a ton to lude it up a little bit |
04-01-09, 07:14 PM
|  | It's a V thing. Cadillac(s): 05 LS6 Stealth Grey | | Join Date: Dec 2004 Location: Tailgating at Giants Stadium Age: 29 | | | Re: Easy guide to installing UUC shifter from the top Thank you. I'll take photos, but will need help posting. I can only link to photobucket or something like that. It never works out, but we'll cross that bridge next week!
One more question, I'm reading aboiut tightness of bolts so it doesn't move around or feel too tight, also locktite. I'm guessing when reassembling, tighten the bolts, shift a little for feel and make adjustments. Once I'm satisfied, I can locktite. In using it at work I know it's difficult to open them again once it dries, and I'd rather not have to. |
04-01-09, 10:58 PM
|  | Cadillac Owners Fanatic Cadillac(s): 2007 Cadillac CTS-V Series | | Join Date: Oct 2004 Location: McLean, VA Age: 25 | | | Re: Easy guide to installing UUC shifter from the top Quote:
Originally Posted by VJester They modify your stock shifter to reduce the throw. You get the stock quietness with improved shifting via the new bushings. I called and it's $100 to modify the stock shifter so I'm guessing $150 by the time you ship it both ways and tax. Just type in TPIS on the web - i think they are a sponsor here too. Like I said just my opinion but your saving at least $200. | has anyone actually done this? feedback would be lovely  |
04-05-09, 11:10 AM
|  | It's a V thing. Cadillac(s): 05 LS6 Stealth Grey | | Join Date: Dec 2004 Location: Tailgating at Giants Stadium Age: 29 | | | Re: Easy guide to installing UUC shifter from the top A big shout to all that contributed to this thread. I used this, the faq and the instructions for a hybrid attempt. Over all it went pretty well. It took me 6 hours total. I got stuck in a couple of places that just added to the time, but looking back it was a good experience. Thank god I'm small and have small hands. Trying to remove the exhaust I broke a bolt holding it to the flange. When drilling the rivits since I couldn't get at them from underneath, one walked a little and I had an interesting time trying to wear away the rivit part holding on still. One part that was really frustrating was the bushings. I knew that was coming and got a little frustrating. When installing the left one went on so easy. The right one, not so much. At this point Lilgcts-v showed up and lent a hand. I definately couldn't of gotten it done with out him, so Thank You! He helped me get the shifter itself attatched, I put some washers around the new bolts the kit supplies to help make up for where it walked. Taking it for a short spin was a dream. It makes the rest of the car feel loose. I took pictures, but between all three sources, there isn't anything not covered. Again thank you for all the previous posts and valuable information. I can't believe I waited 89,433 miles to do this. |
04-05-09, 03:53 PM
| | BLING IS AMERICAN RICE Cadillac(s): '04 CTS-V | | Join Date: Jun 2004 Location: Just North of Titletown... | | | Re: Easy guide to installing UUC shifter from the top almost 90k miles???
when I drilled out the rivets, I did it from the bottom. ever get tiny metal shards in your scalp? not pleasant...
__________________ The Caddy that zigs?
So they were a generation late... Will getting rid of poast counts change how I poast? Dream on...
Currently in the rare 20,000 poast club. 23,165 and counting... |
04-05-09, 05:12 PM
|  | 1,000,000,000 posts Cadillac(s): 2004 CTS-V | | | | | Re: Easy guide to installing UUC shifter from the top Quote:
Originally Posted by thebigjimsho almost 90k miles???
when I drilled out the rivets, I did it from the bottom. ever get tiny metal shards in your scalp? not pleasant... | when installing my b&m I had to rest my head periodically on the driveway...
2 days after my install, im washing my hair and feel this sharp pain. I had a good chunk of a drilled rivet stuck in my head and I literally had to grab and pull it out. didnt feel good! |
04-05-09, 05:19 PM
| | BLING IS AMERICAN RICE Cadillac(s): '04 CTS-V | | Join Date: Jun 2004 Location: Just North of Titletown... | | | Re: Easy guide to installing UUC shifter from the top Quote:
Originally Posted by CadzillaTN when installing my b&m I had to rest my head periodically on the driveway...
2 days after my install, im washing my hair and feel this sharp pain. I had a good chunk of a drilled rivet stuck in my head and I literally had to grab and pull it out. didnt feel good! | yeah, I wanted to keep scratching my scalp. what I needed to do was not touch my head. I needed a LONG shower to get most of it out. I spent the following weekend at the beach and was still finding shards as I would dip under the water... |
04-06-09, 12:29 AM
|  | It's a V thing. Cadillac(s): 05 LS6 Stealth Grey | | Join Date: Dec 2004 Location: Tailgating at Giants Stadium Age: 29 | | | Re: Easy guide to installing UUC shifter from the top |
04-06-09, 12:43 AM
|  | Cadillac Owners Connoisseur Cadillac(s): 2005 Platinum CTS V with Black leather | | Join Date: Apr 2008 Location: North Jerzey | | | Re: Easy guide to installing UUC shifter from the top see i thought i was being real slick by drilling out the rivets from the top... but after when i was under the car bolting in the katech stalk, i kept bumping into the resonator with my forearm knocking the metal shavings into my eyes and hair..
bottom line it was worth it |
04-06-09, 12:56 AM
| | BLING IS AMERICAN RICE Cadillac(s): '04 CTS-V | | Join Date: Jun 2004 Location: Just North of Titletown... | | | Re: Easy guide to installing UUC shifter from the top goggles are a must!!! |
04-06-09, 01:30 AM
|  | It's a V thing. Cadillac(s): 05 LS6 Stealth Grey | | Join Date: Dec 2004 Location: Tailgating at Giants Stadium Age: 29 | | | Re: Easy guide to installing UUC shifter from the top I was saying that to myself during this step. I just squinted. |
04-08-09, 12:18 PM
|  | Cadillac Owners Member Cadillac(s): 2005 Cadillac CTS-V, Stealth Grey | | Join Date: Aug 2008 Location: Cedar Rapids, IA Age: 31 | | | Re: Easy guide to installing UUC shifter from the top Quote:
Originally Posted by ahahnu Get the flak guns out.... but what exactly does this mean? Taper the edge?
Mine is enroute (thanks Luke aka the enabler). It's looking like Saturday will be my install day. Between reading this thread and the instructions pdf'd on the faq, it seems someone as mechanically declined as myself can do it. I got a little ahead of myself this morning.... when warming the car up, I put it in reverse, and pulled the nob off. Gonna be a long couple of days. | Yup, taper the edge. I just took a razor and shaved the front corner a little bit. It ended up looking like something chewed on it, but it went in better. Uhhh, so to speak?
Basically, you turn the square lip from this (front view, not top view):
___
into this:
__
(Ignore the periods, this forum deletes any leading space)
Make sense?
Took me about 4 hours by myself in the driveway. If you're going to drill them from the top, make sure you punch the center of the rivet first to keep the drill centered (a phillips screwdriver and a hammer will do if you have nothing else). Mine went a little off center, which made it a real bitch to get the rest of the rivet out. If you're going to drill from the bottom, it sounds like you'll want to wear goggles. I drilled from the top, and I even got a small shaving in my eye as it fell off something underneath when I crawled under.
You'll love the new shifter! Huge difference. Pretty easy mod, with this guide. Do CAGS while you're under there, if you haven't already.
__________________ 05 Stealth Grey; CAGS, UUC Shifter--Luke's Busings, Armrest Conversion, SNOW TIRES!, Ipod Kit, more on the way! My other car goes mach 1.2 |
04-08-09, 12:57 PM
| | BLING IS AMERICAN RICE Cadillac(s): '04 CTS-V | | Join Date: Jun 2004 Location: Just North of Titletown... | | | Re: Easy guide to installing UUC shifter from the top Do CAGS with an oil change... |
08-17-09, 09:24 PM
| | Cadillac Owners Member Cadillac(s): 06 CTS-V | | Join Date: Aug 2009 Age: 30 | | | Re: Easy guide to installing UUC shifter from the top Sorry for the question I am sure has been answered somewhere, but will this install work with the Katech? I am going to install it this weekend. This is my first mod to the V. |
08-17-09, 09:31 PM
|  | How YOU doin? Cadillac(s): 2007 SRX (Previously 04 CTS-V) | | Join Date: Dec 2004 Location: Over here. No, not there. | | | Re: Easy guide to installing UUC shifter from the top All short shifters can be installed using this method.
__________________ | | Cadillac Discussion Tools | | |
Censor is OFF | | | |
