| 2004-2007 Cadillac CTS-V Performance Mods Discuss all Cadillac CTS-V performance modifications here. Engine tunes, exhaust, intake, suspension and more. | Cadillac Forums: Aftermarket Brake Rotor Options - I found two (2)...
05-20-07, 01:04 PM
|  | Cadillac Owners Enthusiast Cadillac(s): 2004 CTS-V | | Join Date: Mar 2005 Location: Gillette, WY Age: 28 | | | Aftermarket Brake Rotor Options - I found two (2)... I am quickly coming up on that time when I need to change out my rotors and pads and am looking for different options other than the GM cross-drilled rotors.
As far as pads go, I have narrowed the list down to Hawk HPS (a lot of guys on this forum really like them, same performance as stock, less dust, some people say they squeak) and Endless SS-M (better performance than stock, less dust, more $$$, and I have no idea how to order them from their Japanese site, LOL).
As for the rotors, I have found two options on Ebay and I wanted to show them to you guys and get any input on if they are shite or not, or if you know the brand, etc.
Here is the first rotor set, could be junk based on the price and I don't know anything about the brand Suzuka: http://cgi.ebay.com/ebaymotors/04-05...spagenameZWD1V
Here is the second set which looks very promising. Notice that the rotors are zinc plated, dimpled (not cross drilled, so that there is no lessening of the structural strength of the rotor itself, good for the road course), and slotted. And it appears that these are close to the price of the GM drilled: http://brakeperformance.com/site/bra...load=1&sort=3a
Let me know what you think. I have faith in you guys to sort out the good from the bad. CTS-V owners are the smartest people on the planet.
__________________ 2004 CTS-V Mods: Lingenfelter CAI, OEM style spoiler, CCW SP600 wheels (19"x9" and 19"x10"), Toyo Proxes R888 (F: 235/35YR19 - R: 295/30YR19), Magnaflow Cat-back, UUC Shifter w/ Lindsay bushings, FG2 shocks, GC Coilover Kit (600f/650r), Hotchkis Swaybars, Custom FRCs, Kooks 1 3/4" Cermakromed LT Headers & HiFlo cats, ARP Header Studs, Granatelli 1200* Wires, NGK TR55ix Plugs, OC Autosports D&S Rotors, Hawk Pads, SS Brake Lines, 561 Wheelhop Kit, D.R.E. Dyno Tune = 351 hp/ 365 ft-lbs (corrected) |
05-20-07, 01:44 PM
|  | Cadillac Owners Fanatic Cadillac(s): Cadillac CTS-V | | Join Date: Mar 2007 Location: Spokane, WA Age: 29 | | | Re: Aftermarket Brake Rotor Options - I found two (2)... I've looked into the same cheaper rotors as well but have decided not to do it. If you want the look and you are not into hardcore braking they will probably work but if you are really looking for performance I would steer clear of the Chineese made stuff. Some of it isn't bad but its awfully hit or miss for trying to save a few hundred bucks. |
05-20-07, 01:55 PM
|  | Cadillac Owners Enthusiast Cadillac(s): 2004 CTS-V | | Join Date: Mar 2005 Location: Gillette, WY Age: 28 | | | Re: Aftermarket Brake Rotor Options - I found two (2)... Thanks for your input.
I am definitely all about the performance aspect, I don't want anything that performs less than stock.
My wheels are so open that I would like different rotors for the looks also, but it appears that it might be impossible to find slotted (or slotted and dimpled) rotors that will perform as good as stock. I do take my V to the road course occasionally so I don't think cross-drilled is an option for me or anybody who tracks their car. |
05-20-07, 02:02 PM
|  | Cadillac Owners Fanatic Cadillac(s): Cadillac CTS-V | | Join Date: Mar 2007 Location: Spokane, WA Age: 29 | | | Re: Aftermarket Brake Rotor Options - I found two (2)... Isn't that kind of the point of cross drilled rotors (track use)? |
05-20-07, 04:31 PM
|  | Cadillac Owners Connoisseur Cadillac(s): 05' CTS-V | | Join Date: Feb 2006 Location: Palm Beach Gardens, FL Age: 24 | | | Re: Aftermarket Brake Rotor Options - I found two (2)... ^^^they dissipate more heat...so less chance of brake fade, but at the same time theres less area for the pad to bite onto, so your braking power diminishes slightly...it's all give and take. |
05-20-07, 04:39 PM
|  | Cadillac Owners Enthusiast Cadillac(s): 2004 CTS-V | | Join Date: Mar 2005 Location: Gillette, WY Age: 28 | | | Re: Aftermarket Brake Rotor Options - I found two (2)... Quote:
Originally Posted by The Hog Isn't that kind of the point of cross drilled rotors (track use)? | Cross-drilled rotors supposedly dissipate heat better, but they weaken the rotor itself and under extreme braking (high heat and friction) the area around the holes can crack, and over time can lead to the whole rotor cracking in half, not a good thing when you are going balls to the wall at the track.
I have some first hand knowledge of the non-cross-drilled application in a racing situation. Last year at the Denver Gran Prix I had the opportunity to sit in, a get an up close look, at an SCCA Touring Car (SRT-4) and the brake rotors were slotted and not cross-drilled for the very reason discussed above.
That is why I think the rotors with the dimples instead of drilling all the way through could potentially be a good thing for people who want the looks and performance of upgraded rotors, without the possibility of them exploding on the track. |
05-20-07, 10:24 PM
|  | Cadillac Owners Connoisseur Cadillac(s): The CuneMobile | | Join Date: May 2006 Location: Watchin ovar ur city | | | Re: Aftermarket Brake Rotor Options - I found two (2)... I'm not sure whose car this is, but they obviously found a slotted rotor option:  |
05-20-07, 10:30 PM
|  | Cadillac Owners Connoisseur Cadillac(s): 2007 Cadillac CTS-V | | Join Date: Apr 2007 Location: Plano, TX Age: 27 | | | Re: Aftermarket Brake Rotor Options - I found two (2)... |
05-20-07, 10:30 PM
| | BLING IS AMERICAN RICE Cadillac(s): '04 CTS-V | | Join Date: Jun 2004 Location: Just North of Titletown... | | | Re: Aftermarket Brake Rotor Options - I found two (2)... Quote:
Originally Posted by HushH I'm not sure whose car this is, but they obviously found a slotted rotor option:  | Yeah, when you're Mallett you can gave whatever rotors you want.
__________________ The Caddy that zigs?
So they were a generation late... Will getting rid of poast counts change how I poast? Dream on...
Currently in the rare 20,000 poast club. 23,165 and counting... |
05-20-07, 10:31 PM
| | BLING IS AMERICAN RICE Cadillac(s): '04 CTS-V | | Join Date: Jun 2004 Location: Just North of Titletown... | | | Re: Aftermarket Brake Rotor Options - I found two (2)... Ah yes, Katech. My bad... |
05-20-07, 10:36 PM
Originally Posted by HushH I'm not sure whose car this is, but they obviously found a slotted rotor option: | Whenever I see your screenname, I always think of Peter O'Toole... |
05-20-07, 10:53 PM
|  | Cadillac Owners Connoisseur Cadillac(s): The CuneMobile | | Join Date: May 2006 Location: Watchin ovar ur city | | | Re: Aftermarket Brake Rotor Options - I found two (2)... You'll have to forgive me Jim, I'm not very familiar with his roles or work. Was that a character or part of a famous line of his? |
05-20-07, 11:23 PM
| | BLING IS AMERICAN RICE Cadillac(s): '04 CTS-V | | Join Date: Jun 2004 Location: Just North of Titletown... | | | Re: Aftermarket Brake Rotor Options - I found two (2)... Gawd, it's Sunday and being sick all day has messed up my brain. I meant Peter Noone, Herman's Hermits lead singer... |
05-20-07, 11:27 PM
| | BLING IS AMERICAN RICE Cadillac(s): '04 CTS-V | | Join Date: Jun 2004 Location: Just North of Titletown... | | | Re: Aftermarket Brake Rotor Options - I found two (2)... |
05-21-07, 12:18 AM
Originally Posted by thebigjimsho Gawd, it's Sunday and being sick all day has messed up my brain. I meant Peter Noone, Herman's Hermits lead singer... | You have my nomination for threadjack of the year! | | Cadillac Discussion Tools | | |
Censor is OFF | | | |
