04-17-07, 06:25 PM
|  | Baddass V Lover | | Join Date: Jan 2005 Location: Newark, Ohio Age: 49 | | Details On The New Rear I'll give a complete description here and then projected final cost. - 3rd Generation Corvette Cast Iron Differential- This unit will be good for at least 600ftlbs ot Torque at the wheels. This is a completely new unit, casing, gears, posi-unit, bearings, rear HD cover. This also has oversized axle out put stubs, allowing the use of a much larger u-joint on the axle shafts going to the wheels.
- A One Piece Drivshaft, thus eliminating the silly flimsy wheel hop absorbing two piece factory unit. This obviously eliminates the carrier bearing, and all the clunky noises associated with it.
- HD U-Jointed 3" axle shaft tubes and the HD Joints that go with then, these joints are the size used on 1 Ton 4x4 Trucks. This eliminates the factory CV-Joint and skinny shaft setup completely, yes its a bit old school, but it works.
- Also, A Stage III Kit, with modified front mounting system, thus assuring a completely ridgid mounting system for the new diff.
I have taken and removed the weak link(s) in Our beloved Vs, the new diff, axles and driveshaft add a whole new level of piece of mind for the modified, and even aggressive V drivers amongst us.
This system is solidly mounted, thereby eliminating all the ridiculusly soft mounting points designed to halp absorb much of the out of control wheel hop issues, that of course only exist in the minds of V drivers. - Will this diminish the handling of the V? No, nothing I'm doing in this conversion, has any modification to the factory suspension, most I've met, love the ride and cornering ability of the V, just the weak rear setup along with the hop, has been a major turn-off.
- Will there be added noise? Actually, if your factory diff is whining, this should present its self quieter.
- Will the V now ride harsh? No, now My kit does stiffen the car up, helping to reduce body roll, and aiding in planting the tires to the ground, as well tightening the undercarriage up, putting you and the V in more direct contact with the road.
- Why on earth do You think I'd want to spend this much money on a car that I already spent this much money on? If you are asking that question, then you may not, but for those who drive aggressively, want to take their V to the track, Drag or Road Course, will find the peace of mind after this investment remarkable.
The basic setup, installed by Me, with all the above mentioned items included, is $5500.00.
The next step will be a $6000.00 Premium Package, this will add the auxilliary quad shock arrangement, attached to the lower control arm, and frame, thereby supporting the rebound weakness built into Oour factory shock/struts. This shock will have only minor compression, thus barely changing the softness of the ride, but will plant the rear tires into the ground, thereby eliminating the last of the suspension occillations causing the last bit of hop left.
Now, for anyone who wants to take their V into the 9 or even 8 sec qtr mile times, I can offer an bulletproof version of this setup, 12 bolts diff internals, etc..., this will add about $4000.00 to the premium version, please contact Me if you think you are ready for this.
Overview: I believe I'm offering a reasonably priced completely usable race level system you can drive daily with little to no change in the characteristics of the V. |
04-17-07, 06:40 PM
| | Cadillac Owners Connoisseur Cadillac(s): 2005 Stealth Gray CTS-V, 2009 Black CTS-V | | Join Date: Jun 2005 Location: CA | | | Re: Details On The New Rear How would this situation work for us dorks out here in, say, CA? |
04-17-07, 06:45 PM
|  | It's a V thing. Cadillac(s): 05 LS6 Stealth Grey | | Join Date: Dec 2004 Location: Tailgating at Giants Stadium Age: 30 | | | Re: Details On The New Rear I've been wondering about this. Good to hear coming from you Doug. |
04-17-07, 08:36 PM
| | Cadillac Owners Fanatic | | Join Date: Mar 2005 Location: North Pole, AK | | | Re: Details On The New Rear How about just the one piece drive shaft only? I would really like to completely eliminate the clunk! I don't have 5 grand for the entire set up but could do just the drive shaft. Thanks for all of your work on this. With every ones efforts well will finish the work GM should have done in the first place! |
04-17-07, 08:50 PM
|  | '09 w/600 H.P. is trouble for me! Cadillac(s): '04 Plat CTS-V | | Join Date: Mar 2006 Location: Central,FL and LI, NY | | | Re: Details On The New Rear Quote:
Originally Posted by Luna. How would this situation work for us dorks out here in, say, CA? | I can help answer this one from talking to Doug extensively on the phone 2 days ago. There will be instructions and it is going to be simple to change it out for your local mechanic or yourself.
The part that I think is misleading is Doug says that the dual shock system will eliminate whatever wheel hop is left but I think he would mean wheel skip! All it could do at that point, with his stage 3 kit, is skip and I would think that would be only under extreme conditions. I thought the shock system would make it bite harder and eliminate any 'skipping' left. Correct me if I am wrong here Doug! |
04-17-07, 09:25 PM
|  | Super Mod Cadillac(s): 07 STS-V Platinum | | Join Date: Aug 2003 Location: North Coast, OH Age: 43 | | | Re: Details On The New Rear how can I get in on this smokin deal????
F |
04-17-07, 09:40 PM
| | Cadillac Owners Fanatic Cadillac(s): CTS-V | | Join Date: May 2005 Location: California | | | Re: Details On The New Rear Quote:
Originally Posted by Luna. How would this situation work for us dorks out here in, say, CA? | I would guess that we save some $$ in install labor and pay whatever we saved in shipping - I'm in anyway. Maybe those of us interested here in California could order at once and ship together saving a little?
Marty |
04-17-07, 09:43 PM
Originally Posted by Florian how can I get in on this smokin deal????
F | Silly Florian! |
04-17-07, 10:46 PM
|  | Cadillac Owners Enthusiast Cadillac(s): CTS-V | | Join Date: Jan 2005 Location: Highland Village, TX Age: 44 | | | Re: Details On The New Rear I would be interested as well to be installed local in DFW. |
04-18-07, 09:22 AM
|  | '09 w/600 H.P. is trouble for me! Cadillac(s): '04 Plat CTS-V | | Join Date: Mar 2006 Location: Central,FL and LI, NY | | | Re: Details On The New Rear Bump...  |
04-18-07, 09:23 AM
|  | How YOU doin? Cadillac(s): 2007 SRX (Previously 04 CTS-V) | | Join Date: Dec 2004 Location: Over here. No, not there. | | | Re: Details On The New Rear Quote:
Originally Posted by Ak Jim How about just the one piece drive shaft only? I would really like to completely eliminate the clunk! I don't have 5 grand for the entire set up but could do just the drive shaft. Thanks for all of your work on this. With every ones efforts well will finish the work GM should have done in the first place! | Ditto on the driveshaft only question.
Kudos to you for working so hard on this. I hope you can get a patent for the design and keep the leeches from stealing your work. If I was a drag racer, I'd be all over this.
__________________ |
04-18-07, 03:33 PM
|  | It's a V thing. Cadillac(s): 05 LS6 Stealth Grey | | Join Date: Dec 2004 Location: Tailgating at Giants Stadium Age: 30 | | | Re: Details On The New Rear Quote: |
If I were a drag racer, I'd be all over this.
| You should see his S-10.
Fl, don't you have one already? Bastard. |
04-18-07, 04:32 PM
|  | Super Mod Cadillac(s): 07 STS-V Platinum | | Join Date: Aug 2003 Location: North Coast, OH Age: 43 | | | Re: Details On The New Rear Quote:
Originally Posted by ahahnu You should see his S-10.
Fl, don't you have one already? Bastard. | Ah,
My V is the guinea pig...its being massaged by the gentle hands of Doug now. Should have it in a few weeks. Im pretty excited to report back here when Im done. Ive had tons of issues with the rear, Doug should be able to cure them all....
As for my post, I was just pullin chains....
F |
04-18-07, 08:04 PM
|  | It's a V thing. Cadillac(s): 05 LS6 Stealth Grey | | Join Date: Dec 2004 Location: Tailgating at Giants Stadium Age: 30 | | | Re: Details On The New Rear Yeah your silo will be rising once he gets it dialed in. |
04-18-07, 08:11 PM
|  | '09 w/600 H.P. is trouble for me! Cadillac(s): '04 Plat CTS-V | | Join Date: Mar 2006 Location: Central,FL and LI, NY | | | Re: Details On The New Rear Florian will see what else he can break when the rear is done! LOL | | Cadillac Discussion Tools | | |
Censor is OFF | | | |
