| 2004-2007 Cadillac CTS-V Performance Mods Discuss all Cadillac CTS-V performance modifications here. Engine tunes, exhaust, intake, suspension and more. | Cadillac Forums: New Coil Over Kit Released Today!!!!!
03-19-07, 08:01 PM
| | my name is Tiffany Cadillac(s): 05 CTS-V | | Join Date: Mar 2003 Location: San 'tone, TX | | | Re: New Coil Over Kit Released Today!!!!! Quote:
Originally Posted by UMStuning/ApexMtrspt just payed to be a supporting member | cool
let me watch for it to go through...sometimes the first paypal takes time for approval. i'll get you set up  |
03-19-07, 08:25 PM
| | Cadillac Owners Member Cadillac(s): Cadillac | | | | | Re: New Coil Over Kit Released Today!!!!! working on the spring rates
and there are 4 CTS-V kits left right now |
03-19-07, 08:30 PM
|  | Cadillac Owners Member Cadillac(s): Dodge viper srt-10, 07 V | | Join Date: Mar 2005 Location: SO CAL Age: 36 | | | Re: New Coil Over Kit Released Today!!!!! Quote:
Originally Posted by UMStuning/ApexMtrspt working on the spring rates
and there are 4 CTS-V kits left right now | If you guys can get me 750lb front and 800 rear im in.  |
03-21-07, 01:10 AM
| | Cadillac Owners Connoisseur Cadillac(s): 2004 V | | Join Date: Feb 2004 Location: Calif. Age: 42 | | | Re: New Coil Over Kit Released Today!!!!! Wow... i'm impressed... ingenious design.
The entire shock body is threaded... the threads are not only for the spring height adjustment... but to vary the length of the whole shock! So no matter how much you lower the car... the shock length can be adjusted so the shock always stays in it's 'sweet spot' compression range. So the shock valving doesn't get screwed up because you're constantly running the shock fully compressed in it's last 1" of travel.
Shock on left is front shock... threads used for spring perch adjustment and shock length adjustment.
Shock on right is rear shock... threads are used only for shock length adjustment. The spring sits in the stock location.
oooooh... adjustable shocks
I'll install the kit this weekend
03-21-07, 09:13 AM
| | my name is Tiffany Cadillac(s): 05 CTS-V | | Join Date: Mar 2003 Location: San 'tone, TX | | | Re: New Coil Over Kit Released Today!!!!! come install mine |
03-21-07, 12:53 PM
| | Cadillac Owners Connoisseur Cadillac(s): 2004 V | | Join Date: Feb 2004 Location: Calif. Age: 42 | | | Re: New Coil Over Kit Released Today!!!!! ...that'll cost you a lot of...  |
03-21-07, 01:35 PM
Originally Posted by UMStuning/ApexMtrspt just payed to be a supporting member | Waiting to hear about spring rates?  |
03-21-07, 03:12 PM
|  | Cadillac Owners Master Cadillac(s): '05 CTS-V | | Join Date: Jul 2004 Location: Elkridge, MD Age: 37 | | | Re: New Coil Over Kit Released Today!!!!! Dreamin et al,
I was under the impression from the title of this thread, that this was a 'true' coilover application. I guess if I had actually looked at the picture for longer than .002 seconds, I would have noticed that this is not the case for the rear.
This brings up a few questions:
1) How much does not using a full coilover in the rear affect the perfromance? I know the Penske setup was supposed to be that way, and I know the mallet rear is a full coilover (I've seen that setup in person). If one is only giving up say 25%, but is saving 200% cost-wise (or more), this may be a compromise many of us would be more than willing to make.
2) How much 'extra performance' and/or 'tunability' will the adjustable shocks & dual adjustable spring perches (like Dreamin described in his post), provide vs. say Ground Control + FG2's? I already have FG2's, and was planning on going ground control as my next mod. If the gain between the two setups isn't that much, it may be smart to just save the $400 bucks in my case (??)
I plan on doing a couple roadcourse HPDE's each year ( 2 -4 probabaly). I also am not averse to having the car drive 'stiffly sprung'. My main concern is to be able to lower the car about 1", and have it handle/perform better, while remaining as neutral as posible (I loved the bone stock neutrality of the car). I guess bonus points for something that could be set to be even stiffer and/or lower while actually at the track.
A few odd's and ends:
- My car is a DD.
- I run a stagered tire setup 275/35 245/40 (so I can run a bit lower than stock)
- I have Hot's bars (I also picked up Florian's set of C5 Z06 endlinks, that I will install once the car is lowered).
Any advice anyone can give would be much appreciated (especailly Dreamin, RGD and Feff.)
-Chris
__________________ 2005 CTS-V:No Roof|FG2|Corsa|UUC Shifter, B-Lines, Motor/Tran Mounts, Diff Bushings|LPE CAI|FFV IntakeTube|Hawk HP+ |Hotchkis Sways|Kooks 1.75 Coated LTs + cats|KARS III |Mamofied Fast90 + NW90|224/228 111+0 XFI/XE-R .609/.588|ATI 25% UD Pulley|YT 1.7" UltraLites|Melling HiFlow Oil Pump|Comp Chromeoly 7.425" PR's|Cloyes Hex Adjust Timing Set|Lucas 42# Flow Matched Injectors|Patriot Gold Xtreme Springs, Ti retainers, Super 7 locks|All ARP Fasteners|Mustang Dyno Tuned (SAE): 412rwhp / 380 rwtq |
03-21-07, 04:06 PM
| | Cadillac Owners Connoisseur Cadillac(s): 2004 V | | Join Date: Feb 2004 Location: Calif. Age: 42 | | | Re: New Coil Over Kit Released Today!!!!! 1) Personally, i would not run a 'true' coil-over in the rear. Moving the springs ontop of the shocks puts the entire weight of the rear on the shock towers. We dont know if GM designed the towers to handle the weight of the car... there could be long term fatigue issues... and in an accident if that piece fails, the springs are pointed right at the rear passenger's spine. With that said, I trust Mallett... he has connections into GM and if he is running a true coil-over, it make me feel a little better.
But I dont see any performance disadvantage to leaving the spring in their stock location... the suspension geometry is as GM designed it; the weight of the car is as GM designed it; the performance increase comes from just lowering the car.
2) Being able to adjust the shock length is huge (in my opinion)... running shocks overly compressed (do to lowering the car) shortens the life of the shock, and completely screws up the shock valving. This kit solves that problem.
With that said, lowering 1" +/- the stock shocks are fine (proven by how many people are running/tracking the GC kit with stock shocks)... Going any lower is going to be a problem for the stock shocks.
As far as 'tunability' of the shocks over the FE4 and FG2... i can tell you after I install the kit. I will set the new shocks at 'full hard' to see how stiff they are over the stock shocks... Keep in mind insanely stiff shocks will only improve performance on a track... a smooth track... on the street you upset the car's suspenion and hurt performance.
FWIW, if I had spent the money for the FG2 and the GC kit... I would not be changing to this kit.
Neutral handling has to be tested... I think this kit will understeer... I may endup running my GC springs with this kit... i am *very* happy with those springs rates.
And normally you dont change ride height for track events (it screws up your alignment)... but being able to crank up the shocks for track use helps a lot.
Odds and ends)
Running the springs rates we're talking about 500-600lbs range, the car will still be a DD
With 35 and 40s... you could lower more than 1" |
03-21-07, 04:13 PM
|  | Cadillac Owners Member Cadillac(s): Dodge viper srt-10, 07 V | | Join Date: Mar 2005 Location: SO CAL Age: 36 | | | Re: New Coil Over Kit Released Today!!!!! Dreamin, I forgot, what spring rates are you running right now with your GC set up? Thanks, Mike |
03-21-07, 04:31 PM
Originally Posted by Dreamin ...that'll cost you a lot of...  | they sell that here
if you like it, if its all that its supposed to be....i will fly you out to help
i have a tax refund check that still unspent  |
03-22-07, 01:38 PM
and there are 4 CTS-V kits left right now | APEX, what's going on with the spring rates? |
03-22-07, 04:35 PM
| | Cadillac Owners Member Cadillac(s): Cadillac | | | | | Re: New Coil Over Kit Released Today!!!!! Quote:
Originally Posted by urbanski cool
let me watch for it to go through...sometimes the first paypal takes time for approval. i'll get you set up  | I had a problem with paypal, I sent another one |
03-22-07, 04:37 PM
Originally Posted by vettethret APEX, what's going on with the spring rates? | I am picking up a kit right now for a local guy, I will talk to Ksport about spring rates |
03-22-07, 04:52 PM
Originally Posted by UMStuning/ApexMtrspt I am picking up a kit right now for a local guy, I will talk to Ksport about spring rates | O.k. What state are you guys located in?  | | Cadillac Discussion Tools | | |
Censor is OFF | | | |
