Go Back   Cadillac Owners Group > Current Cadillac Vehicle Discussion > Cadillac V-Series Forums > Cadillac CTS-V Series Forum - 2004 - 2007 > 2004-2007 Cadillac CTS-V General Discussion
2004-2007 Cadillac CTS-V General Discussion Discuss everything about the first generation Cadillac CTS-V that does NOT fall into either the Performance or Appearance Modification category.
Cadillac Forums: GM Rear Cradle Bushing Torque
Old 02-12-07, 06:52 PM
Cadillac(s): 2005 CTS-V
View SuperVeee's Photo Album
Casino Cash: $1345
I did some looking in the forum and couldn't find an answer so here goes.
I was rotating the tires with the rear up and tire off and noticed when I grabbed the big white front GM cradle (TSB bushing) that I could move it easily. Is this OK since there is not much load on the suspension with the wheel off or should it be torqued to 195 lbs with no movement?
Brent
  #2 (permalink)
Old 02-12-07, 10:30 PM
The Tony Show's Avatar
How YOU doin?
Cadillac(s): 2007 SRX (Previously 04 CTS-V)
View The Tony Show's Photo Album
Casino Cash: $18595
Re: GM Rear Cradle Bushing Torque
It shouldn't move, even with the wheel off. Tighten those ASAP.
  #3 (permalink)
Old 02-13-07, 07:14 AM
Lindsay Cadillac's Avatar
Alexandria, Va
Cadillac(s): Work on them all...
View Lindsay Cadillac's Photo Album
Casino Cash: $6688
That's normal... Those bushings (GM TSB bushings) fit loosely in the rear cradle mounts. You can still move them even after the bolts have been tightened to the proper spec...
James M. Pollack
Service Director
jpollack@elindsay.com
Disclaimer: I sign my posts with my name and position at Lindsay Cadillac so people know who I am. Any opinions expressed on the forums ARE MY OWN and do not necessarily reflect the views of Lindsay Automotive, unless I specifically state that I am speaking on behalf of Lindsay Automotive.
  #4 (permalink)
Old 02-13-07, 08:43 AM
How YOU doin?
Casino Cash: $18595
Really? Shows what I know.... Guess that's why I'm a salesman, not a tech.
D'oh!
  #5 (permalink)
Old 02-13-07, 09:07 AM
Alexandria, Va
Casino Cash: $6688
D'oh!
Well, when you think about it... You wouldn't think they should move, but they do...
Of course then they wouldn't make noise and we wouldn't want that now would we...
  #6 (permalink)
Old 03-16-07, 10:52 PM
Cadillac(s): CTS-V
View Kingpin08's Photo Album
Casino Cash: $5460
are the tsb bushings a different material? are there any harder bushings that can replace the stock ones? i hate that slop
  #7 (permalink)
Old 03-17-07, 07:19 AM
ewill3rd's Avatar
Cadillac Technician
Cadillac(s): none
View ewill3rd's Photo Album
Casino Cash: $16917
What maintains the pressure on the bolt has nothing to do with the bushings.
The bushings are a loose fit, as James said.
Inside the mount itself cast into the rubber, is a metal sleeve. The bolt goes through the flat washer and that hits the sleeve on the bottom and the floor pan area on the top. When you torque the bolt the sleeve is tight on the flor and the washer but the bushings just fit into the gaps in the mount to keep center part with the sleeve from moving around.
The Spectre bushings are VERY tight and shouldn't move, but the GM TSB bushings are much thinner and just sit in the holes.
If you suspect the bolts may actually be loose you should check them, but it is normal for the bushings to move.
  #8 (permalink)
Old 03-17-07, 09:17 AM
BLING IS AMERICAN RICE
Cadillac(s): '04 CTS-V
View thebigjimsho's Photo Album
Casino Cash: $35862
**ahem**cough**snort**fart**cough**
http://www.cadillacfaq.com
The Caddy that zigs?
So they were a generation late...
Will getting rid of poast counts change how I poast? Dream on...
Currently in the rare 20,000 poast club. 23,165 and counting...
  #9 (permalink)
Old 03-17-07, 02:23 PM
ewill3rd's Avatar
Cadillac Technician
Cadillac(s): none
Casino Cash: $16917
Oh and there might be something about it in the FAQ
Tags: , , ,
bushing, cradle, rear, torque
Censor is OFF
