Schroth Harness Update
Page 1 of 2 12 LastLast
Results 1 to 15 of 21
2004-2007 Cadillac CTS-V General Discussion Discussion, Schroth Harness Update in Cadillac CTS-V Series Forum - 2004 - 2007; Hi All: Yesterday I finally got the correct parts installed to finish the Schroth ( http://www.schrothracing.com/ ) Quick Fit Pro ...
    Feffman's Avatar
    Feffman is offline Cadillac Owners Enthusiast
    Automobile(s): CTS-V
    Nov 2006
    St. Louis, Mo.
    672
    Hi All:
    Yesterday I finally got the correct parts installed to finish the Schroth (http://www.schrothracing.com/) Quick Fit Pro 4-point harness for the V. They operate great and look good, particuarly since they can be removed from the car with four simple clicks disconnecting at the seat belt points when not in use. These are HANS device compatible too.
    The initial install had to wait as the mounting pieces that bolt in where the existing seat belts bolt in (one on the outside of the front seat and one on the outside of the rear) were not the correct length. Had to send them back to HMS Motorsports (Schroth http://www.schrothracing.com/) having them customized to the proper length. It seems they were NOT as custom as HMS claimed. Presumably, they now have the design corrected.
    Not inexpensive at around $315 per side. A good number of groups insist the restraint system is the same on both sides so I may have to do the other side as well. Kind of a pisser as I almost never have passengers (particuarly aftet the California Porsche deaths) while on track.
    Happy Motoring!
    Feff
    www.MVPTrackTime.com
  2. #2
    rand49er's Avatar
    Jan 2005
    South Lyon, MI
    68
    13,829
    Re: Schroth Harness Update
    Hey, Mark, have you got a digital camera. Would love to see this harness, but ...
  3. #3
    Chef's Avatar
    Chef is offline Cadillac Owners Connoisseur
    Feb 2006
    Arizona
    1,928
    Well done!
    Pics would be great if you have the time?
    Chef
  4. #4
    Rockafella's Avatar
    Rockafella is offline Cadillac Owners Member
    Automobile(s): 2004 Cadillac CTS-V
    Sep 2006
    Michigan
    89
    [QUOTE=rand49er;974800]Hey, Mark, have you got a digital camera. Would love to see this harness, but ...
    /QUOTE]
    Hey Randy, getting ready for Gingerman!?! Haha..
  5. #5
    Feffman's Avatar
    Nov 2006
    St. Louis, Mo.
    672
    Photos as requested
    2nd photo down is the front strap that installs with the same nut as the stock seat belt. This needed to be lengthened 2" inches for a proper fit. The plastic slot that the belts slip through needed to be widened slightly with a Dremel to accomidate both belts simultaneously.
    Bottom photo is the rear mounting point (outiside by the door) bolted to the same spot as the rear seat belt under hte seat. Schroth had to lenghten this 1" inch but it may have been better to add 2" inches. Neither of the added attachments interferes with the stock seat belt operations and doing them in black makes them less noticable.
    Feff
  6. #6
    ctsvett's Avatar
    ctsvett is offline FAQ is your Friend
    Feb 2003
    California
    3,987
    That looks pretty cool... I would be careful since these probably arent tested in a crash simulator, but nothing aftermarket usually is.
    Does this place have the part number for the entire kit? Can you list list part numbers and lengths?
    Does it hold you pretty well if you get crazy in the twisties?
    I for one may do this just for more support when driving fun in the hills near where I live.
    I would put this install up on the FAQ if you care to provide details. This question has been asked many times.
    Reed
  7. #7
    Feffman's Avatar
    Nov 2006
    St. Louis, Mo.
    672
    Quote Originally Posted by ctsvett View Post
    You can simply call HMS Motorsports and tell them you want a set of the Schroth Quick Fit Pro harnesses for a CTS-V. Make sure you tell them you want the bolt in parts that are longer for the CTS-V.
    Honestly haven't tried them out yet as I was installing the Ground Control suspension this weekend as well.
    Reed
    Give me a few days to do a write up and I'll get it to you.
    Feff
  8. #8
    Chef's Avatar
    Feb 2006
    Arizona
    1,928
    Good stuff!!
  9. #9
    ctsvett's Avatar
    Feb 2003
    California
    3,987
    waiting on your feedback before I jump in..
    Reed
  10. #10
    Feffman's Avatar
    Nov 2006
    St. Louis, Mo.
    672
    Just ordered the passenger side Schroth harness as most clubs require equal restraints on each side. OH well at least I'll match now!
    Feff
  11. #11
    heavypedal's Avatar
    heavypedal is offline Cadillac Owners Fanatic
    Automobile(s): '04 Raven CTS-V
    Oct 2005
    Raleigh, North Cackalacky
    415
    Feff....the Schroth harness looks badazz in the car. Definitely need the passenger side one to take the newbies on hot-laps
    T
  12. #12
    rgd
    rgd is offline Cadillac Owners Enthusiast
    Automobile(s): 04' CTS-V, 04' Escalade EXT
    Aug 2005
    SF Bay Area
    623
    Hi Reed,
    To answer your question, yes it will hold you in place thru the twisties. That is the exact same setup I put in my car a while ago.
    Feff you will love it!
    Thought i would jump in w/my $0.02.
    Reed
  13. #13
    rgd
    Aug 2005
    SF Bay Area
    623
    Ps. Looks gr8!
  14. #14
    Chef's Avatar
    Feb 2006
    Arizona
    1,928
    Any updates Feff?
    I'm calling them tomorrow - Do you have a contact name there?
    As far as install - How ez / time consuming?
    thx,
    Chef
  15. #15
    Feffman's Avatar
    Nov 2006
    St. Louis, Mo.
    672
    Quote Originally Posted by Chef View Post
    Any updates Feff? I'm calling them tomorrow - Do you have a contact name there? As far as install - How ez / time consuming?
    Chef:
    Very easy install, simply have to remove the rear seat for rear seat mounts. The front outside mounts needed a littel Dremel work on the plastic part of the seat (cover for bolts, etc.) to allow the additional seat belt through the slot. They work great but are pretty pricey. I've yet to install any type of 5th point (crotch belt) due to lack of time.
    Feff
  16. Remove Advertisements
