| 2004-2007 Cadillac CTS-V General Discussion Discuss everything about the first generation Cadillac CTS-V that does NOT fall into either the Performance or Appearance Modification category. | Cadillac Forums: Amp connecting to RAP circuit
02-03-07, 09:30 PM
| | Cadillac Owners Member Cadillac(s): Cadillac CTS-V | | Join Date: Feb 2007 Location: Perry Hall, MD | | | Amp connecting to RAP circuit I would like to add an amplifier to the rear sub. The sub doesn't seem to do much. I have temporarily connect the AMP and it works great.
I have read the FAQ on using the RAP circuit to power the AMP. I have the sunroof so I should have the RAP relay. Where do I find the circuits described in the FAQ?
New CTS-V owner and loving it, traded a 96 Impala SS for it. I miss the Impala SS but the CTS-V is a lot more fun. :-)
Thanks |
02-03-07, 10:28 PM
|  | Cadillac Owners Connoisseur Cadillac(s): 2005 Cadillac CTS-V | | Join Date: Nov 2006 Location: Moultrie, GA Age: 49 | | | Re: Amp connecting to RAP circuit Quote:
Originally Posted by The_Groundhog traded a 96 Impala SS for it. I miss the Impala SS but the CTS-V is a lot more fun. :-) | Traitor.
Welcome to the Caddy side. It IS fun, ain't it?
__________________ Gene Z. aka Boilermaker
05 CTS-V, Stealth Gray aka The Don V, Just an exhaust and a chip, man!!
Highest mileage V on the forum?
In service 12/1/06, >139,000 miles and counting....
96 Impala SS aka Black Sunshine, 383, Twin Turbo, 11's, ~245,000 miles |
02-03-07, 10:33 PM
|  | Cadillac Owners Master | | Join Date: Mar 2004 Location: Reno, NV | | | Re: Amp connecting to RAP circuit Are you looking for a switched source or just a +12V? Both are available under the rear seat. The constant +12V is on the driver's side fuse block - I don't recall what it is labelled.
Innocent Bystander indicated that this block was fed with twin 10 gauge leads, IIRC, so that is where my 8 gauge power feed for the MTX auto-on amp is.
However, I'm guessing you're looking for the switched lead. You'll have to probe the fuseblock on the passenger's side under the rear seat for the wire you need...'cause I searched and couldn't find it (killed the brain cells last month I suppose).
WW |
02-03-07, 11:42 PM
| | Cadillac Owners Connoisseur | | Join Date: Feb 2004 Location: Conroe, Texas Age: 41 | | | Re: Amp connecting to RAP circuit Uh............"Search" is your friend. Sorry Wild..........I just couln't help myself.
Shane |
02-03-07, 11:52 PM
| | Cadillac Owners Member Cadillac(s): Cadillac CTS-V | | Join Date: Feb 2007 Location: Perry Hall, MD | | | Re: Amp connecting to RAP circuit Thanks guys. I'll look for it in the morning under the seat. |
02-03-07, 11:56 PM
| | Cadillac Owners Member Cadillac(s): Cadillac CTS-V | | Join Date: Feb 2007 Location: Perry Hall, MD | | | Re: Amp connecting to RAP circuit Yes, I would have loved to keep the Impala SS but with 142K miles and my wife hit it three times in the driveway with her Tahoe. Both sides had been fixed and painted. I figured if I wanted it back I could find another one that had never been hit and less miles. |
02-04-07, 02:31 PM
|  | FAQ is your Friend Cadillac(s): CTS-V | | Join Date: Feb 2003 Location: California | | | Re: Amp connecting to RAP circuit its funny how many people here traded or are former impala SS owners.
I am one... Lasstss is one.. and I keep seeing this everywhere..
Looks like all of us traded up to a faster, cooler GM high performance sedan product.
Ontopic: Use the fuse block under the rear seat as WW explained.
Reed |
02-04-07, 08:42 PM
| | Cadillac Owners Member Cadillac(s): Cadillac CTS-V | | Join Date: Feb 2007 Location: Perry Hall, MD | | | Re: Amp connecting to RAP circuit Well I pulled the rear seat today, nothing under there but a bunch of wires in a bundle on each side. I did not see a fuse block. |
02-05-07, 12:08 AM
|  | FAQ is your Friend Cadillac(s): CTS-V | | Join Date: Feb 2003 Location: California | | | Re: Amp connecting to RAP circuit did you pull the insulation carpet as well? Its attached to the front lip of the rear seat raised metal piece:
Reed |
02-05-07, 12:00 PM
| | Cadillac Owners Member Cadillac(s): 2004 CTS-V | | | | | Re: Amp connecting to RAP circuit If anybody can actually identify the switched power lead in the fuseblock, please let me know. I probed every lead and checked the wiring diagram and the only place I could track the RAP down to was the blue wire in the right trunk area going up the rear pillar for the sunroof.
-Chris |
02-05-07, 11:24 PM
| | Cadillac Owners Member Cadillac(s): Cadillac CTS-V | | Join Date: Feb 2007 Location: Perry Hall, MD | | | Re: Amp connecting to RAP circuit Thanks for the pic. I'll pull the seat and look again. Being that it's about 35 degrees in the garage with the heat on 8 outside. I'll wait for warmer weather to try again. |
02-06-07, 12:41 AM
|  | FAQ is your Friend Cadillac(s): CTS-V | | Join Date: Feb 2003 Location: California | | | Re: Amp connecting to RAP circuit FYI, this is a work in progress, but it may help you. http://www.cadillacfaq.com/faq/answers/amprap/
Reed | | Cadillac Discussion Tools | | |
Censor is OFF | | | |
