| If your thinking about a new cam install... Now that my suspension is done it's time for an Engine re-build. I plan on going thru the whole thing, headers, cam, heads, intake, tbody, valves etc...etc...
Anyway, I started my research here, then did some LS1 tech reading etc. I finally decided to make some calls and found the following. Though I am sure there are plenty of other options including doing the work myself which I am not opposed though it would probably take 8x the time it should; this method seems like it will be the coolest way to go.
I called LG Motorsports and began asking questions about cam/header packages etc and found this out. If you buy all the necessary parts thru LG you can have their race team tear down and re-build your car in one day while at the track during a SCCA event. They meet you there with parts in hand so you don't bring anything but you, your car and, oh your wallet! They set you up with a pit pass you can watch the race, hang out with the team walk over and meet Andy Pilgrim etc... How cool will that be! I plan on having my car done in August during the Infineon race in Sonoma. The total bill should be around 7k or less. I compared the cost of parts to what I could buy them direct or indirect if you will same cost. They charge about 1k labor. From what I can tell that is reasonable.
They said with a mild(ish) cam they should be able to get around 490-500 rwhp.
Thought I would throw this out there so if anybody is interested they can check into it.
Thanks,
rgd
Reason: add info
