| 2004-2007 Cadillac CTS-V General Discussion Discuss everything about the first generation Cadillac CTS-V that does NOT fall into either the Performance or Appearance Modification category. | Cadillac Forums: TPS Ques
01-04-07, 04:35 PM
|  | Maggied V = More than just an appliance. Cadillac(s): 2005 CTS-V | | Join Date: Jan 2005 Location: South Lyon, MI Age: 61 | | | TPS Ques Just got another set of tire pressure sensors for my Mille Miglias, but started thinking about interference from the original four sensors on my OEM wheels. Three are sitting in the garage near the car PLUS my spare (in the trunk, of course) has a sensor in it.
Besides storing the three OEM wheels/tires in the basement (presumably to get them out of range), what do others do? What about the spare? Can they be "shielded?"
(This may be a complication I hadn't thought about.  )
__________________ '05 CTS-V, Stealth Gray, Sunroof, 3M Clear Bra, B&M Shifter w/UUC Bushings, Specter Werkes Bushings, V Headrests, Wheel To Wheel Powertrain Tune, Corsa, Kooks w/Hi-Flo Cats, Ultimate Grid Pedals, Hotchkis Anti-Sways, STS-V Fogs, Ground Control 650R/600F, WW Clear Sidemarkers, Full-Size Spare, Magnuson SC Polished, CTS Console, FG2, Aggressive Street Alignment, MOMO Shift Knob, DSS/Hendrix Engrg Axles, UUC Flywheel. Soon: UUC MMs. 472 RWHP/411 RWTQ (Mustang dyno). |
01-04-07, 04:52 PM
|  | Cadillac Owners Enthusiast Cadillac(s): 2005 CTS-V | | Join Date: Jun 2005 Location: Ames, IA | | | Re: TPS Ques When you reprogram the new sensors they are the sensor for each wheel. Doesn't matter where the old ones are sitting. |
01-04-07, 04:59 PM
|  | Cadillac Owners Connoisseur Cadillac(s): 05' CTS-V | | Join Date: Feb 2006 Location: Palm Beach Gardens, FL Age: 24 | | | Re: TPS Ques yup, just think if you parked next to another V if they did like you say, you'd have problems...but since its already "coded" to the car, you should be fine...now the VW toureg did have that problem...sitting on the new car lot one would read the ones next to it tire sensors...I guess thats just one of the reasons they dont make it anymore. |
01-04-07, 05:02 PM
|  | Maggied V = More than just an appliance. Cadillac(s): 2005 CTS-V | | Join Date: Jan 2005 Location: South Lyon, MI Age: 61 | | | Re: TPS Ques Quote:
Originally Posted by AmesCTS-V When you reprogram the new sensors they are the sensor for each wheel. Doesn't matter where the old ones are sitting. |  DOH! That's right! When I release air out of each one, that tells the display which one is which.
Can I go crawl into a hole now.  Mods ... lock this thread. |
01-04-07, 10:14 PM
| | Cadillac Owners Fanatic | | | | | Re: TPS Ques wrap them in aluminum foil to shield their signal from the car sensor. |
01-05-07, 02:19 PM
|  | Cadillac Owners Enthusiast Cadillac(s): 2007 CTS-V (Thunder Grey) | | Join Date: Dec 2005 Location: Sacramento Kalifornia Age: 59 | | | Re: TPS Ques I thought after a while they stopped transmitting to conserve battery life and a sudden pressure change or rotation above a certain speed would start them transmitting again. I have a Corvette with TPS and 4 extra CTS-V stock wheels for the V with TPS and I have no problem with interference.  |
01-05-07, 02:27 PM
|  | Cadillac Owners Enthusiast Cadillac(s): 2005 CTS-V | | Join Date: Jun 2005 Location: Ames, IA | | | Re: TPS Ques I haven't looked at exactly how they work. But I think it's pretty clear they all have a unique id of some sort and they transmit that along with the pressure data so the car knows what id goes with what tire. It wouldn't matter if there was a box of 1000 TPS's sitting inside the car it's not going to read them, just the 4 it's supposed to. |
01-05-07, 03:31 PM
|  | Out of the hunt Cadillac(s): An old V | | Join Date: Sep 2004 Location: Steeler Nation | | | Re: TPS Ques Quote:
Originally Posted by rand49er  DOH! That's right! When I release air out of each one, that tells the display which one is which.
Can I go crawl into a hole now.  Mods ... lock this thread. | Don't feel bad dude, others on this forum have done the same thing more than once. Don't ask me how I know...
__________________ { This message is composed of 100% recycled sub-atomic particles. No trees were harmed in the posting of this message. However, billions of electrons were temporarily inconvenienced. |
01-08-07, 09:37 AM
| | Cadillac Owners Connoisseur | | | | | Re: TPS Ques Most of the responses to the original question are correct. The system responds only to TPSs for which it has been programmed. The only potential problem is that a nearby TPS that you don't want programmed, transmits its code while you are in programming mode. This can happen even though wheels with TPSs that are not moving transmit much less frequently (once every hour as opposed to once every 20 sec., or something like that), they do not stop transmitting completely. I have reprogrammed the TPM system on both mine and my wife's car numerous times (following tire rotations and changes) with the cars sitting beside each other and have had no problems. However, because of the potential problem I just described, I verify that the system responds only to the TPSs on the car. There are several ways to do this. The simplest and most efficient way is to check the pressure display when pumping the tires up again. The TPS will transmit at that time due to the pressure change. Ensure that the display responds to the correct tire in the correct position. |
01-08-07, 09:45 AM
|  | Cadillac Owners Enthusiast Cadillac(s): 2005 CTS-V | | Join Date: Jun 2005 Location: Ames, IA | | | Re: TPS Ques Quote:
Originally Posted by tedcmiller Most of the responses to the original question are correct. The system responds only to TPSs for which it has been programmed. The only potential problem is that a nearby TPS that you don't want programmed, transmits its code while you are in programming mode. This can happen even though wheels with TPSs that are not moving transmit much less frequently (once every hour as opposed to once every 20 sec., or something like that), they do not stop transmitting completely. I have reprogrammed the TPM system on both mine and my wife's car numerous times (following tire rotations and changes) with the cars sitting beside each other and have had no problems. However, because of the potential problem I just described, I verify that the system responds only to the TPSs on the car. There are several ways to do this. The simplest and most efficient way is to check the pressure display when pumping the tires up again. The TPS will transmit at that time due to the pressure change. Ensure that the display responds to the correct tire in the correct position. | While I suppose this is possible it's really really really unlikely. It takes a pretty huge pressure change to get them to transmit and be programmed to be accepted by the car. The chances that a tire that is just sitting there is going to have a pressure change like that before the tire that you are actually letting air out of is almost impossibly low. |
01-08-07, 02:39 PM
| | Cadillac Owners Connoisseur | | | | | Re: TPS Ques Quote: |
| I don't think you read what I wrote carefully enough. It doesn't require a pressure change to cause the TPS to transmit. The factory service manual indicates that the TPS will transmit approximately every hour regardless of rotational speed or pressure changes. This is why the chances of getting a transmission from another TPS while programming the TPM are not as small as you might think.
01-08-07, 03:00 PM
|  | Cadillac Owners Enthusiast Cadillac(s): 2005 CTS-V | | Join Date: Jun 2005 Location: Ames, IA | | | Re: TPS Ques That assumes that the TPS's always send the same signal. I assumed that there is a normal transmit and the rapid pressure change and/or the magnet method caused the TPS to send a different signal.
I've got 8 TPS's in my garage. Just for the heck of it I'll put the car in program mode and if you are right eventually it should pickup one of the sensors doing it's once per hour thing and use that transmit to program the first tire. I think you only have something like 5 mins to program so I'll might have to repeat it a few times. |
01-08-07, 04:01 PM
Originally Posted by AmesCTS-V That assumes that the TPS's always send the same signal. I assumed that there is a normal transmit and the rapid pressure change and/or the magnet method caused the TPS to send a different signal.
I've got 8 TPS's in my garage. Just for the heck of it I'll put the car in program mode and if you are right eventually it should pickup one of the sensors doing it's once per hour thing and use that transmit to program the first tire. I think you only have something like 5 mins to program so I'll might have to repeat it a few times. | Very interesting. Say, what is the frequency of transmission by a given TPS during normal driving? Every few minutes or so?
(This reminds me of one of those tanks physicists use that are filled with a liquid (glycol?) used to detect quarks emitted by the sun; these are located way down underground in mines.  ) |
01-08-07, 10:24 PM
|  | V-LOVIN Cadillac(s): 2005 CTS-V | | Join Date: Jul 2005 Location: Maryland | | | Re: TPS Ques Quote:
I've got 8 TPS's in my garage. Just for the heck of it I'll put the car in program mode and if you are right eventually it should pickup one of the sensors doing it's once per hour thing and use that transmit to program the first tire. I think you only have something like 5 mins to program so I'll might have to repeat it a few times. | Sorry to hijack... Ames- are you looking to sell any of them. I'm looking for 4 to put on my stock rims for Winter usage. If so, please send me a PM with the details.
Thanks,
John |
01-08-07, 10:29 PM
|  | Cadillac Owners Enthusiast Cadillac(s): 2005 CTS-V | | Join Date: Jun 2005 Location: Ames, IA | | | Re: TPS Ques They are all on rims. Going from summer to winter rims without having to mess with TPS's is nice. GMPD has pretty good pricing on them which I got my dealership to match. | | Cadillac Discussion Tools | | |
Censor is OFF | | | |
