2004-2007 Cadillac CTS-V General DiscussionDiscuss everything about the first generation Cadillac CTS-V that does NOT fall into either the Performance or Appearance Modification category.
Cadillac Forums: Why does my car not want to stop in the wet?
It takes a second for the clamp to bite down almost like there is a bead of water that needs to be shed from the pads/rotors. It is scary for a moment then they clamp down hard. Normal or not? Brakes fine in the dry.
Many brake systems will have a period of time to dry out the pad material before the friction heats up enough to clamp down. Are you talking about after driving in the wet without touching the brakes for a few minutes?
I think the V's brakes are more prone to do this than many other factory systems because it is a 4 piston caliper. The clamping force comes from both sides of the rotor so it may take slightly longer to clamp than a
single piston caliper. Just a good reason to take it easy in the rain, I guess.
__________________ The Caddy that zigs?
So they were a generation late...
Will getting rid of poast counts change how I poast? Dream on...
Currently in the rare 20,000 poast club. 23,327 and counting...
I had a car that refused to stop cold, especially if the temps were below freezing. The brakes worked great after half a mile but the first stop was the scariest stop of the day, almost killed me more than once.
Different brake materials have different characteristics. I'd say that the water is cooling them below an efficient range and that coupled with the moisture itself is degrading your stopping power at times.
You could try to switch brake materials (depending on what kind of driving you do most) or just get used to the phenomenon and take it into account in wet weather.
How is the brake dust on your car? If it's minimal, then my guess would be that the previous owner changed the stock pads for Hawk to reduce the dust. My brakes have exhibited the same "crap your pantsness" when driving in rain that you describe since I switched to Hawk pads.
