| 2004-2007 Cadillac CTS-V General Discussion Discuss everything about the first generation Cadillac CTS-V that does NOT fall into either the Performance or Appearance Modification category. | Cadillac Forums: Brake Duct Project Finished
12-03-06, 01:33 AM
| | Cadillac Owners Fanatic Cadillac(s): 04' CTS-V, 04' Escalade EXT | | Join Date: Aug 2005 Location: SF Bay Area | | | Brake Duct Project Finished Sorry for the lack of good pictures. I had taken a bunch during the install but have had problems saving them on my computer. These are after the fact (two weeks) captured from a short video for sake of show and tell.
At any rate, my brakes are now complete and consist of:
Two piece (front only/directional veined) Rotors ~ Solid, no slots no cross-drilled (my research tells me that is best for the way my brakes are set-up)
More surface to surface for braking power. Pads don't glaze until temps are way/way up there.
Raybestos ST-41 Pads (first time used will comment after track event this Sunday, Sears point/Infineon) So far they seem great. Because the event is Sunday and the track is only 45 miles away I’m just going to leave the on until after the event.
First impression at Sears point (excellent)! I will know better after next weekend when I am at a familiar track. I will be able to push harder and compare braking to previous sessions.
8 feet of BRADUC30SIL Duct Tube
24" x 18" piece of sheet metal cut and shaped into two 9" round pieces of sheet metal with hole in center to fit hub thru, three bolt holes and one strategically placed oval hole matching the duct tube hose after it is shaped
1/8" x 3/4" x 96" aluminum (used for brackets)
Assorted rivets n bolts
1. First I removed front wheels, Calipers (hang out of way via rope), and rotors.
2. Remove bolts holding hub and remove bracket which holds the traction control sensor wire (I used it as a pattern to cut out inner hole and bolt patterns for my 9" sheet metal pieces used to seal the inner portion of the rotors. (When placed between the steering knuckle/hub) it is perfect alignment to seal off inner portion of the rotor.
Picture 1
3. Remove the front fender well liner, pulled off the intake duct tube and cut about 1.5” to 2” off to allow the 3" duct hose to fit inside it.
1. (I riveted the hose to the intake duct tube.)
4. Then I cut a slot from the hole the stock tube entered the wheel-well towards the inner wall of the wheel-well/frame so I could run the tube to the inside of the wheel well with ought making contact with the tires.
5. Shaped and installed brackets to hold duct tube out of harms way.
6. Once the brackets were in place I put the wheels back on the check clearance again.
Picture 2
7. Trimmed the length of the hose not needed and shoved it thru the oval cutout in the sheet metal back plate that seals the inner rotor and riveted it in place.
Picture 3
The procedure took about 8 hrs for the driver’s side and 1.5 hrs on the passenger side. Typical, after doing something once it is much easier and faster the second time. Also there is more room on the passenger side because the PCM and steering is on driver’s side.
Thats it!
Thanks,
rgd
12-03-06, 01:56 AM
|  | Cadillac Owners Master | | Join Date: Mar 2004 Location: Reno, NV | | | Re: Brake Duct Project Finished rgd -
nice writeup. Sorry for the inexperienced question - but why direct the venting to the center of the brake disc? Do the vents in the rotors actually draw air through them?
WW |
12-03-06, 03:00 AM
| | Cadillac Owners Connoisseur Cadillac(s): 2004 V | | Join Date: Feb 2004 Location: Calif. Age: 42 | | | Re: Brake Duct Project Finished Yes, from the inside out. |
12-03-06, 06:40 AM
|  | No BS Zone Cadillac(s): 2005 Cadillac CTS-V | | Join Date: Nov 2006 Location: Moultrie, GA Age: 48 | | | Re: Brake Duct Project Finished Nice project!
Mind sharing where you got those rotors? How much?
I dream about stopping with these.....
__________________ Gene Z. aka Boilermaker
05 CTS-V, Stealth Gray aka The Don V, Just an exhaust and a chip, man!!
In service 12/1/06, >137,000 miles and counting....
96 Impala SS aka Black Sunshine, 383, Twin Turbo, 11's, ~245,000 miles |
12-03-06, 09:48 AM
|  | Cadillac Owners Connoisseur Cadillac(s): '04 CTS-V platinum/blk. | | Join Date: Aug 2004 Location: CT | | | Re: Brake Duct Project Finished rgd,
Well done brother.....that's an aggressive project. |
12-03-06, 10:33 AM
|  | Cadillac Owners Connoisseur | | Join Date: Feb 2006 Location: Arizona | | | Re: Brake Duct Project Finished I'm on your six RGD... Well done indeed!  |
12-03-06, 11:23 AM
|  | Cadillac Owners Master | | Join Date: Mar 2004 Location: Reno, NV | | | Re: Brake Duct Project Finished Quote:
Originally Posted by Dreamin Yes, from the inside out. | Thanks, Dreamin. Hmmm...might have to add this project to the mod list for the V. I don't seem to have anything on there at the moment
Good job RGD.
WW |
12-03-06, 01:50 PM
| | Cadillac Owners Fanatic Cadillac(s): 04' CTS-V, 04' Escalade EXT | | Join Date: Aug 2005 Location: SF Bay Area | | | Re: Brake Duct Project Finished Quote:
Originally Posted by wildwhl Thanks, Dreamin. Hmmm...might have to add this project to the mod list for the V. I don't seem to have anything on there at the moment
Good job RGD.
WW |
lololololoololoollooolollololo   Stop it I cant breath...
No really!
rgd
Thanks by the way. |
12-03-06, 02:00 PM
| | Cadillac Owners Fanatic Cadillac(s): 04' CTS-V, 04' Escalade EXT | | Join Date: Aug 2005 Location: SF Bay Area | | | Re: Brake Duct Project Finished Black Sunshine, is that anything like fire and ice; Oops wrong venue!
Coleman Racing, for rotors, they can do the hats too.
Any 18" rotor 175.50.
Hats around $220 ea I believe.
Origionally I did not get my hats there but I probably would if I had it to do over.
Easy search on the web.
thanks,
rgd |
12-03-06, 02:36 PM
|  | No BS Zone Cadillac(s): 2005 Cadillac CTS-V | | Join Date: Nov 2006 Location: Moultrie, GA Age: 48 | | | Re: Brake Duct Project Finished Thanks for the info.  |
12-04-06, 06:03 AM
|  | Cadillac Owners 10000+ Posts Cadillac(s): Black the Darkside | | Join Date: May 2004 Location: Central Ohio | | | Re: Brake Duct Project Finished Your flex ducts look similar to the NASCAR brake ducts. Of course at 180 mph braking really heats up the rotors. This might serve you track boys well but not of much use for a daily driver. I assume the ducts give you full rotation of steering? Good job!  |
06-25-07, 10:43 AM
| | BLING IS AMERICAN RICE Cadillac(s): '04 CTS-V | | Join Date: Jun 2004 Location: Just North of Titletown... | | | Re: Brake Duct Project Finished Quote:
Originally Posted by rgd Sorry for the lack of good pictures. I had taken a bunch during the install but have had problems saving them on my computer. These are after the fact (two weeks) captured from a short video for sake of show and tell.
Picture 1
Picture 2
Picture 3
Thats it!
Thanks,
rgd | Hey rgd, do you think you could give us an update and repost the pictures???
__________________ The Caddy that zigs?
So they were a generation late... Will getting rid of poast counts change how I poast? Dream on...
Currently in the rare 20,000 poast club. 23,327 and counting... | | Cadillac Discussion Tools | | |
Censor is OFF | | | |
