CTS-V oil temp still looks high?
Results 1 to 5 of 5
2004-2007 Cadillac CTS-V General Discussion Discussion, CTS-V oil temp still looks high? in Cadillac CTS-V Series Forum - 2004 - 2007; Buzzing around town, saw 265f. Took it out for a quick drive around and on the highway, saw 273f. Yeah, ...
    globed70 is offline Cadillac Owners Enthusiast
    Feb 2004
    590
    Buzzing around town, saw 265f. Took it out for a quick drive around and on the highway, saw 273f. Yeah, i do run it up through the gears pretty good, but this isn't track driving. The coolant is running 195f, the tranny about 150f, and oil pressure around 50psi. Checked the oil level, showing full. My concern is that with some hard driving, I could easily hit the oil temp max. Anybody else seeing the same thing? Could it be related to calibration issues discussed in C&D?
  2. #2
    GNSCOTT is offline Cadillac Owners Connoisseur
    Jan 2004
    Connecticut
    1,061
    Re: CTS-V oil temp still looks high?
    Quote Originally Posted by globed70
    Have you tried calling the dealer yet?? Could be another calibration problem seeing how oil cooling can't be much different than a ZO6. I'd have to see where the oil cooler lines run, but I couldn't imagine them going close to the headers with no sheild.
  3. #3
    Feb 2004
    590
    I spoke to the dealer this morning... they called the techs at GM/Caddy and there is nothing noted in terms of this sort of problem (guess they fixed the calibration issue before the first batch left?); and they had no comment on whether my temps were abnormal. In any case, they will check the trouble codes tommorrow morning; not convinced they'll find anything. Z06 vettes show much lower oil temperatures than mine.
    Everyone out there with a CTS-V: what are your oil temps during normal and hard driving?
    You can toggle through the display choices to find it... don't mix it up with trans temp or coolant temp. THANKS!
  4. #4
    benjet's Avatar
    benjet is offline Cadillac Owners Connoisseur
    Dec 2003
    Bay Area, CA
    1,372
    Dont think I've seen them that high (and I have already been on the track with mine). Usually 230-250.
  5. #5
    Jan 2004
    Connecticut
    1,061
    I'm inclined to think its more of a calibration issue. It should run a little hotter than a Z because you are heavier (comparitively speaking) but problably not that much higher.
  6. Remove Advertisements
